| This thread is about: NCAP Rating now available - Only 4*, it's in General Discussion at the Honda Civic forum Civinfo; Originally Posted by Hartside Not convinced. Newtons second law is "net" Force, which takes into account all forces acting on a body. Extra frictional force ... | ||
#61 (permalink) | |
My original thought was actually more about what happens to the engine in a collision...you'd think that the diesel might on the one hand provide more protection if it is mounted more solidly (I don't know that it is, however) and is of a stronger construction generally (which is normally the case with diesel engines), but on the other hand might cause bigger problems if it was to move during a collision, being heavier. |
#62 (permalink) |
This is like failing an exam when you know the questions in advance. Sorry to say that this leaves me with a strong feeling that the safety aspects of the Civic have been misrepresented.
#63 (permalink) |
According to the blurb, Honda's state of the art crash testing facility is staffed by 300 safety engineers.
I deduce, therefore, that some of them were having a crafty fag behind the bike sheds when the Civ was first being tested |
#64 (permalink) | |
Greek Subtopic Moderator
#65 (permalink) |
Galaxy class starship
I think they did exactly that. Re-produce NCAP test crashes in their own testing facility. Whoever it was that presented their test results at a meeting must be feeling a bit queezy at the moment.
Off-topic ramblings: Wow, I didn't know we could drag n' drop smilies from posts into this "Quick Reply" field. |
#67 (permalink) |
Just read this report with interest especially the part that states Honda dealers can disconnect the passenger airbag to allow rearward facing childseats to be fitted in the front.
We have not seen any communication from Honda on this point and will certainly not be offering this service ( if indeed it exists ). This point ( an important one) does seem to cast a bit of doubt in my mind about the credibility if this report. |
#70 (permalink) |
Smell My Cheese!
Thie first bit is on about hitting a bumper going over a bump in a square somewhere, struggling with relevance....
#73 (permalink) |
Maybe people are getting unnecessarily upset at the really tiny extra risk represented in that lost star.(Especially if they ignore the huge risk of smoking, for instance!) But it's annoying that inferior cars score higher, I agree. Incidentally, I wonder what the equivalent effect would be for a passenger aircraft not achieving the top standard. I can't believe they all have identical safety ratings. Pottsy?
#75 (permalink) |
Honcho, all passenger aircraft are of the same safety standard. In aviation the emphasis is on not crashing in the first place, whereas because cars are thousands of times less safe then there has to be an emphasis on safety in a crash.
I suspect that Myago would have had to hit a curb pretty hard to bend the shell, but then again modern crash testing and design is all about getting the car to rapidly deform around a secure passenger area so I wonder if this readiness to deform has caused this. In other words, the higher the stars the greater the likelihood of having major damage in a minor bump. How ironic! |
#76 (permalink) | |
The bodyshell frame has to take up all the forces and moments. Mine does not have the glass roof, and the metal feels soooo thin and weak, even when washing with a sponge... But actually (as I perceive), it is there to cover the opening instead of the glass choice and in no ways contributing to the shell rigidity. Elements, either shell or frame that are outside the passenger compartment shell, are designed for absorbing forces by crushing, before the forces start bending the passenger compartment shell. However, the only thing I don't like there is that, the currently bent part could be fixed to the main chassis frame by bolts; whereas, as I see from the photos, is welded. I understand that we have to be very careful when approaching kerbs or "stopper pipes" (if I can mean what I think..) in parking places. |
#78 (permalink) |
note to self:
check pilot's name before flying back to the stars - personally I'm happy with the narrow margin that we missed out by. the extra 7mm (or whatever it was) that the pedal moved? What do you recon the chances are of that actually making a significant difference in the case of (gawd forbid) a crash? obviously they have to set a limit somewhere - x movement = 1 star, y movement = 2 stars etc, but I'm not going to loose a lot of sleep over it. though I can certainly understand those people who are less than happy. |
#79 (permalink) |
Its not so much the score, i mean 3*'s would have been very disappointing, its just with all the fuss they made over it, seems like a let down, particularly for the family folk.
| Ncap Rating Why 4 Star? | chriswarwick | General Discussion | 5 | 17th November 2007 17:03 |
| Head Unit Power rating of Head Unit (satnav model) | FWH | Ipods, MP3 Players and ICE | 5 | 2nd October 2007 22:58 |
| Euro NCAP test results? | pikkumies | General Discussion | 1 | 18th June 2006 19:56 |
