Drove car with no oil cap - Civinfo
post #1 of 19 (permalink) Old 5th July 2010, 09:12 Thread Starter
My oil warning light came on on Saturday and I topped up engine oil. I must have forgot to replace cap, I have now driven to work (approx 60 miles). The oil warning light came on about half way, when I opened up the hood there was oil everywhere, there is now nothing left when i check using dipstick. The car was driving ok, If i fill it up with oil will car be ok to drive?? Or does it need to go to a garage??
Any help appreciated
Kaiser
Kaiser is offline
post #2 of 19 (permalink) Old 5th July 2010, 10:02
Wine and cooking !
l-noel's Avatar
Car: 2008, Grey Mica 1.5 Materia
I had the same problem two years ago, I didn't fix the oil cap correctly and I lost it during travel. I've done about 20 km when the oil warning went on, I stopped, found the disaster under the bonnet (about the 2/3rd of the oil was lost). To found an oil cap a 14th of July in France was impossible. So I cover the hole with rags and I found a "replacement cap" by using a candy box cover... I do stop every 100 km to check the oil level and the replacement cap. I did drive like that during two weeks before to receive the correct replacement cap.
I've ask my dealer if there was a problem with the oil lost for the engine, and he tell me not to worry about because the loss was not enough to create problems.
Did you check your oil level immediately or did you wait for 1 or two minutes before checking ?
In all case I will take my car back to the garage and ask them to look at it (cleaning the motor is important because the oil can damage various belt or electrical connections)...
But first of all do the topping up again (I'm sure you did it immediately)
I Wish you good luck.
l-noel is offline
post #3 of 19 (permalink) Old 5th July 2010, 10:34 Thread Starter
Cheers mate. I had to go to honda for a replacement cap (£17 - nearly fell over). I topped up the oil, but it was completely empty before hand. Turned the engine over, no funny noises etc. Might have got oil in just in time. No warning lights are coming on either. I will take it a run later on see if its ok
Kaiser
Kaiser is offline
post #4 of 19 (permalink) Old 5th July 2010, 10:46
coste1l's Avatar
how much oil did you have to put in?
coste1l is offline
post #5 of 19 (permalink) Old 5th July 2010, 12:17 Thread Starter
Just under 3 litres
Kaiser is offline
post #6 of 19 (permalink) Old 5th July 2010, 12:22
coste1l's Avatar
what do they hold empty to full?
coste1l is offline
post #7 of 19 (permalink) Old 5th July 2010, 12:33 Thread Starter
I dont actually know. When I check the oil levelo now it just below the upper hole on the dipstick, so I am assuming it must hold around 3 litres
Kaiser is offline
post #8 of 19 (permalink) Old 5th July 2010, 12:39
coste1l's Avatar
ok, so what it holds minus what you put in his how low it got it was a very short journey tho?
coste1l is offline
post #9 of 19 (permalink) Old 5th July 2010, 12:41 Thread Starter
I must have drove around 60 miles with no oil cap, with warning light coming on around halfway
Kaiser is offline
post #10 of 19 (permalink) Old 5th July 2010, 13:43
Alanok's Avatar
Car: 2008 CTR, Alabaster Silver
Send a message via MSN to Alanok
If it's like the EP3 then it's about 4.5 ltrs. I used to pour in 5 ltr tubs and have a bit left over when I did my own servicing.
Alanok is offline
post #11 of 19 (permalink) Old 5th July 2010, 13:47
coste1l's Avatar
i cant see it doing damage tbh, did the temperature gauge rise much?
coste1l is offline
post #12 of 19 (permalink) Old 5th July 2010, 15:44 Thread Starter
I didnt notice to be honest. I've since taken it a run for about 25 mins. No funny noises etc. Seems to be OK. Think ive been quite lucky.
Kaiser
Kaiser is offline
post #13 of 19 (permalink) Old 5th July 2010, 19:08
coste1l's Avatar
i think so too!
coste1l is offline
post #14 of 19 (permalink) Old 5th July 2010, 21:08
Kids use a lot of space
MC Hammer's Avatar
So you drove for 30 miles with the oil light on?
Oil low level warning or no pressure?
If it was the latter then there will be damage for sure, however given the tight tolerances you will appear to get away with it. The downside will be to engine life being shortened.
If it was just low level, then it'll probably be fine.
MC Hammer is offline
post #15 of 19 (permalink) Old 5th July 2010, 22:09
Cockup Specialist
Relic's Avatar
I do beleive it holds nearly 6 litres in the 2.2.
But I haven't chnaged the oil personally..
...no doubt someone here has
Technical Specifications - Civinfo Wiki
..ther you go ..under engine oil
Relic is offline
post #16 of 19 (permalink) Old 7th July 2010, 11:02 Thread Starter
At the time I thought it was the low level warning, but when I seen what I had done I was then unsure.
I've been driving it a few days now and done over 100 miles, there seems to be no problem. Fingers croossed it stays that way.
Thanks for the answers/help from everyone
Kaiser
Kaiser is offline
post #17 of 19 (permalink) Old 8th July 2010, 13:22
Wine and cooking !
l-noel's Avatar
By the amount of oil you put in, there was still enough oil to do the job. So I'm sure you will not have any problems. It's always very disturbing when you have the oil warning coming up when you've just done the topping.
l-noel is offline
post #18 of 19 (permalink) Old 8th July 2010, 13:32
Car: FN2 NHB GT & 89' CRX 16V
Ive done this before and known cars driven on empty in nearly all cases fill up clean up and forget about it.
froggy is offline
post #19 of 19 (permalink) Old 8th July 2010, 22:33
Ell
Car: 2010 Type R GT, Milano Red
I did exactly the same however I reckon I drove for WEEKS without the oil cap on!
No oil warning light came on and the cap was still in the same place under the bonnet as when I shut the bonnet when I lifted it up weeks later. The oil was also still 3/4 full, so a little top up and put the cap back on.
Also no mess under the bonnet, car drove fine during, has been fine since and never got hot or anything....
Ell is offline
  Civinfo > 8th Generation Euro Honda Civic (2006 - 2011) > General Discussion
Human Verification
I test drove the Peugeot RCZ gadgetman68 Any non Civic chat here please! 24 29th June 2010 15:48
Test drove the 2010 Stef Honda CR-V 8 3rd March 2010 20:27
finally!! drove one...!! Brummer Type-R 1 9th March 2007 21:41
Drove one today! HOW FUN! DanKo Type-R 5 6th March 2007 00:47
Drove the old one.. pikkumies Type-R 1 25th February 2007 23:17
