8th Gen ctdi exhaust rasp - Civinfo
 4Likes
  • 1 Post By cosmicma
  • 2 Post By BB-8Fan
  • 1 Post By BB-8Fan
post #1 of 17 (permalink) Old 19th March 2017, 03:09 Thread Starter
Hi new owner & member, I have an 8th Gen 2.2 ctdi Civic with terrible annoying exhaust rasp on engine overun (slowing down/changing gear)
I suspect that the baffles have rotted away inside the rear box as there is no blowing leaks. Anybody had a similar issue please????
BB-8Fan is offline
post #2 of 17 (permalink) Old 19th March 2017, 03:11 Thread Starter
PS there is a thin metal heat shield above the rear box that is hanging off too - do people just remove these?? I'm not sure exactly what the heatshield is protecting - hopefully not the fuel tank.......
BB-8Fan is offline
post #3 of 17 (permalink) Old 19th March 2017, 09:23
Car: 2008 2.2 EX 5dr, silver
I didn't have any issues when I ran the standard exhaust but I did have the heat shield drop down. I used some big washers at first before removing the whole thing when the car was up on a lift and I could see the exhaust wasn't near anything of concern, I'm running a Martellius exhaust though with a tiny back box.
fatwelshboy is offline
Thanks to fatwelshboy from:
post #4 of 17 (permalink) Old 19th March 2017, 09:55
250bhp.... finally :)
musegroove's Avatar
Car: 08 CTR, Milano Red
The heatshields, especially that one above the backbox just rot and can be repaired with big washers as above.
I'm not a fan of removing them but that rear one only looks like it only protects the boot, fuel tank is up front in the R but I'm sure it's the same throughout the MK8 range.
musegroove is online now
Thanks to musegroove from:
post #5 of 17 (permalink) Old 19th March 2017, 11:07
Farqui's Avatar
Car: x'06 2.2 EX FK3 Milano
Eco display Eco display
Nope, i ran a stock zoorst and it never made a rasp.
You could well have a blown baffle, tap the mufflers to check.
Good luck.
Farqui is offline
Thanks to Farqui from:
post #6 of 17 (permalink) Old 19th March 2017, 15:14
cosmicma's Avatar
for the rear heat shield you need a pack of these
AVF M6 Steel Repair Washer, Pack of 10 | Departments | DIY at B&Q
the 2 most rear fixings could do with using 2 washers to sandwich the heat shield between them, i used slightly longer bolts to accommodate the washers the original bolts are quite short
works for me
EDIT..
dunno if anybody else is getting the same but every time i try to post the link i'm getting some double click.net thing added to it making the link useless
what your looking for is these
AVF M6 STEEL REPAIR WASHER, PACK OF 10
just search those in B & Q website
Farqui likes this.
cosmicma is offline
Thanks to cosmicma from:
post #7 of 17 (permalink) Old 19th March 2017, 18:54 Thread Starter
So, I've binned the shield and it is still farting like a goodun on gear changes & overun. The back box actually looks pretty new so I'm beginning to worry of it's the front muffler on the intermediate pipe that's gone. My worry is a garage says it's a certain part then it's not and i"m £120 down & still have the problem.
A one of these national chains that specialise in tyres & exhausts will just say it needs a full system as they're rip off merchants. Not sure what to do...
BB-8Fan is offline
post #8 of 17 (permalink) Old 19th March 2017, 19:09
scaramanga's Avatar
Car: 2.2 ctdi
is it just a little rasp then normal or is it there all the time when you shut off
if its just a little you could look at the air filter most aftermarket ones don't fit correctly and when I had 1 fitted it gave a little rasp when changing gear but was soon cured by fitting genuine part
it does sound like a exhaust rasp when its doing it
scaramanga is offline
Thanks to scaramanga from:
post #9 of 17 (permalink) Old 19th March 2017, 19:13
scaramanga's Avatar
Car: 2.2 ctdi
the fuel tank is under the front seats
as already said remove bolts put big washers on and replace bolts job sorted
or remove if you wish
post #10 of 17 (permalink) Old 19th March 2017, 22:55 Thread Starter
Afraid it is defo something wrong, I test drove another one a week ago and not a peep from the exhaust on overun... And definitely the exhaust mid or rear section causing it...
BB-8Fan is offline
post #11 of 17 (permalink) Old 19th March 2017, 23:39
scaramanga's Avatar
Car: 2.2 ctdi
well go to somewhere that will get it on a lift and allow you to go underneath and listen to it your self
post #12 of 17 (permalink) Old 19th March 2017, 23:42
Farqui's Avatar
If you don't want to pay off an OEM replacement, then pop into an exhaust specialist for an appraisal.
They might be able to sort you out for just a few quid, maybe.
Farqui is offline
post #13 of 17 (permalink) Old 20th March 2017, 01:51 Thread Starter
Ugh, I wish - going to visit a few tomorrow & get it test driven - will see what a few diagnose then take it from there.
Hard to check the mid pipe as it's tucked away under that big tray - pity.
BB-8Fan is offline
post #14 of 17 (permalink) Old 20th March 2017, 21:35
more torque than the mrs
deni.babe's Avatar
what mileage you on? not heard many people having to change their oem exhaust on the dervs even at 150k,the only issues I know are cracked manifolds maybe a large crack is present in yours and this what you can hear, can you smell diesel fumes inside the car.. good luck and let us know.
deni.babe is offline
Thanks to deni.babe from:
post #15 of 17 (permalink) Old 21st March 2017, 16:13 Thread Starter
Right, update: Took it to the garage and it'd not the exhaust - it is induction noise from the air filter area.
I've seen a few with the same problem online so i removed the air box and air resonator to check for cracks etc. Some flyboys remove the resonator so it sounds 'Sporty' (rolls eyes) but it was all still there ok. I wrapped the plastic tube in foam & refitted it in case it was vibrating against the inner wing & it made it go away but it came back as soon as the engine got hot.
I have just ordered a genuine Honda air filter just in case the cheap aftermarket one fitted isnt getting a good air tight seal on the air box.
I will keep you posted.
deni.babe and Farqui like this.
BB-8Fan is offline
post #16 of 17 (permalink) Old 24th March 2017, 16:35 Thread Starter
Ok, all fixed now. It was the aftermarket air filter causing the exhaust blowing type of sound. Fitted a genuine honda one and its perfect.
Farqui likes this.
BB-8Fan is offline
post #17 of 17 (permalink) Old 24th March 2017, 17:19
Farqui's Avatar
Much less hassle using OEM filters, they aren't expensive.
Farqui is offline
  Civinfo > 8th Generation Euro Honda Civic (2006 - 2011) > General Discussion
Human Verification
8th gen or 9th gen Civic - 2nd hand long-term purchase POACHEDEGGS General Discussion 31 28th November 2016 09:37
goodbye 8th gen civic SE hello 9th gen ES newby from Norfolk pdavis44 Introduce yourself 8 19th May 2012 09:17
