Go Back   Civinfo > All Civics > Group Buys
Old 16th November 2010, 23:26   #1 (permalink)
Davek's Avatar
Car: 2007 CTR GT in Milano
Thanks given: 32
HKS Brakeline Kits - £60 Delivered
Hey people
Been offered another group buy opportunity on the HKS stainless brakeline kits from Caroline at Sumopower.
I would highly recommend uprated brakelines & fluid, they totally transform the braking and are a must on the type R as the OEM brakes are poor at best & with winter setting in you want to ensure your brakes are at there best to suit all conditions you may face.
This is a limited period only offer as HKS are raising all there prices as of 1st December so all purchases must be done before the 30th November!
The kits are the 6 line kits and usually retail at £70.50 + Delivery...they are offering them to Civinfo members at the reduced rate of £60 delivered!
All lines will be dispatched to those that have paid up on the 1st December.
They can also offer bottles of Motul RBF600 Brake fluid 500ml for £12.75 per bottle and no extra postage when brought in conjunction with the brakelines.
If your interested then call Caroline on 01797 222281 and quote your "User Name", "Davek" & "Civinfo" and they can get it sent straight out.
Any questions then feel free to ask and I'll get in touch with Caroline or you can always ring yourselves on the number above.
Grab a saving whilst its still available!
Davek is offline   Reply With Quote
Thanks to Davek from:
Old 16th November 2010, 23:30   #2 (permalink)
Davek's Avatar
Thanks given: 32
Abit more info from HKS....
HKS BRAKE LINE KIT * NEW RELEASE *
The HKS Stainless steel brake hoses are designed to overcome the issues commonly found with stock hoses . Most stock hoses are rubber which has a limited shelf life and many service manuals will designate that rubber hoses should be replaced approximately every 4 years . Rubber perishes overtime due to constant expansion and contraction through the cycle of braking . This can lead to areas becoming brittle ,cracking or punctured .Another drawback with using rubber hoses on the braking system of any vehicle is the loss of braking pressure through the expansion of the hose.
HKS Stainless steel braided hose kits allow minimal expansion under force due to their construction stainless steel braided teflon hose and give a more positive , firmer feel under heavy braking Teflon PTFE inner lining offers significant durability advantages ovder standard PTFE or nylon inner linings which is proven through independent tests to outlast many other hoses by up to 24 times longer!
The kit for the FN2 contains 6 lines
Old 16th November 2010, 23:35   #3 (permalink)
rossk1009's Avatar
Car: 58 NHB TYPE R GT
Thanks given: 155
Do these come with the distribution blocks or do they just go straight onto the pipes?
I know you might not know but thought i would ask anyway
rossk1009 is online now   Reply With Quote
Old 16th November 2010, 23:56   #4 (permalink)
Davek's Avatar
Thanks given: 32
Question asked for you...will let you know ASAP or Caroline will be on to answer.
Old 17th November 2010, 00:10   #5 (permalink)
Propa Lairy B*stard!
jameseh's Avatar
Car: NightHawk FN2
Thanks given: 96
Oh I'll have me a set of these, as well as some brake fluid. What dot number is Motul RBF600 and is it recommended for road use?
While I'm at it I might as well buy some extra filters for my RSK!
Thanks Davek for the post, get Caroline on here so I can thank her too
jameseh is offline   Reply With Quote
Old 17th November 2010, 00:19   #6 (permalink)
Davek's Avatar
Thanks given: 32
According to Opies oils website its DOT 4
MOTUL RBF 600 Factory Line racing brake fluid
It says its great for race and rainy conditions too so its more than adequate for road use...I believe this is what other tuners recommend using when going for the upgrade.
Caroline is on here but not as a trader (sumocazza) just on here for research and stuff for her own FN2.
Old 17th November 2010, 00:35   #7 (permalink)
jameseh's Avatar
Car: NightHawk FN2
Thanks given: 96
Cheers for the info I was too lazy to search it myself haha cos its Black Ops time for me now!
Old 17th November 2010, 00:48   #8 (permalink)
coste1l's Avatar
Thanks given: 1,185
you dont need the distribution blocks just reuse the existing ones theres nothing wrong with the oem ones?
coste1l is offline   Reply With Quote
Old 17th November 2010, 10:44   #9 (permalink)
Supplieroftuningepicness!
SumoPower's Avatar
Car: 2007 Milano CTR
Thanks given: 120
Hey everyone
They don't come with the blocks you just re-use your existing ones...A really smart bit of kit (from experience!) and well worth the price! I used approx 2 bottles of the RBF when we done the change on my car if that helps
SumoPower is offline   Reply With Quote
Old 17th November 2010, 10:47   #10 (permalink)
SumoPower's Avatar
Thanks given: 120
Give me a call if you can tear yourself away from Black ops I'll sort the replacement filters out for you no probs
Thanks to SumoPower from:
Old 17th November 2010, 23:32   #11 (permalink)
J_H
i-VTEC - DO YOU?
J_H's Avatar
Car: 2009 CTR, Black
Thanks given: 21
Will check bank after this busy week... good deal though!
J_H is online now   Reply With Quote
Old 19th November 2010, 15:15   #12 (permalink)
Derv Devil
Ash3000's Avatar
Car: Black 2.2 i-CDTI EX, Sat Nav
Thanks given: 16
These ok for 2.2 i-CDTI?
cheers
Ash3000 is offline   Reply With Quote
Old 19th November 2010, 19:06   #13 (permalink)
allagios's Avatar
Car: 2009 CTR GT , Silver
Thanks given: 114
Originally Posted by sumocazza View Post
Hey everyone
how can you do that?
Rubber hoses are permantly connected to the distribution blocks!
allagios is offline   Reply With Quote
Old 19th November 2010, 19:10   #14 (permalink)
allagios's Avatar
Thanks given: 114
does this group buy includes others like me from GR?
With a bit more for the carriage?
Old 19th November 2010, 21:17   #15 (permalink)
Cockup Specialist
Relic's Avatar
Thanks given: 762
Here we go with the distribution block confusion again
If you look at items 1,2,4... you have blocks of metal at the end of the hoses that the hose screws into.
These are the distribution blocks...although some people think we are reffering to the support in the middle of the front hoses.
2007 HONDA CIVIC 2.2 TYPE S BRAKE LINES (VSA) (RH) - Honda Original Parts from Lings Honda v1.01
Old 19th November 2010, 21:48   #16 (permalink)
allagios's Avatar
Thanks given: 114
ok have you ever tried to unscrew the hoses from the metal blocks?
if you do let me know!!!LOL
Old 19th November 2010, 22:35   #17 (permalink)
Cockup Specialist
Relic's Avatar
Thanks given: 762
No I let the garage do that after coming close to rounding the hardline nuts
I got the goodridge with blocks.... are they not bolted in then ???
Old 19th November 2010, 22:59   #18 (permalink)
allagios's Avatar
Thanks given: 114
oem hoses are one piece with the metal blocks!
i know that....i've been there!
Goodridge have the metal blocks separated!
i know that...i've been there too!!
Old 19th November 2010, 23:01   #19 (permalink)
Cockup Specialist
Relic's Avatar
Thanks given: 762
But Costel1 had the HEL lines with no blocks fitted ???
And quite a few others have.
Unless they fix straight on the hard lines and bypass the blocks
Old 19th November 2010, 23:11   #20 (permalink)
allagios's Avatar
Thanks given: 114
HEL's 1rst released s's kit fits with tireups!
I've been there too!lol
that was my 1st s/s 4 line kit advertised for fn2's and what a surprice when i lift the car to fit these HEL hoses and realize that i need 6 and not 4!
then i bought the 6 line goodridge kit with the metal blocks!
Thanks to allagios from:
LinkBack to this Thread: http://www.civinfo.com/forum/group-buys/47985-hks-brakeline-kits-60-delivered.html
KIT TUBI FRENO in treccia aeronautica HKS This thread Refback 24th November 2010 22:45
PRE Group Buy x Tubi in treccia e olio Motul x impianto frenante This thread Refback 21st November 2010 16:08
Similar Threads for: HKS Brakeline Kits - £60 Delivered
HKS Racing Suction Kits - £285 delivered! Davek Group Buys 47 10th February 2011 13:56
Price delivered please k20_ed Torque Developments International PLC 10 10th February 2010 19:23
Price Delivered Pt.2 k20_ed Injection Imports 5 29th January 2010 14:40
iTek HID kits $199.99 Delivered !! All Version Performance General commercial posts 1 8th November 2009 12:55
Suspension 5Dr Suspension Kits - Do Type R/S Kits Fit? The Phantom Wheels, Tyres, Suspension and Brakes 3 16th June 2009 15:36
