| This thread is about: brodit mount installation help, it's in General Discussion at the Honda Civic forum Civinfo; I have recently got the brodit mount for the civic. Its the one that sits to the left of the gearstick. I also bought a ... | ||
I have recently got the brodit mount for the civic. Its the one that sits to the left of the gearstick. I also bought a brodit attachment to hold my iphone in.
Does anyone know how im meant to fix the iphone holder to the actual mount. Cause i cant believe im meant to drill and screw into the actual plastic mount? |
Yes, as standard you are supposed to drill and fix the mount to the proclip. You should have been supplied some screws with the kit for exactly that purpose.
However they also do something called a MoveClip which allows the mount to be removed more easily: Brodit Mini Move Clip |
Not sure what's wrong attaching the pics :
ImageShack - Hosting :: image146ii4.jpg ImageShack - Hosting :: image145fh9.jpg |
No need to drill, they screws are self tapping and screw into the plastic without any problems. Not sure why this should be a problem?
That's my TrafficMaster Q-Busta
TrafficMaster Q-Busta When in range of a Tm beacon it either lights up red or green depending on traffic conditions, in conjunction with spoken alerts as to traffic conditions on major roads (covered by Tm) up to 10 miles ahead and covered side roads. Example: "You are on the M25, junction 12, clockwise, M25 clockwise, slow traffic for 4 miles between junctions 15 and 17, expect 20 minutes delay, A30, M4, M40, traffic flowing freely" The Q-Busta, unlike the old Freeway boxes is a subscription for life - no annual fees. UK only I suspect thought so not a lot of use for you. |
#10 (permalink) | |
I picked this info off the Brodit.com site. No mention of drilling any holes
653733 ProClip ![]() The ProClip is a mounting bracket for the vehicle´s dashboard. Onto the Proclip you can install e.g. a holder for your mobile phone or PDA or a handsfree set etc. Safe and convenient -always within easy reach. The ProClip is car specific and easy to install. The installation is quick, no special tools or dismantle of the dashboard is required and it will not damage the interior of the vehicle. Made in black ABS plastic. Comes with detailed instructions. Item no. 653733 fits: Honda Civic 06-08 For all countries Tell a friend Print You install the product like this... 1. 2. 3. 4. Please read all of the instructions and look at the pictures before attaching the ProClip. 1. Press the thin end of the enclosed gap opener into the gap between the console and the panel surrounding the gear shift, to widen the gap. Use the enclosed alcohol pad to clean the surface where the ProClip is to be installed. Peel off the adhesive tape covers on the ProClip. 2. Press the angled edge on the upper part of the ProClip into the gap between the frame surrounding the control panel and the dashboard. Flip the ProClip downwards so the angled upper edge hooks behind the frame surrounding the control panel. 3. Press the lower part of the ProClip into the gap next to the gap opener. Pull out the gap opener. 4. The ProClip is in place. < Back |
| FS: Brand new Brodit phone holder for 06 Civic onwards | Dream Weaver | For sale and Wanted | 6 | 22nd May 2008 11:46 |
| Mounts Brodit Pro Clip? | tonyt | Electronics | 9 | 3rd March 2007 08:57 |
| Mounts Sat Nav - vent mount for Garmin Nuvi? | lhirst | Electronics | 2 | 12th January 2007 00:28 |
| Mounts Where to buy Brodit products in Finland? | Jani | Electronics | 5 | 10th December 2006 12:18 |
| Can't think where I could mount it | Maldax | Any non Civic chat here please! | 0 | 11th July 2006 19:41 |
