[HOW TO] Install non OEM parking sensors - and save 250!!!! - Page 8 - Civinfo
 11Likes
post #141 of 243 (permalink) Old 3rd January 2009, 20:03
having driled 4 bumpers ,i have never used any sort of tape . just mark a pilot hole and drill.
gary y is offline
Thanks to gary y from:
post #142 of 243 (permalink) Old 6th January 2009, 09:42
iamholam's Avatar
Hi wondering if anyone can help. I installed my parking sensors back in May and have no problems with them what so ever.
but.... Lifted up the false floor in my car last night and noticed that the carpet there is soaking wet I took out the rubber bung and replaced it with a plastic washer to route the parking sensors through but didn't really make much of an effort to seal the hole (as it's not in any easy line to get water into it) I also had to tape up the whole where the spare wheel used to go (because I don't use it)
I'm going to have to dismantle my boot again to check out what is leaking, my question is how did everyone else seal the hole and if you didn't is your boot wet like mine?
iamholam is offline
post #143 of 243 (permalink) Old 10th February 2009, 12:05
Can anybody give a ling for this wonderfull CISBO parking sensors on e-bay?
My car is Galaxy Grey.
Can't find them.
Thank you!
AiSt is offline
post #144 of 243 (permalink) Old 10th February 2009, 13:19 Thread Starter
Enthusiastic Supporter
Miggins's Avatar
Car: 2006 2.2 5 door, Cosmic grey
Send a message via MSN to Miggins
Link
These appear to be the sensors (same as what I bought - they are not vehicle specific). They are Grey but you will need to check the colour. (On eBay.Co.UK))
*NEW* CISBO Car Parking Reversing 4 Sensor Buzzer Kit on eBay, also Reversing Sensors, Security Electrical, Car Accessories, Cars, Parts Vehicles (end time 14-Feb-09 12:17:36 GMT)
Hope this helps.
AiSt,
Just found my old box - Colour is 'Grey' (perfect match) and the code on the box SB301-4
Just noticed your location and they only ship to UK
Miggins is offline
post #145 of 243 (permalink) Old 15th February 2009, 11:37
williams's Avatar
Got my cisbo sensors fitted yesterday . Overall a great success , they appear to be working just fine . Hard bit for me was removing the internal quarter panel cover but managed it after much head scratching . The colour match for alabaster silver is perfect . Bought them of ebay and asked the seller for the silvers ones .
Parking Reversing Sensor 4 Sensors Audio Buzzer Alarm on eBay, also Reversing Sensors, Security Electrical, Car Accessories, Cars, Parts Vehicles (end time 16-Feb-09 23:05:41 GMT)
Heres a couple of picts to judge the colour match
williams is offline
post #146 of 243 (permalink) Old 18th March 2009, 13:06
cb83's Avatar
Car: 2006 1.8 EX,Alabaster Silver
I'm going to attempt the installation this weekend. I've read through all the posts and think I'm pretty well prepped for the job...the only thing I don't fully understand is this "rubber grommit" thing.
Could somebody explain what this is used for and what type I will need for the job. There is also a mention that silicone bathroom sealant can be used....could somebody give a little more detail regarding this (i.e where will it be applied and what purpose is it serving?).
Thanks,
Chun
(Also, just thought I'd mention I installed RickHondaR's ambient light kit yesterday...and it looks great!!)
cb83 is offline
post #147 of 243 (permalink) Old 18th March 2009, 17:20
williams's Avatar
The wires have to get into the boot from the bumper . On the rear of the car behind the bumper is a entry point which is plugged with a plastic grumet . When you drill a hole through this you leave a point of entry for water . Hence the need to replace the plastic grumet with a rubber one , or drill the plastic one and stick a bit of silcone around it to prevent water ingress .
hope this helps
williams is offline
post #148 of 243 (permalink) Old 18th March 2009, 17:35
cb83's Avatar
Cheers, I thought it was something like that but just wanted to make sure.
Hopefully, if all goes to plan, I will upload some photos of the completed job this weekend.
cb83 is offline
post #149 of 243 (permalink) Old 18th March 2009, 21:37
jamie_c69's Avatar
Car: Civic
hope this helps
Hi There, How well do you sensors work? are you pleased with them?
jamie_c69 is offline
post #150 of 243 (permalink) Old 18th March 2009, 23:38
williams's Avatar
They work great , must say bargain of the year . Mind you getting the interior panel off to get to the wire was a pain .
williams is offline
post #151 of 243 (permalink) Old 19th March 2009, 20:12
jamie_c69's Avatar
Car: Civic
sounds good, where did you install the buzzer?
post #152 of 243 (permalink) Old 21st March 2009, 18:09
williams's Avatar
Behind the cloth fabric on the wall of the spare wheel compartment in the boot . You can hide it anywhere in the boot under the fabric and it will sound just fine when reversing .
williams is offline
Thanks to williams from:
post #153 of 243 (permalink) Old 23rd March 2009, 12:48
cb83's Avatar
I finally managed to fit the parking sensors at the weekend; it took me all of 11hours but I got there in the end!
I bought what Id thought were CISBO sensors from ebay but they turned out to be branded Gadetman they looked very similar to the CISBO kit (including packaging and instruction manual) although the actual control unit was much smaller which was pretty convenient when it came to installing it.
I did have some concerns about the quality given that I hadnt heard of Gadgetman before, but I took the risk and havent regretted it the sensors work fine, I am well impressed.
Ive attached some pictures of the finished results below . Note, the sensors were purchased in black and were lightly sprayed with two coats of Alabaster Silver (NH700M) aerosol from Auto-paint; also, using the wedges provided in the kit, the outside sensors were angled slightly inwards following problems raised by some members concerning sensors picking-up false/mis-leading signals this adjustment seems to have done the trick as all my sensors seem to operate in the correct range.
cb83 is offline
post #154 of 243 (permalink) Old 23rd March 2009, 12:54
iamholam's Avatar
I originally had mine on the rear wheel arch but found it was too quiet there so have moved it under the carpet next to the drivers door and seat runner.
It's not too much extra work to do when you have everything apart and I would highly recommend it!
iamholam is offline
Thanks to iamholam from:
post #155 of 243 (permalink) Old 25th March 2009, 18:15
StevenG's Avatar
I've got my hands on some non OEM parking sensors and had them painted by a body shop for the correct colour match, and will soon be having a fun day with my Dad trying to put them in.
Can anyone explain how the panel at the drivers' side (UK car) of the boot comes off, where you gain access to the brown wire for the 12v supply to the reverse light. I apologise if this has already been covered. I have read through this thread but couldn't find any clear instructions. What's the best angle to approach this from? I had a brief look in the car, pushing and pulling stuff but didn't want to be too forceful without being sure of where I was supposed to be pulling!
StevenG is offline
post #156 of 243 (permalink) Old 26th March 2009, 13:21
iamholam's Avatar
The way I have done it was to remove the plastic back panel from the boot (the one that surrounds the boot latch) Then from the side of the drivers side panel just work your way along the edge of the plastic trim pulling up from where the trim touches the boot seal. (pull the boot seal off that area first so that you can get you fingers in)
It helps if you pull in the area where the fasteners are in place because the plastic and the fasteners can be a little fragile but you should be able to find them on the instructions for the how-to.
You do have to give it quite a yank to get it out, don't be shy!
iamholam is offline
post #157 of 243 (permalink) Old 30th March 2009, 14:04
StevenG's Avatar
So yesterday my dad and I set about tearing up my poor little car, but it all seems to have been worth it. It took about 6 or 7 hours, but we got there in the end. We ended up managing to velcro the speaker under the backseats. It's visible when they're folded up, but that happens so rarely that I'm not too bothered. The main benefit being that it's quite close behind me, so it's nice and easy to hear.
I do quite often find it beeps even when there's nothing at all behind me. Still need to work out why this is. I wonder if it's picking up the road surface. What's more important though is the beep's frequency increases as I get close to stuff, eventually turning solid when I'm about one foot away. Could take me a while to get more confident with it though!
StevenG is offline
post #158 of 243 (permalink) Old 10th April 2009, 20:08
mike170177's Avatar
Finally fitted my Cisbo parking sensors yesterday, I got them for xmas as a present so it's only taken four months to fit them! Really pleased with the end result, removing the rear bumper was the hardest part, after this the rest was just a case of taking your time. Total time was around five hours.
Thanks to everyones advice throughout this thread, it proved very useful during the install. The success of the Cisbo parking sensors is a prime example of how forum members help each other out.
mike170177 is offline
post #159 of 243 (permalink) Old 14th May 2009, 06:50
baldrik2002's Avatar
Car: 1.8 ES 2006 5 dr
Front Sensors
Has anyone fitted them to the front and rear of a civic as I have been told that front sensors are just as useful as the back ones.
baldrik2002 is offline
post #160 of 243 (permalink) Old 20th May 2009, 08:18
The kit I bought has front sensors too but I still haven't got around to fitting them yet. Been far too busy modding my TT!
Naresh is offline
  Civinfo > 8th Generation Euro Honda Civic (2006 - 2011) > This is How To ... (Guides Only)
Human Verification
LinkBack to this Thread: http://www.civinfo.com/forum/how-guides-only/1202-%5Bhow-%5D-install-non-oem-parking-sensors-save-%A3250.html
????? ??????? ?????????? ???????? -> ???????? ?????? This thread Refback 28th March 2014 13:56
Parking sensors, front and rear - Unofficial Honda FIT Forums This thread Refback 18th January 2014 17:36
Untitled document This thread Refback 9th June 2013 02:14
Parking sensors, front and rear - Unofficial Honda FIT Forums This thread Refback 15th June 2012 05:35
Untitled document This thread Refback 22nd May 2011 10:07
Parking sensors, front and rear - Unofficial Honda FIT Forums This thread Refback 18th November 2010 21:47
Untitled document This thread Refback 16th June 2010 19:40
Untitled document This thread Refback 28th May 2010 16:34
Parking Sensor - Insight Central: Honda Insight Forum This thread Refback 27th May 2010 18:04
parking sensor cisbo - Google? haku ? Fonecta.fi This thread Refback 27th April 2010 21:30
Untitled document This thread Refback 23rd April 2010 15:51
parking sensor cisbo - Google? haku ? Fonecta 02.fi This thread Refback 12th March 2010 12:46
Untitled document This thread Refback 3rd January 2010 13:26
????? ??????? ?????????? ???????? -> TBILISIS FORUMI This thread Refback 12th August 2009 12:01
Untitled document This thread Refback 26th July 2009 18:13
Untitled document This thread Refback 7th July 2009 22:38
Untitled document This thread Refback 27th April 2009 11:24
Untitled document This thread Refback 19th April 2009 19:20
Parking sensors on a Civic - Type R Owners Forums This thread Refback 3rd June 2008 20:30
[HOW TO] Install Honda OEM parking sensors Pottsy This is How To ... (Guides Only) 11 20th October 2016 10:59
Parking Parking Sensors Knat Electronics 33 7th September 2008 19:35
Exterior parking sensors panasony Bugs, faults and irritations 8 23rd January 2007 20:44
Parking Parking sensors PTR Electronics 18 9th October 2006 18:13
Other Parking Sensor Install basegreen Gallery 3 31st May 2006 00:07
