Boot struts.. - Civinfo
 3Likes
post #1 of 23 (permalink) Old 22nd May 2016, 11:32 Thread Starter
JPP
Welshivic's Avatar
Car: 2008 2.2 EX Nighthawk Black
Question Boot struts..
Sorry if this has been brought up before but can someone recommend some new gas struts for my EX with no spoiler etc fed up of hitting my head now.....
Welshivic is offline
post #2 of 23 (permalink) Old 22nd May 2016, 12:20
cheekee's Avatar
Car: Red 2010 1.8 I-Vtec SE-T
These are supposed to be an excellent upgrade.
Honda Civic 2006 Tailgate/Boot Gas Strut - 74820SMGE020M1 6218XQ
cheekee is offline
post #3 of 23 (permalink) Old 22nd May 2016, 14:26
Monstermind's Avatar
Car: 2007 2.2 Type S-GT NHB
Some on here have fitted Merc ML struts from 98-05 model year, they are slightly stiffer than Honda ones and seem to do a better job.
Farqui, Farqui and Farqui like this.
Monstermind is offline
post #4 of 23 (permalink) Old 19th November 2016, 20:11
nturnb's Avatar
Car: 2007 2.2 ES i-cdti, Blue
Thumbs down
I don't know about the Guys on here who've installed these ones but after about 1yr, both of mine are leaking quite badly....
nturnb is offline
post #5 of 23 (permalink) Old 19th November 2016, 20:59
Farqui's Avatar
Car: x'06 2.2 EX FK3 Milano
Eco display Eco display
mine are still going strong pal
Farqui is online now
post #6 of 23 (permalink) Old 19th November 2016, 21:04
nturnb's Avatar
Alright Farqui, mine still work fine but not as they did when purchased ie, almost gave you an uppercut when the boot was opened.. They have started to leak and whatever is leaking out of them is making the paint bubble on the strut body....
Maybe I open my boot more ????
nturnb is offline
post #7 of 23 (permalink) Old 19th November 2016, 21:07
Farqui's Avatar
Maybe. I'm in there a few times a week. Not daily tho.
FYI: mine have been fitted since Aug'15.
post #8 of 23 (permalink) Old 19th November 2016, 21:20
nturnb's Avatar
I think mine were fitted round about the same time as I think quite a few bought them about the same time..... I do use mine daily though....
nturnb is offline
post #9 of 23 (permalink) Old 6th January 2017, 09:50
Apologies for digging up this post but I noticed my struts operate no problem but they have quite a lot of surface rust on them which I thought was odd.
Reckon I should just replace them or if-it-isn't-broken etc?
LongmanFK2 is offline
post #10 of 23 (permalink) Old 6th January 2017, 09:54
Farqui's Avatar
If it ain't broke...
If the rust bothers you, then clean them up and give them a quick spray with satin black/similar.
post #11 of 23 (permalink) Old 6th January 2017, 10:32
atom3624's Avatar
Car: 2.2 i-CTDi EX Civic
In the thread somewhere, I'm certain there's mention that Honda have 2 strengths of strut.
1 is 'the normal' one, for hatches / rear doors without wings, etc.
1 is for CTR, etc., which has extra to lift.
When actual force was quoted, the CTR strength strut was at least as powerful as the Merc ML replacements.
FYI - I replaced with ML ones off Ebay and have some surface rust at the top - not ideal, but might clean and put a smidge of Vaseline on.
Al.
atom3624 is offline
post #12 of 23 (permalink) Old 24th January 2017, 16:00
Car: 2.2 NHB
I find the boot quite heavy, are the struts supposed to open the boot all the way up? Or just about half way then you push the rest?
Argh, nevermind i found another post and got my answer.
Boopolo is offline
post #13 of 23 (permalink) Old 24th January 2017, 16:31
Farqui's Avatar
Good struts should lift the tailgate to max height, sounds like yours are tired.
post #14 of 23 (permalink) Old 24th January 2017, 17:42
I bought some of these
as mentioned about april last year, noticed last week one was leaking. Fair play to struts depot they replaced no questioned asked and even supplying the Merc ones instead. Came with a 3 year guarantee. yet to fit them but hopefully they'll last and work better. my civic has a larger OEM spoiler so it does struggle with the weight.
Farqui likes this.
MattJ is offline
post #15 of 23 (permalink) Old 12th April 2017, 09:43
lwoofy888's Avatar
I have just fitted the merc struts and they send the boot flying up but beware they are pretty stiff to try to shut the boot again so my girlfriend does struggle and pretty much has to use both hands
Farqui likes this.
lwoofy888 is offline
post #16 of 23 (permalink) Old 12th April 2017, 09:46
Farqui's Avatar
It'll be a good work out for her!
The struts ease with use and calm down on the cooler days, so should get easier for her to close, after a while.
post #17 of 23 (permalink) Old 12th April 2017, 12:51
lwoofy888's Avatar
Not too worried since it's my car and i like having it go straight up as I'm fairly tall
post #18 of 23 (permalink) Old 12th April 2017, 12:55
Farqui's Avatar
If you're tall, then hopefully it won't crack you on the chin!
post #19 of 23 (permalink) Old 12th April 2017, 14:04
nturnb's Avatar
Watch that you don't get an uppercut too as my Mrs almost did
Mine are still working but not as effective and they are leaking...
nturnb is offline
post #20 of 23 (permalink) Old 12th April 2017, 14:51
lwoofy888's Avatar
Wouldn't be surprised if I do hit myself when I forget that I've changed them. Sounds like something stupid I would do
  Civinfo > 8th Generation Euro Honda Civic (2006 - 2011) > General Discussion
Human Verification
Boot Struts Arni Wiki Article Discussion 3 4th January 2016 17:44
Bodywork Boot Struts!!! robbo51 Bugs, faults and irritations 61 21st January 2012 15:53
Bodywork Boot Struts ?? robbo51 Bugs, faults and irritations 15 8th May 2008 12:56
