This thread is about: Roof Rack photo's, it's in General Discussion at the Honda Civic forum Civinfo; No, the Thule rapid fit system doesn't require you to do any of that. The kit itself when coupled with the footpack sits on the ...
Old 8th November 2006, 16:03   #21 (permalink)
jayt43's Avatar
No, the Thule rapid fit system doesn't require you to do any of that. The kit itself when coupled with the footpack sits on the edge of the roof near to the door sills. So, it'll be exactly the same installation process as with your Alfa 156, Great Soprendo.
Honda's roof rack uses the bolts under the trim (see TT's photo) and is therefore attached in a completely different way. So, in a nutshell, it has nothing to do with how Thule the system works!
jayt43 is offline   Reply With Quote
Old 8th November 2006, 17:22   #22 (permalink)
The Great Soprendo's Avatar
Thanks for clearing that up - very glad to hear it - though on the Alfa, the Thule footpack does 'interact' with the manufacturers fittings for the roof rack (it's a kind of bolt under the rubber around the door which the footpack hooks over).
The Great Soprendo is offline   Reply With Quote
Old 13th May 2007, 15:21   #23 (permalink)
johnny's Avatar
Smile Roof rack
Hi
I have a question about the photo's you placed on Civicinfo. With the lease i ordered the exact same roof bars.
My question is the following, cause i am new to this i don't know if you can fit any roof rack or that you got to have an orginal honda accessoire. I believe mine are suitable for 30 kilograms.
I am planning my summer holiday in Engeland in a month so i would like to know what i have to arrange.
Thnx for any reply's
Johnny
from Holland
johnny is offline   Reply With Quote
Old 26th July 2007, 19:01   #24 (permalink)
Roof Bars
I need a rack for my S type and Thule dont seem to know when/if they will produce one, so it looks like it will have to be the official Honda one.
Anyone know how the dealers cut the roof strip to access the fitting bolts? Remove the whole roof strip from the car to cut it, then refit, or do they somehow cut it in situ?
Ninjaboy is offline   Reply With Quote
Old 26th July 2007, 19:42   #25 (permalink)
Tomthumb's Avatar
They took the strips off cut them and put them back on when they did mine.
Tomthumb is offline   Reply With Quote
Old 26th July 2007, 21:50   #26 (permalink)
P@tje's Avatar
Well I fitted the same Honda roof rack some weeks ago. It took me 4 hours to remove the 2 trims and mount the roof rack. At the front window they were difficult to take loose without damaging some plastic placeholders that are under the trims. And of course you need a plastic screwdriver. With metal, you can hurt the glass!!
So I made a tool from a peace of wood.
The roof rack / or bars are very nice and of great quality.
I also heard that for Thule roof boxes, you will need another U-shaped clamps. The original ones seems to be to short. So that's indead true.
I have a Probox / Hapro roofbox and this one fits well.
Old 26th July 2007, 21:55   #27 (permalink)
P@tje's Avatar
Yes they remove the whole strip and cut it into 3 peaces. I did it myself, as told above.
After the summer holiday I will remove the rack. Then I can see if water didn't find it's way under the rubber feets. I also hope that the 4 plastic caps will do their job well and keep water out of the roof gutter
Old 1st August 2007, 21:35   #28 (permalink)
fergus73's Avatar
I bought the Roof bars From my Honda Dealer for £162.68.
I fitted them myself onto my Type S GT in just over Half an hour.
You don't need to remove the whole strip if you start from the back i just put a towel over the glass and cut the strip in situ.It was really easy.You can get the strip off using a credit card and your fingers.
On the bits of trim that you throw away I removed the White plastic clips and have kept them as spares(just in case).
I think the plastic covers are pretty cheap and nasty and will break easily.I told the dealer this and he ordered me a spare set and gave me them for free.
fergus73 is offline   Reply With Quote
Old 2nd August 2007, 02:23   #29 (permalink)
druidh's Avatar
Thanks for the photos. That's helped make up my mind about Honda vs Thule rack.
Off to order the Thule one now!
druidh is offline   Reply With Quote
Old 2nd August 2007, 07:46   #30 (permalink)
P@tje's Avatar
well I thought about that, but I didn't dare it. To afraid of hurting the car with the ironsaw.....
Old 13th August 2007, 13:49   #31 (permalink)
Just take care with the Honda supplied straps that incearse the load acrrying capacity.. I have recxently used them and when i took them off on Saturday i found they had deformed the door frames!
proto is offline   Reply With Quote
Old 16th August 2007, 21:30   #32 (permalink)
I've got Thule roof bars specifically for the civic.
More than happy with them.
Take them on and off quickly and generally use them to transport ladders.
They were cheaper than the Honda bars and looking at the Honda bar photos earlier on this thread, I'm glad I chose Thule aerobars.
There is no cutting into the roof, once removed it's back to how it was when I bought it.
Got the bars in May and have put them on and taken them off about 5 times since then.
I would definitely recomend the Thule one's. Got them from a company called Snow chains of Europe on the net. (At least I think that was the name, should come up via Google). The bars and fitting kit and delivery was £129.00.
Redciv is offline   Reply With Quote
Old 19th August 2007, 21:53   #33 (permalink)
P@tje's Avatar
Well I took mine off last yesterday. No problems at all. Just a case of not to tighten the screws. Tight is Tight as we say overhere.
Now I hope that with the 4 plastic covers the strips will last long and waterproof. That's the only thing I worry about for the future (and that the covers will be re-usable after dismounting them next sommer if I need the roof rack again....
Old 22nd August 2007, 21:46   #34 (permalink)
Does your Civic have a glass roof?
gillw is offline   Reply With Quote
Old 26th August 2007, 11:07   #35 (permalink)
No, my civic does NOT have a glass roof (if that helps ?)
Old 3rd April 2008, 09:02   #36 (permalink)
barry roubaix's Avatar
Can anyone confirm the dimensions of the roof bars?
I'm hoping to get the honda roof bars and then fit some Thule Bike Racks to the bars.
I guess they should fit but further info would be nice.
barry roubaix is offline   Reply With Quote
Old 3rd July 2008, 18:19   #37 (permalink)
roof rack
Hi Guys,
Can you advise me what are the part numbers for the thule rack? footers, bars
I need it for me FN2.
Thanks!
Chris
j241 is offline   Reply With Quote
Old 3rd July 2008, 18:44   #38 (permalink)
Type R GT 09570
Originally Posted by j241 View Post
Hi Guys,
Thanks!
Chris
Try posting this in one of the dealers forums on here
Commercial - Civinfo
Old 3rd July 2008, 19:50   #39 (permalink)
Any chance of a photo of the Thule rack in place? I had one for my previous cars (Carina, Corolla and Accord) so I'm happy with the quality, but I would like to see how it fits on the Civic's awkward roof. Thanks.
pjg50 is online now   Reply With Quote
Similar Threads for: Roof Rack photo's
Roof Rack jp100pro Type-R 1 3rd September 2007 15:11
Satnav photo's TFL Electronics 13 30th April 2007 16:05
Dog guard / Snowboard rack gavk83 General Discussion 3 12th February 2007 21:11
Centre Console - CD Rack richierich General Discussion 9 9th October 2006 10:00
Options Roof Bars Ancient Nerd Buying, Dealers and Servicing 13 28th July 2006 18:22
