Civinfo TEGIWA Imports
Old 3rd October 2012, 23:17   #1 (permalink)
Car: 2009, CTR, Milano Red
Thanks given: 1
"Check System" after not using car 15 days?
Hi guys
CTR, 2009, has been running fine.
I left the car at an airport car park for 15 days. So it's been unused for over 2 weeks. (I kept keys).
When I returned and started the engine, I got the message "check system" and the engine management light is on.
Any ideas? Used car twice since, light still on.
StenR is offline   Reply With Quote
Old 3rd October 2012, 23:19   #2 (permalink)
Type EX,A guy called Mark
markvirgo's Avatar
Car: 2006 1.8, Alabaster Silver
Thanks given: 95
Faulty Battery?
Can you read the codes?
markvirgo is online now   Reply With Quote
Old 3rd October 2012, 23:24   #3 (permalink)
"Grandad eye"
stevey_p7's Avatar
Car: 2007 1.8L CTS Silver
Thanks given: 504
Disconnect then reconnect the battery. See if its still there after that.
stevey_p7 is offline   Reply With Quote
Old 4th October 2012, 00:03   #4 (permalink)
Thanks given: 1
How do I read the codes?
How do I disconnect battery?
Sorry I'm a bit clueless here.
Old 4th October 2012, 00:10   #5 (permalink)
markvirgo's Avatar
Thanks given: 95
To disconnect battery, open bonnet and using a 10mm spanner or socket loosen the black - clamp on the battery, lift of the clamp. Leave it off for 30 minutes. reconnect and start the car.
To read the codes you need access to a code reader
Old 4th October 2012, 00:31   #6 (permalink)
Thanks given: 1
Perfect.
Thanks guys.
Will report back.
Old 4th October 2012, 00:44   #7 (permalink)
"Grandad eye"
stevey_p7's Avatar
Thanks given: 504
Yeah disconnect the positive and negative then leave it for a bit. I just use an adjustable spanner to loosen them clamps and lift them off the battery.
That should hopefully sort the problem.
If its still there once you've reconnected and started the car up, best off doin a diagnostic check either at your local Honda or if your Breakdown cover has Honda Specialist callout vans then ask them. Think AA have Honda special vehicles. I know RACs is VW.
Old 4th October 2012, 13:09   #8 (permalink)
Thanks given: 1
Light went off after the misses went to work with the car this morning.
Thanks for help anyway. Will try the above if it happens again!
Old 4th October 2012, 21:20   #9 (permalink)
"Grandad eye"
stevey_p7's Avatar
Thanks given: 504
No problem. Theres a Check System thats came up for me and it's something to do with the car thinking its been over fuelled.
The Check System then disappears after a good run and starting the car back up again.
Similar Threads for: "Check System" after not using car 15 days?
Indications "Check System" Warning lights on dash Beck Engines and Transmission 6 28th February 2012 16:16
Faults "Check system" and Glow light flashing Roosterrs Engines and Transmission 4 25th March 2011 14:34
Indications "Check System (Engine)" light on nelster Engines and Transmission 9 22nd September 2009 09:40
Engine "Check System" message came on Hartside Bugs, faults and irritations 13 9th June 2007 16:19
Satnav "No DVD Disc Installed. Please Check System." Error message BobTheLoveGoat Electronics 2 30th March 2007 20:28
