This thread is about: Diesel Limiter cutting in, it's in General Discussion at the Honda Civic forum Civinfo; Honda 57 Civic Type S 2.2 D - I have been getting a strange problem when trying to open up the engine and pull away ...
Old 2nd July 2008, 12:35   #1 (permalink)
dobbie's Avatar
Honda 57 Civic Type S 2.2 D - I have been getting a strange problem when trying to open up the engine and pull away fairly quickly. I know we try and pull away from lights but on the last few occsions when giving it some wellie I have managed to get all 5 led;s lit and de activate the power in first gear. The limiter seems to cut in to soon so if you want to keep the power on a touch longer my civic does not seem to handle this. I have even managed to do this in second gear as well, although this has only happend once.
My question is, has this happend to anyone else and is it a normal function of the car. Incidently when I first got the car this did not happen and it seemed to have a lot more poke in first. This has only happend in the last few weeks.
Bernie
dobbie is offline   Reply With Quote
Old 2nd July 2008, 14:01   #2 (permalink)
If the limiter is cutting in your are over revving it change up earlier. I find it better to get rolling in first then floor it in second.
Old 2nd July 2008, 14:54   #3 (permalink)
I don't know what the led's are like in the diesel, but in my Type R when all of them are lit I am right at the top of the rev range, and to continue revving it would cause the limiter to activate.
Have a read of this : Rev Limiter
If you think it is not working properly take it into your dealer and demonstrate it to them. Sounds to me like it is ok though
Old 2nd July 2008, 16:14   #4 (permalink)
cb550's Avatar
Bernie
Hav'nt(knowingly) had the rev limiter cut in on this car,but have with other diesel cars.
Have had all the led's up in 1st,but I think anticipating the change up,so probably not holding on for the rev limiter to have an effect.
I would have thought the car was functioning properly if holding on in a gear at max revs and the the car hesitates due to the limiter
Old 3rd July 2008, 16:03   #5 (permalink)
FAL
First gear is quite "short" on this car, so you should expect to quickly run out of revs in first. Fifth is very "tall" too compared with some other makes I've driven.
One day, with 6 gears to play around with, some designer somewhere might actually manage to get the gear ratio spacings optimised. As it is, we still seem to suffer from the sort of gearbox "gaps" we used to see with a "short" second in 1960s 4speed Fords........
FAL is offline   Reply With Quote
Similar Threads for: Diesel Limiter cutting in
Flip Key Cutting Sites markvirgo General Discussion 33 28th September 2008 22:51
Rev limiter = a valuable thing! uncler Type-R 40 30th April 2008 19:11
Performance Rev Limiter dragonglance Engines and Transmission 15 25th March 2008 20:15
Nissan GT-R recognizes tracks via GPS and removes speed limiter trev0006 Any non Civic chat here please! 3 23rd December 2007 21:04
Satnav Radio cutting out pjelsworth Electronics 5 25th May 2007 18:06
