Civinfo TEGIWA Imports
Old 25th June 2010, 18:11   #1 (permalink)
Car: 2008 1.8 ES
Thanks given: 5
Its getting worse!!
I bought a Civic three and a half weeks ago, all was fine for the first week, then the back ache started, in lower area of my back just above waist level.
A week ago I was in agony with it, it got worse every time I drove the car.
I havn't usd the car at all this week (although I have a 120 mile round trip to do tommorow) and I'm feeling a lot better.
Anyone esle had this problem with the seats in The Civic and if so was there a solution?
Regards all
spanish boy is offline   Reply With Quote
Old 25th June 2010, 18:19   #2 (permalink)
Chip's Avatar
Thanks given: 226
I would suggest that it is a coincidence as the seats seem generally O.K. to me. If you have a minor disc problem in your lower back, it can be made worse by sitting for any period. Keep moving and play around with the seat position to get a better compromise. Regular movement breaks are vital on a long drive.
Chip is offline   Reply With Quote
Old 25th June 2010, 21:27   #3 (permalink)
Banned - it's a MrRee
I'm the same ..... not quite in agony, but I can feel my bad back sneaking back!!
It doesn't help that the seats need adjusting all the time - it's hard to get comfortable ... but, sometimes I do (only to undo it when I get access to the rear!).
They look comfortable, but aren't .... my last car was 10 years old and I had it all that time (the seat had moulded to my ample rear end).
BigPete is offline   Reply With Quote
Old 26th June 2010, 07:06   #4 (permalink)
cb550's Avatar
Thanks given: 61
When I had my ES I did find the seats a little uncomfortable for my lower back.The way around it I found,firstly I placed some flat steel washers under the seat rails rear mounting points.This tilted the seat base very slightly more forward which had the effect of spreading body weight a little more to the legs and less to the back.Some cars have adjustment for the seat base.
I also bought some sheepskin seat covers which made sitting in the seats feel like a luxury armchair-expensive but worth every penny to me at the time.
The type S seats I find extremely comfortable-totally different to the ES-but everyone's shape and size are different,so those seats may well be perfect for someone else.
Old 26th June 2010, 09:49   #5 (permalink)
Woette's Avatar
Car: '07 1.8 MR Type-S 63000 km
Thanks given: 90
Eco display Eco display
I find the seats good but if its indeed not properly adjusted i do notice this almost instantanuously. In the beginning i had my upper arms suffering badly on long journeys. After some puzzling i've now found a good position (higher seat + lower steering wheel position).
Dont give up on the civic yet, try lots of different settings.
And on long runs try to let your foot rest (if you have the cruise control) instead of keeping it hovering above the throttle/brake.
Old 26th June 2010, 10:42   #6 (permalink)
Transalp's Avatar
Thanks given: 1
I found out that having my wallet in the back pocket of the trousers was the cause. Since then I really enjoy long rides without any pain.
Transalp is offline   Reply With Quote
Old 26th June 2010, 17:21   #7 (permalink)
That's a good point ref. the wallet ... I have noticed that too.
Old 27th June 2010, 09:30   #8 (permalink)
HappyMan's Avatar
Car: Fiesta 1.6 Zetec S, Black
Thanks given: 492
I find the seats very comfortable but it took me a while to get the seat into the right position when I got the car.
Old 27th June 2010, 17:16   #9 (permalink)
Car: 2008 1.8 ES
Thanks given: 5
Hi all, thanks for the replies
After yesterdays drive......................my back hurts!!
I suffered back problems years ago and thought I'd got rid of them.
I've just had 6 years of Volvo S60's and Saab 9-3's without a problem.
The Mrs got her sewing machine out today and made a "swiss roll" for me, about 18 inches wide and 5 inches in diameter, she made it from the wadding material you have in jackets and covered it with some fabric she had.
Fingers crossed it will work, I will let you know!!
Regards
Old 29th June 2010, 16:15   #10 (permalink)
Car: 2008 1.8 ES
Thanks given: 5
Thumbs up The "swiss roll" worked.
Just done a 240 mile round trip, not a problem!!
The Mrs handywork was a bit cheaper than having to go out and buy a new car.
Regards
Old 29th June 2010, 16:18   #11 (permalink)
HappyMan's Avatar
Thanks given: 492
Regards
Good to hear you have things sorted and well done Mrs Spanish boy for solving the problem
Old 29th June 2010, 16:20   #12 (permalink)
Chip's Avatar
Thanks given: 226
My Mrs is only good at causing pain and anguish not fixing it! Keep her, you sound like you have got a goodun!
Old 29th June 2010, 18:31   #13 (permalink)
gazmdm's Avatar
Car: 09 milano ctr
Thanks given: 30
Regards
Glad to see it's ok now
gazmdm is offline   Reply With Quote
Old 30th June 2010, 13:42   #14 (permalink)
Type Grrrrrrrrrrr
A-Frame's Avatar
Car: 2007 2.0 i-VTEC Type R GT
Thanks given: 11
Hey,
I have a prolapsed disc, been suffering for a couple of years now....However the support I receive from the seats in my CTR have helped alot on my hour drive to work.
Compared to my Astra, its like sitting on a cloud.
Try and keep the seat back straight and your knees slightly bent, when you are not changing gear, bring your clutch leg up all the time at an angle.
A-Frame is offline   Reply With Quote
Old 30th June 2010, 16:46   #15 (permalink)
Jimm's Avatar
Thanks given: 180
I don't have a bad back, but I do find the seat nothing like as good as the Rover 216 SLi I used to have. There was a lumbar support adjuster, and screw back adjuster on there, but I've only got the SE Civic with no lumbar adjustment - so maybe my own fault??
(Come to think of it I don't know if the posher models have a lumbar support adjuster.)
Jimm is offline   Reply With Quote
Old 1st July 2010, 11:58   #16 (permalink)
Car: 2008 1.8 ES
Thanks given: 5
Thanks for the feedback
This is what the Mrs made for me, simple, but its done the trick. I just place it in the right position to support myback. Appologies for the picture, takem with the phone!!
Regards
Old 1st July 2010, 12:53   #17 (permalink)
steve fox's Avatar
Car: 2008 2.2 SE Blueish Silver
Thanks given: 3
My Mrs makes sure there's never enough money in my wallet for it to be any problem!
steve fox is offline   Reply With Quote
Old 1st July 2010, 12:55   #18 (permalink)
ciVinfo resident
edwardwan's Avatar
Car: 1.8 CTS 3dr Vivid Blue Pearl
Thanks given: 18
yes I put a small cushion in the same space and pain gone. Guess my ass is not big enough for the seat to be ergonomic for me :O
edwardwan is offline   Reply With Quote
Similar Threads for: Its getting worse!!
Can it can any worse? CTR_Timmy Type-R 15 27th April 2010 15:04
Radio Radio reception suddenly worse john87 Ipods, MP3 Players and ICE 2 16th April 2010 12:48
Worse Stone Chips - NHB or Milano J_H General Discussion 35 1st January 2009 11:25
£70 worse off, poor cloths and scratches!!! LivesInABox Cleaning 21 3rd June 2008 16:46
