![]() Car: 2.2 lrd tuned Black
serviced my 2.2
And must admit it was one of the easiest services ever, oil filter fuel filter air filter and pollen filter.
Gotta go on an airport run tonight so will be interesting to see if i get improved mpg now its all fresh and clean inside |
![]() Car: 08 2.2 nhb type s gt
Thanks given: 135
taught the fuel filter is a bitch to change,my nearest honda dealer charges an extra €90euro to change the fuel filter as they reckon its such a hard job
loads of grunt
![]() Car: 08 2.2 type s gt blsilverish
Thanks given: 220
fuel filter is at least 40 mins to change maybe anything under an hour is classed as easy? and imo is not for the faint hearted.
remove the battery and air filter which made changing the air filter even easier, then had the fuel filter out in no time.
hardest part was unscrewing the filter as it was tightened quote a bit. pollen filter was really easy too cant believe dealership was going to charge me £400! |
under the hand brake??
the fuel filter on the 2.2 is under the air box i undid the electrical connectors, removed the 12mm bolt holding the carrier to the engine bay, undid the hoses took the carrier out then undid the other 12mm bolts once it was out, refitting was just the reverse, and like i say while the air box was out i just refitted the new filter and bish bash bosh job done! access to the oil filter was much better than other civics ive owned in the past, and made it a doddle. |
Clingfilmed
![]() Car: 2008 2.2 CTS GT
Thanks given: 827
Civic Type R FN2 Fuel Filter / Pump Replacement
This one, which is on the FN2 but has a certain level of infamy! Can't see why a dealer would charge so much more for the one in the engine as looks easy enough? |
ah sorry just all the other posters have 2.2's...
the only other fuel filter ive done before was on a mates renault and it was a nightmare compared to the civic. gotta admit my engine feels a bit more free now with the fresh oil. |
#11 (permalink) | |
Clingfilmed
Thanks given: 827
Similar Threads for: serviced my 2.2
| Servicing When should I get my car serviced? | adammole | Buying, Dealers and Servicing | 12 | 31st July 2011 12:15 |
| Servicing Anyone serviced their car themselves? | vickesh | Buying, Dealers and Servicing | 14 | 28th January 2011 20:19 |
| Warranty do I have to get it serviced at dealers | kevin m | Buying, Dealers and Servicing | 2 | 25th July 2009 10:14 |
| Servicing Car only serviced once at 24,000miles :( | iamholam | Buying, Dealers and Servicing | 13 | 26th November 2008 01:41 |
| Servicing Just serviced == goes like a rocket! | eighteentee | Engines and Transmission | 25 | 5th October 2008 10:43 |
