Go Back   Civinfo > Other Hondas > Honda CR-V
Old 10th May 2012, 23:11   #1 (permalink)
Car: 2004 CRV executive
Thanks given: 3
Headlamp washer pipes.
When I picked up my 2004 crv, I noticed the headlamp washers not working. Had a nose around, and found the pipes not connected to the h/lamp washers. Anyhow connected them back up, only to find that they seem to blow off again every couple of days. The pipes connect ok, and secure in, but seems to be to much pressure to keep them connected. Any suggestions?
Andyd99 is offline   Reply With Quote
Old 10th May 2012, 23:18   #2 (permalink)
無限 Unlimited
Laney's Avatar
Car: 59 Mugenised CTR
Thanks given: 257
maybe try to buy new connectors for the pipes or perhaps some jubilee clips on the joint may work
Laney is offline   Reply With Quote
Thanks to Laney from:
Old 10th May 2012, 23:22   #3 (permalink)
Thanks given: 3
Good shout, unfortunately don't think there's enough room for any kind of clip/cable tie, as I can only just get my hand in there!!!
Old 10th May 2012, 23:27   #4 (permalink)
Syx
Clingfilmed
Syx's Avatar
Car: 2008 2.2 CTS GT
Thanks given: 840
Can you not even get the smaller hose clamps on there (like the ones that are on the coolant pipes etc)?
Old 10th May 2012, 23:47   #5 (permalink)
無限 Unlimited
Laney's Avatar
Thanks given: 257
had you removed the bumper before you reconnected hoses? if not it may give better insight as to what can be done.
Old 11th May 2012, 13:26   #6 (permalink)
-=SBZ=-
snowboundzero's Avatar
Car: 2.2 EX
Thanks given: 132
Wipe the connections with some de-greaser maybe?
Rough them up with some sandpaper to give it a bit more grip.
Check see if the jets are clear. If there's a blockage limiting the flow it will cause excess pressure and blow the hoses off.
snowboundzero is offline   Reply With Quote
Similar Threads for: Headlamp washer pipes.
HID Fox hits headlamp washer pump -ouch! WreckerL Lights 1 20th October 2011 11:51
Wanted - Nr Side Headlamp Washer with Black Body Cover and Grey Nr Side Skirt Wingcoder Items wanted 0 5th October 2011 18:59
Headlamp Washer Jets PBartleet General Discussion 4 20th September 2011 02:08
Lights Headlamp washer + cold weather = stuck eighteentee Bugs, faults and irritations 10 11th January 2010 07:41
Head missing headlamp washer nozzles v001148 Lights 1 29th December 2006 11:27
