This thread is about: driving with lights on, it's in General Discussion at the Honda Civic forum Civinfo; I agree with you Dan, good point made to me by a Police driver on a course too, when the wipers are on so should ...
Old 20th July 2007, 07:36   #81 (permalink)
Smell My Cheese!
richierich's Avatar
I agree with you Dan, good point made to me by a Police driver on a course too, when the wipers are on so should the headlights.
But not using headlights is still not as annoying as those people who choose to use sidelights and foglamps, you know who you are! I have seen a couple of Civics doing this. Although I have used my fog lamps once when no fog, trying to get out of a really dark car park, just could not see the kerbs near to the corners, fog lamps helped then.
Old 20th July 2007, 07:46   #82 (permalink)
GHGH's Avatar
I've said this before: A problem rises when some drivers choose to use DRL, rendering the rest less visible.
In Norway DRLs has been legislated more than 20 years. I remember I got very quickly hard wired to expecting meeting cars to have lights, and dangerously failing to see those without.
Old 20th July 2007, 10:16   #83 (permalink)
Blaven's Avatar
Fog lights
I do not agree that front fog lights blind oncoming traffic as I have never had an occasion [in 30+ years of driving] to think that I was being blinded or even distracted by someones fog lights at night. Obviously rear ones do blind a bit but it is a design problem-manufacturers just need to make it more visible on the dash that they are on or have a chime/beep every 5 or 10 mins to remind drivers they are still on
Blaven is offline   Reply With Quote
Old 20th July 2007, 13:48   #84 (permalink)
Nifty with fish
sushi_chef's Avatar
The Highway Codes take on this is interesting...
The first line of point 93 really shocked me though!!
93: You MUST
  • use headlights at night, except on restricted roads (those with street lights not more than 185 metres (600 feet) apart and which are generally subject to a speed limit of 30 mph)
  • use headlights when visibility is seriously reduced (see Rule 201).
  • ensure all sidelights and rear registration plate lights are lit at night.
    Laws RVLR regs 24 & 25 & RV(R&L)R reg 19
94: You MUST NOT
  • use any lights in a way which would dazzle or cause discomfort to other road users
  • use front or rear fog lights unless visibility is seriously reduced. You MUST switch them off when visibility improves to avoid dazzling other road users.
    Law RVLR reg 27
95: You should also
  • use dipped headlights, or dim-dip if fitted, at night in built-up areas and in dull daytime weather, to ensure that you can be seen
  • keep your headlights dipped when overtaking until you are level with the other vehicle and then change to main beam if necessary, unless this would dazzle oncoming traffic
  • slow down, and if necessary stop, if you are dazzled by oncoming headlights.
http://www.highwaycode.gov.uk/08.htm#93
SS
sushi_chef is offline   Reply With Quote
Old 23rd July 2007, 11:02   #85 (permalink)
Charles_Harding's Avatar
93: You MUST
I think that they are referring to Main Beam headlights there!
"Marriage is a punishment for shop lifting in some countries!"
Charles H.
Old 23rd July 2007, 11:10   #86 (permalink)
The first line of 93 doesn't say main beam, it just says "headlights". But luckily I would consider darkness as a serious reduction in visibility, so the next line has it covered.
Old 23rd July 2007, 11:16   #87 (permalink)
But isn't the point that with street lights that close together, visibility wouldn't be reduced?
Old 23rd July 2007, 21:28   #88 (permalink)
12th June 2006 1.8EX
WoolyCiv's Avatar
It's all designed to allow you to be pulled over whenever the polce want to.
Its a strange thing when the highway code is quoted as I remember in the dim and distant past when I was learning to drive being told that the highway code as its name implies is a code of conduct, it is not the law.
Similar Threads for: driving with lights on
Black What a glorious day for driving. The Phantom Gallery 10 11th September 2007 23:20
MPG Economy driving Tony Fendall Engines and Transmission 27 12th July 2007 10:45
HID Xenon lights and driving on the continent GlenMH Lights 24 28th April 2007 10:42
driving in europe brinor Introduce yourself 5 6th April 2007 10:27
MPG ECO-driving pikkumies Bugs, faults and irritations 2 5th August 2006 19:39
