![]() Car: 2006 1.8 5 door, Cosmic grey
Thanks given: 7
Remote screw rounded - how to remove it?
I'm trying to change out the battery in my remote. The previous owner ganked up the screw so badly that the screw is toast, the pattern is no longer a phillips head.
I've tried the key cutting shop, but they also couldn't remove it. Will I have to carefully drill it out? Any other options? Where do I get the replacement screw from? I'd happily get the new casing off eBay as mine's a bit shabby anyway but don't want to pay for cutting the blade. Any advice greatly appreciated. |
![]() Car: 2007 1.8 5 door
Thanks given: 61
Could cut a slit in the screw with a dremmal then use a thin slotted screwdriver but you would probably nick the plastic casing. Might be easier to buy a new housing and 'carefully destroy' your current one to get the innards out.
Sent from my HTC Sensation Z710e using Tapatalk 2 Last edited by Hullcivic1986; 28th October 2012 at 19:08. |
![]() Car: 2.2, HHB- 07
Thanks given: 86
I have the same problem . Stupid previous owner not looked after this amazing car and also the bloody key! Rounded completely like some just took nail and tried to screw it tighter. Muppet, never the less its my problem now and i shall take care of it
Most Active Australian
![]() Car: 2010 Black Civic Si FK2
Thanks given: 67
I got my screw out with those precision screw drivers and using force while turning.
also pliers, when the head gets out a bit use them to remove it with the pliers and not the screw driver. |
#9 (permalink) | |
Thanks given: 7
link |
#15 (permalink) | |
Clingfilmed
![]() Car: 2008 2.2 CTS GT
Thanks given: 827
And then when you need the "original" key as the spare gets lost or the battery dies...? |
Similar Threads for: Remote screw rounded - how to remove it?
| Screw in key | Grayfox | General Discussion | 4 | 5th March 2012 09:18 |
| Electrics Remote Locking Not Working ... Remote unlock works fine?!?!? | Winterwolf | Electronics | 6 | 17th August 2010 19:10 |
| Screw Covers | foxzbury | General Discussion | 2 | 19th September 2009 21:16 |
| Need a screw! | generationgav | Bassetts Honda | 0 | 28th April 2009 16:48 |
| That small screw is a little B****R | pistol86 | General Discussion | 13 | 22nd September 2008 07:48 |
