Go Back   Civinfo > Other Hondas > Honda CR-V
Old 28th May 2012, 10:00   #1 (permalink)
Car: 2008 2.2 diesel, cosmic grey
Thanks given: 5
squealing disc brakes on 08 reg CRV
Hi, anyone experienced squealing discs? Had new pads fitted but made problem worse. Any ideas/suggestions appreciated
drummerboy is offline   Reply With Quote
Old 28th May 2012, 10:15   #2 (permalink)
Syx
Clingfilmed
Syx's Avatar
Car: 2008 2.2 CTS GT
Thanks given: 827
Were the anti-squeal shims fitted onto the new pads?
Syx is online now   Reply With Quote
Thanks to Syx from:
Old 29th May 2012, 10:15   #3 (permalink)
AoS
AoS's Avatar
Car: 2013 2.0 CR-V, Passion Red
Thanks given: 16
Eco display Eco display
Honda has a fix for this (not sure what it is but they did something on my wife's CR-V and it worked).
AoS is offline   Reply With Quote
Old 29th May 2012, 11:18   #4 (permalink)
Thanks given: 18
I had a spell of squealing, and the discs & pads only had about 5k on them so knew they were likely ok.
After a few sharp brake bursts to re-bed them, it's gone away
BaldySmurf is offline   Reply With Quote
Thanks to BaldySmurf from:
Old 29th May 2012, 12:57   #5 (permalink)
Car: 2009 CRV 2.2 EX
I had an anti squeal kit fitted under warranty when the car had about 6K miles on it and it did silence the brakes. The squeal came back at 20K but new brake pads solved the problem, as they were 70% worn.
Hope this helps
CRVNorth is offline   Reply With Quote
Thanks to CRVNorth from:
Old 6th June 2012, 12:30   #6 (permalink)
Thanks given: 5
I'll try that, thanks
Old 6th June 2012, 12:32   #7 (permalink)
Thanks given: 5
Hi, thanks - what are "shims"?
Old 6th June 2012, 12:33   #8 (permalink)
Thanks given: 5
Thanks - was it a Honda recall or just a regular fix?
Old 6th June 2012, 12:40   #9 (permalink)
Syx
Clingfilmed
Syx's Avatar
Thanks given: 827
Thin strips on the back of the pad that reduce the squeal.
Here's an image - it's the silver bit attached to the pad in this example but on my EBC pads they're dark grey.
http://i679.photobucket.com/albums/v...9-10-30005.jpg
Thanks to Syx from:
Similar Threads for: squealing disc brakes on 08 reg CRV
Brakes Squealing brakes when turning right Ben GT Wheels, Tyres, Suspension and Brakes 3 12th September 2011 11:39
Brakes Squealing brakes norton Wheels, Tyres, Suspension and Brakes 6 26th April 2011 20:45
Brakes squealing front brakes jplant1981 Wheels, Tyres, Suspension and Brakes 12 18th April 2011 15:26
Brakes Rear brakes squealing now grinding [picture] ctrmike Wheels, Tyres, Suspension and Brakes 31 5th October 2009 16:29
Brakes Squealing brakes - when not braking!! Younghobba Wheels, Tyres, Suspension and Brakes 2 10th April 2008 21:50
