This thread is about: Connecting an iPod to an EX, it's in How To at the Honda Civic forum Civinfo; I would have thought very low, but an email to technical@connects2.com would sort it out one way or the other....
LinkBack (4) Thread Tools Display Modes
Old 3rd October 2006, 23:23   1 links from elsewhere to this Post. Click to view. #101 (permalink)
Old 26th October 2006, 16:39   #102 (permalink)
IronSoil's Avatar
I have read many different Honda webpages (Finland, Sweden Germany, UK), and they say about the loom (2 PIN BUS CORD) that Pottsy ordered, is only required for Civic with Navigation.
Part Number: 08A31-0H6-000.
ONLY FOR CARS WITH FACTORY FITTED NAVIGATION SYSTEM - REQUIRED TO FIT 8CD CHANGER OR ADAPTER FOR iPOD WITH FACTORY FITTED NAVIGATION SYSTEM
http://www.honda-access.com/uk/en/products/index.jsp
When I look at the Sport model accessories, it doesn't mention anything about a 2 PIN BUS CORD needed.
So maybe the picture that Roger Harris chared for us from the back off the HU, the white connector might be for the Navigation, and those who don't have Navigation can connect the Connects2 adapter straight to the white connector?
I have sent a question about it on the Connects2 forum.
I hope that this would be the solution for non Ipod owners that can connect a mp3-player finally to the Civic...
IronSoil is offline   Reply With Quote
Old 7th December 2006, 12:20   #103 (permalink)
generationgav's Avatar
Wait...can I put the Connects2 adaptor (for £59) straight in to my SE without the loom? Or do I still need something to "trick" it in to thinking that a CD Changer is there?
Old 7th December 2006, 19:10   #104 (permalink)
IronSoil's Avatar
I think it is possible.
I will try to install the Connects2 cable as soon I will receive my Civic
Old 22nd January 2007, 22:00   #105 (permalink)
arthercrow's Avatar
Dension Icelink fm
Hi
1st post so hello. Got 2.2 ex on Thursday, changed interior lights, and spent all weekend fitting Icelink FM, all was fine until I needed to identify the ariel coax socket (what gives with this then ?) why not a conventional plug, finally working and everything fine except I wired the permanent and switch live together (to save time???) now the unit resets the frequency every time you switch it on. Anyone know what is permanent live on dash that is easy to get too?.
arthercrow is offline   Reply With Quote
Old 30th January 2007, 16:51   #106 (permalink)
Does the Connects2 box come with the Honda HU ---> Connects2 cable? It isn't clear on the site?
Old 30th January 2007, 18:03   #107 (permalink)
IronSoil's Avatar
Yes it comes with the cable, so you can connect the Connects2 adapter to your HU.
I will get my Civic on tuesday and will find a company that will install it for me.
I will tell then if it is working or not...
Old 27th March 2007, 11:28   1 links from elsewhere to this Post. Click to view. #108 (permalink)
Bog
Bog's Avatar
Had some time this weekend, so I fitted my connects2 aux in to my EX. I took the dash apart as per Pottsy's instructions, it took about 1 hour to do and was relativly simple. The only hard part was getting the trim panel above the HU off.
Once all off, I connected the Honda loom (thanks Chiswick Honda ) and connects2 box.
I then fitted a 3.5 socket to one of the heated seat switch blanks (I chose this location as it keeps my cup holders free and the switch blanks are easy/cheap to replace if I want to remove the socket at a later date). I then soldered a lead to it with another 3.5 stereo socket at the end, which in turn plugs into the connects 2 lead.
Old 9th May 2007, 14:39   #109 (permalink)
I puchased a transmitter from ebay for under £5.00. I think it is manufactured by Belkin? I know that people here say that the quality of sound is not so good as hard wired - but for a fiver - and with me singing along (not nice) and no installation grief - it's fine. I also use a transmitter that just clips over my mobile phone - and again uses one of the radio frequencies to put the call out through the car speakers. That cost me £20 about 2 years ago at the BMF bike show. Both simple and effective.
civicpete is offline   Reply With Quote
Old 13th May 2007, 19:32   #110 (permalink)
Daren's Avatar
Just installed my Connects2 aux-in box today and i'm happy to report it is working
I followed the instructions on the WIKI to install the box without the £92 Honda loom. It is really easy - give it a go.
It took me about 3 hours in total (would have been 2 if it was not raining so hard).
I have made a few minor changed to the WIKI to make things a little clearer as I was scratching my head in a few places - should be a little easier now though.
I'm chuffed - Aux-in - £40 -
Daren is offline   Reply With Quote
Old 13th May 2007, 21:51   #111 (permalink)
basegreen's Avatar
I'm plucking up courage to do this to my SE.
Anyone else done this to the standard HU?
Old 13th May 2007, 23:12   #112 (permalink)
Daren's Avatar
Basegreen - it's even easier on the SE model - you just plug the connects2 module straight into the Civic head unit.... no chopping wires... no special £92 Honda wiring loom... its just plug and play
Old 13th May 2007, 23:32   #113 (permalink)
basegreen's Avatar
how do you access the AUX channel on the standard HU tho?
Old 13th May 2007, 23:42   #114 (permalink)
Does the CD button not toggle between internal and external CD player? The connects2 is just pretending to be the external changer.
Old 15th May 2007, 17:47   #115 (permalink)
Daren's Avatar
You got it - thats how it works on my EX, you can also press the mode button on the stearing wheel a few times and it toggles FM > FM > AM > MW > CD > Ext CD/Aux-in.
Old 15th May 2007, 17:50   #116 (permalink)
Daren's Avatar
If you mean the Aux channel socket on the HU - its behind the unit and you need to remove the HU first to install the connects2 (see other posts and WIKI), if you mean how do you switch it on once installed.... then see my post above.
Old 15th May 2007, 18:24   #117 (permalink)
basegreen's Avatar
Got it. WHere's the best place to grab the connects2 bit from then?
Edit: 40 quid from the place pottsy got it from it seems, and to save my sanity, do i need ANYTHING else other than this? Would probably bring the aux cable into the cubby hole under the HU.
Are cables required for the SE HU between the connects2 and the HU?
Old 15th May 2007, 18:33   #118 (permalink)
Daren's Avatar
I got mine from http://www.incarexpress.co.uk/view_p...partno=VHOX001
Nice and quick - and £20 cheaper than Halfords.
You shouldn't need anything else, all the cables you need are in the box and it will plug straight into the external CD socket on the back of your head unit.
I added a simple 3.5mm socket for my unit inside the centre slide compartment (cost me £1.29 from Maplins and 10 minutes to solder) but you don't need to do this - you will see what I mean when you get the box and cables.
Old 2nd June 2007, 18:07   #119 (permalink)
WavyD's Avatar
Unhappy iPod Adaptor.
Hi Everyone. I have just been on the Honda website and the Type R Brochure shows an iPod adaptor as clear as day!
Is the Navigation unit in the Type R not the same as in the EX model?
I'm considering buying a 2.2 i-CTDi EX at the moment, but the iPod connection problem is putting me off! I had the same problem with my Vauxhall OEM Headunit as my MP3 compatable unit won't take a Connects2 box! Click the image to open in full size.
I use a Griffin iTrip at the moment and the quality is shocking at best. I did find some articles on modifying the iTrip to make it transmit further, have not had a go yet!
http://www.makezine.com/blog/archive..._itrips_r.html
Also this one -
http://www.thatgrafix.com/itrip.nano/
As I want a fully controllable had wire solution, I think that I'll hold on to what I've got until I know for sure.
Type R online Brochure -
http://www.honda-access.com/car-ebro...r07/index.html
Old 3rd June 2007, 00:11   #120 (permalink)
the iPod lead in the R is the same as the one available for the rest of the range - extreemley limited functionality, espcially for the price
LinkBack to this Thread: http://www.civinfo.com/forum/how/10-connecting-ipod-ex.html
www.clubhondacivic.com :: Ver tema - Adaptador Ipod This thread Refback 6th January 2008 15:56
www.clubhondacivic.com :: Ver tema - æLa solucion definitiva a la salida Auxiliar de audio? This thread Refback 22nd November 2007 07:32
Honda Trójmiasto Wyj¶cie " AUX " w 8 generacji ? This thread Refback 10th November 2007 10:18
HIBRIDOS CLUBE :: Verificar tópico - Onde fica a entrada Aux (auxilary)? Post #108 Refback 16th August 2007 15:13
Similar Threads for: Connecting an iPod to an EX
Thread Thread Starter Forum
