| This thread is about: Change the defrost options, it's in General Discussion at the Honda Civic forum Civinfo; Was looking on the net for info on removing the HU on my 4dr saloon and came across this.....something completely different Disclaimer: I am ... | ||
JDM all the way!
Disclaimer: I am in no way claiming I figured this out. It does work though. So if you turn on your defrost windows button for the windscreen (not the heated button for the rear and side) the A/C is automatically turned on with it. The reason being the A/C dries the air which will removes condensation from the windows quicker. It is automatically set because in hotter/humid countries it is the only way to clear the windows. There is a way to allow you the option to have the defrost on the windscreen and be able to turn the A/C on/off. This supposedly would reduce your fuel consumption when A/C is not needed. Like most here I bet you don't care why it makes a difference, it's just some more buttons for us to press So here you go.... a. Turn on the car b. Put the temp knob all the way to cold & turn the fan knob to off c. Put the "mode" to the face only location d. Turn the car off e. Hold down the Recirculate Button and A/C Button f. While holding both buttons turn the key all the way to the on position (don't need to start the engine) g. Keep both buttons pressed, two dashes will appear on the little lcd, then "Lo" will appear when the change has been made. Then you can let go. h. Turn off the car, then back on and press the defrost button. You should now see "a/c on" on the display and you can turn it off without stopping the defrosting Let me know if it works for you!! |
#4 (permalink) | |
But I agree - the A/C will drain about 0,2 l/hour so as lon as you don't need it why use it? |
JDM all the way!
Very constructive post there buddy
![]() You obviously didn't read my post, as I said I found it while looking for info on removing my Head Unit (so I could put an aux-in in for my ipod without paying honda their extortionate price). ![]() Some people like messing with the setting on their cars, so I posted it, just like someone posted the one that tests all the lights on the dash.....which I see no reason for but what the hell, if people like it then let them at it. |
| Sponsored Links | |
Advertisement |
Similar Threads for: Change the defrost options
| [How to] Defrost your windows in record time | N2H | How To | 61 | 18th March 2008 10:18 |
| Options | Kremmen | Buying, Dealers and Servicing | 6 | 8th March 2008 10:37 |
| What options? | FWH | Buying, Dealers and Servicing | 18 | 9th June 2007 18:23 |
| What options? | smb09_1999 | Buying, Dealers and Servicing | 2 | 2nd March 2007 13:07 |
| 2.2 EX options | dondon | Introduce yourself | 13 | 21st February 2007 00:36 |
