Gap on the plastic of the boot door - Civinfo
 6Likes
  • 2 Post By ufoblue
  • 1 Post By Farqui
  • 2 Post By ufoblue
  • 1 Post By dimitri9494
post #1 of 14 (permalink) Old 19th April 2017, 10:10 Thread Starter
dimitri9494's Avatar
Hello,
I have some gap between the plastic and the metal on the boot door...
This is a kind of any pin fail? Should i disassemble the plastic? What is the correct procedure for that?
Picture here: https://ibb.co/ngUtWQ
dimitri9494 is offline
post #2 of 14 (permalink) Old 19th April 2017, 10:15
Harryhonda98's Avatar
Car: 2009 honda civic type s 1.8
Eco display Eco display
Send a message via AIM to Harryhonda98 Send a message via MSN to Harryhonda98
Originally Posted by dimitri9494 View Post
Hello,
All them plastic clips are held together with them plastic pop clips,try giving them a good tap and see if that solves it
Sent from my SM-G920F using Tapatalk
Harryhonda98 is offline
post #3 of 14 (permalink) Old 19th April 2017, 10:33 Thread Starter
It is what I thought on the beginning... I tried to tap the plastic to inside to see if it goes to the proper place but no luck ...
Anyone knows how to disassemble completely this plastic? I am afraid of break it
post #4 of 14 (permalink) Old 19th April 2017, 12:07
Farqui's Avatar
Car: x'06 2.2 EX FK3 Milano
Check the 8th Gen, How To section
Farqui is online now
post #5 of 14 (permalink) Old 19th April 2017, 12:15
jaxckhan's Avatar
make sure you do it on a warm day or a warm garage the plastic can crack if its cold,
jaxckhan is offline
Thanks to jaxckhan from:
post #6 of 14 (permalink) Old 19th April 2017, 21:23
I took mine apart perfectly. Start from the back pop clips. Use a flat screw driver loosen it a bit then use a sponger if you have one. Heres a pic to show you where all the pop clips are located. Once you pull the back pop clips off, then the rest will just comes off easy as you pull it off from the middle. Wiggle it while pulling down on each side
Farqui and xfiniti64 like this.
ufoblue is offline
Thank You to ufoblue from 2 Users:
post #7 of 14 (permalink) Old 20th April 2017, 08:55 Thread Starter
Many many thanks. This is something I want to look at it.
I am seeing there is nothing fixing the plastic on the left/right edges...
post #8 of 14 (permalink) Old 20th April 2017, 10:28
Farqui's Avatar
The left/right corners are held in via the screws within the recessed grab 'handles' but as these corner fixing aren't positioned around the edge so you may get a slight gap there.
deni.babe likes this.
post #9 of 14 (permalink) Old 20th April 2017, 14:25
I took it specially for you
ufoblue is offline
Thanks to ufoblue from:
post #10 of 14 (permalink) Old 20th April 2017, 14:44 Thread Starter
Man you are the best!!!! Many thanks
ufoblue likes this.
post #11 of 14 (permalink) Old 20th April 2017, 15:09
veehexx's Avatar
Car: 2015 CTR FK2
looks the same as the other honda clips - can be got from Car Trim Clips & Fasteners - Trade Prices - Vehicleclips.co.uk at a fraction of the price of the stealer.
veehexx is offline
Thank You to veehexx from 2 Users:
post #12 of 14 (permalink) Old 20th April 2017, 21:04
more torque than the mrs
deni.babe's Avatar
just remember though the plastic panel on the hatch isn't completely flush there are some gaps...
deni.babe is offline
post #13 of 14 (permalink) Old 21st April 2017, 08:54 Thread Starter
So you mean there is expected to have some gaps between the plastic and the door itself?
post #14 of 14 (permalink) Old 21st April 2017, 11:06
deni.babe's Avatar
yes mate mine is the same as yours...
  Civinfo > 8th Generation Euro Honda Civic (2006 - 2011) > General Discussion
Human Verification
Outer Boot Plastic MrLongbeard Styling 9 11th September 2015 13:41
Help removing plastic boot mould worth1g Bugs, faults and irritations 3 20th February 2014 11:04
Boot Plastic Panel Removal? TerryVision Styling 4 21st February 2011 12:35
Bodywork Front door alignment (panel gap) nickb_boy Bugs, faults and irritations 2 13th September 2010 09:31
Scratched the inner boot plastic. Help TH3DOCTOR General Discussion 10 28th February 2010 18:34
