General Torque and Servicing info - Civinfo
 6Likes
  • 6 Post By Gus#1
post #1 of 3 (permalink) Old 18th May 2017, 21:55 Thread Starter
Gus#1's Avatar
Car: 2006 2.2 Type S 3dr, Silver
This was produced for the 2.2 Manual (no DPF) only (although some may apply to other models)
Wheel Nuts – 108 N·m
Changing Transmission Fluid
Fluid Required:
Approx. 2.2L
Up to. 2.5L
Specification - MTL 75W-80 GL4 - Oil Advice
- Recommended - Genuine Honda MTF-3 Manual Transmission Fluid - 'Cox Motor Parts' MTF
- Premium - RED LINE Synthetic Manual Transmission Lubricant MTL 75W-80 GL4 - 'Opie Oils' Red Line MTF
Battery Base (M.8) – 22 N·m
Drain Plug (M.14) – 14mm washer
Transmission Oil Drain Plug – 39 N·m
Fill Plug (M.20) – 20mm washer
Transmission Oil Filler Plug – 44 N·m
Fill level indication (M.10) – 10mm washer (replacement not required)
Changing Engine Oil
Fluid Required:
Approx. 5.5L
+ Filter Change 5.9L
Up to. 6.8L
Specification - 0w-30 Synthetic meeting or exceeding 'ACEA A1/B1' 'ACEA A3/B3' or 'ACEA A5/B5' - Oil Advice
- Recommended - Genuine Honda New Generation Diesel Engine Oil 0W-30 - 'Cox Motor Parts' Diesel Engine Oil 0w-30
- Personal Preference - Castrol Edge Titanium 0w-30 FST A5/B5 Fully Synthetic Car Engine Oil - 'Opie Oils' Castrol 0w-30 A5/B5 Engine Oil
Aluminium maintenance lid (under car) (M.6) – 9.8 N·m
Drain Plug (M.14) –
14mm washer
Engine Oil Sump Drain Plug – 39 N·m
Changing Oil Filter
Oil Filter Assembly – 25 N·m
Oil Filter Removal Tool (required for torquing) - 'Cox Motor Parts' Diesel Oil Filter Removal Tool
This was produced for the 1.8 Manual only (although some may apply to other models)
Changing Transmission Oil
Fluid Required:
Approx. 1.4L
Up to. 1.6L
- Premium - Red Line Synthetic Manual Transmission Lubricant MTL 75W-80 GL4 - 'Opie Oils' Red Line MTF
Changing Engine Oil
Fluid Required:
Approx. 3.5L
+ Filter Change 3.7L
Up to. 4.5L
Specification - '10W-40' or '5W-40' or '0w-40' or '0w-20' or '0w-30' Mineral or Synthetic (recommended) to at least 'API SL grade' - Oil Advice
- Basic (Honda Allows) - Castrol Edge Professional H 0W-20 Fully Synthetic Engine Oil - 'Cox Motor Parts' Castrol 0w-20 Engine Oil
- Recommended - Castrol Edge Titanium 0w-30 FST Fully Synthetic Car Engine Oil - 'Opie Oils' Castrol 0w-30 Engine Oil
Drain Plug (M.14) –
14mm washer
Changing Oil Filter
Oil Filter Assembly – 12 N·m or 3/4 Turn Clockwise
Oil Filter Removal Tool (required for torquing) - 'Cox Motor Parts' Petrol Oil Filter Removal Tool
This was produced for the 1.4 Manual only (although some may apply to other models)
Fluid Required:
Approx. 1.4L
Up to. 1.6L
Changing Engine Oil
Fluid Required:
Approx. 3.4L
+ Filter Change 3.6L
Up to. 4.2L
Drain Plug (M.14) –
14mm washer
Changing Oil Filter
Gus#1 is offline
Thanks to Gus#1 from:
post #2 of 3 (permalink) Old 19th May 2017, 19:57 Thread Starter
Gus#1's Avatar
Hope this helps some people, anyone who disputes any of the information above please comment (want this as accurate as possible) and if anyone has anything to add again please comment!
Thanks,
Gus
Gus#1 is offline
post #3 of 3 (permalink) Old 22nd May 2017, 22:34
The D is for Dave
D_Fizzle's Avatar
Car: 2006 2.2 SE Alabaster Silver
Great info to have, can it be added to the servicing wiki?
D_Fizzle is offline
  Civinfo > 8th Generation Euro Honda Civic (2006 - 2011) > General Discussion
Human Verification
FK2R general info Kk13 9G Type R 1 23rd October 2016 20:26
Servicing Question on Honda servicing in Norwich and in general Jlai928 Buying, Dealers and Servicing 4 11th February 2016 09:05
FN2 Servicing info? Ry_B Type-R 10 29th June 2015 19:26
General Commercial Section info Kremmen General commercial posts 2 11th May 2015 07:06
Servicing General/DIY Servicing Advice RosscoMac Buying, Dealers and Servicing 8 28th September 2013 15:10
