| This thread is about: Handbrake failure compensation, it's in General Discussion at the Honda Civic forum Civinfo; I think it would be difficult to prove the handbrake was at fault. Of the few that have failed there was never any evidence of ... | ||
#21 (permalink) |
I think it would be difficult to prove the handbrake was at fault. Of the few that have failed there was never any evidence of fault when they were examined. Unless someone can produce some damning independent evidence no court case will float.
#24 (permalink) | |
Perfect Guy!
It is not an Idea it is the highway Code!!! If you park on a hill and do not leave your car in gear (as well as applying the handbrake) and your car rolls ( be it a civic or a BMW 5 series) I would of thought that the police would be wanting a word ( o.k the handbrake should not fail but if it does the gears should still hold the car) same with an insurance company if someone's hanndbrake fails and the car rolls and causes damage to the car - do you think the insurance company is going to pay out if you have broken the highway code by not having the car in gear aswell ? CZ would I be right in that assumption ??? |
#25 (permalink) | |
Type R GT 09570
The point is we shouldn't have to do this, we are being told to do it because of a fault with an essential part of the car. The fact that a certain persons hasn't faulted doesn't mean it won't. Honda have obviously identified a design or manufacturing fault and feel it is important to address it, if not immediately rectify it. I'm sure it's not a decision they have taken lightly. It is potentially a very serious fault. I am not lecturing you because I know you have the same opinion as me, but I have tried telling this to Mr Honda this afternoon and it's like banging my head against a brick wall. You know who I mean!!! |
#26 (permalink) | |
Perfect Guy!
I think the authorities will take a dim view of the handbrake failure but they will also look into why the highway code was not adheard to There is no defence to that |
#27 (permalink) |
Very few parts of the HW code are legal requirements. Those marked as must are legislated for. The rest are guidelines.
If someone claimed the handbrake had failed and caused an RTC the vehicle would be examined independently either through the Police or by the insurance company. |
#28 (permalink) | |
Perfect Guy!
#30 (permalink) | |
Perfect Guy!
Surely the insurance companies would take a dim view of this though ? |
#32 (permalink) | |
I don't think either of the recommendation's are compulsory in law just recommendations. |
#33 (permalink) | |
Not in the same way you could be prosecuted for having headlights out brake lights etc out. The insurance company may well not like it, but I'm not entirely sure they could use it to avoid a claim. |
#34 (permalink) |
Further to what I said earlier here is the introduction to the code, lifted from the book itself...
Many of the rules of the highway code are legal requirements, and if you disobey these rules you are committing a criminal offence. You may be fined, given penalty points on your licence or disqualified from driving. In the most serious cases you may be sent to prison. Such rules are identified by the use of the words MUST/MUST NOT. Although failire to comply with the other rules of the code will not, in itself, cause a person to be prosecuted, the Highway code may be used in evidence in any court proceedings under the Traffic Legislastion to establish liability. Rule 226. Parking on hills. If you park on a hill you should (not must)... - Park close to the kerb and apply the handbrake firmly - Select a forward hear and turn your steering wheel away from the kerb when facing uphill - Select reverse gear and turn your steering wheel away from the kerb when facing downhill - Use 'park' if your car has an automatic gearbox So while suggested, it is not a must and so not an offence you can be prosecuted for. Although as Broders suggested it may be something that can be used to establish liability. |
#35 (permalink) | |
Type R GT 09570
#38 (permalink) | ||
When we use the car, we are obliged to operate it in accordance with the manual. So lets have a quick look at it...
How to put the brake on: Quote:
Parking: Quote:
The parking brake is as likely to hold the car on the hill as the engine is to power you down the road. It should do and it probably will do, but it might not. So it's best to think of what may happen when there is a single point of failure. Especially when it's a single string powered notoriously unreliable device such as this. Very sadly, I suspect that this may lead to a new placard fitted to the dash on all cars from all manufacturers (the parking brake is essentially the same in all cars) stating something like "When parked, leave in gear". |
#40 (permalink) |
Type R GT 09570
I don't suppose you have Rage's fitted though. There is no margin for error with these wheels as the rim is level with the tyre sidewall and the sidewall itself is only three inches high. It would be very easy to over do it and hit the kerb. Whilst I am not denying it is good practice, it is something I choose not to do.
| Handbrake To All Members Of Civinfo!!! Handbrake failure? | Brodick | Bugs, faults and irritations | 173 | |
