Old 15th December 2007, 18:48   #21 (permalink)
Munro's Avatar
Thanks given: 89
Originally Posted by Sandozer View Post
That is one thing I miss from my old Focus TDCI, a !!!HEATED WINDSCREEN!!!.
Has Ford got the patent on this?? only seen it on Fordies so far....
The ford heated screen is brilliant for this time of year - demist or defrost the windscreen in seconds at the push of a button.
Old 15th December 2007, 21:29   #22 (permalink)
matg's Avatar
Thanks given: 14
Yes I believe they do.
matg is offline   Reply With Quote
Old 15th December 2007, 22:16   #23 (permalink)
Lord of JAE.....
Car: 58' NHB Type R-GT
Thanks given: 390
Range Rover Vogues (don't know about other models, never had any different) has it too [a very fine nonnofilament wire through the windscreen].
Old 15th December 2007, 22:52   #24 (permalink)
Car: M200 Type R
Thanks given: 202
My wife's mini has one, as she keeps reminding me, I knew this would happen.
Old 16th December 2007, 00:48   #25 (permalink)
N2H
I'm sure it's nice to have a heated windscreen but as it's a legal requirement to have all windows blockage free, some de-icing will still have to be done surely...
N2H is offline   Reply With Quote
Old 16th December 2007, 17:59   #26 (permalink)
sambuca2907's Avatar
Thanks given: 1
I don't think the heated front is just a Ford thing - I have driven another make of car that actually had a heated front screen, but for the life of me I cannot remember what it was!
Old 16th December 2007, 18:03   #27 (permalink)
Car: MX-5 & V70
Thanks given: 507
I´ve only seen it on Fords.
I thought they had a patent.
May well be available on other Ford-group cars or some-one else may be paying for the technology or worked around the patent.
Old 16th December 2007, 18:06   #28 (permalink)
Thanks given: 1
Yes someone above said they had seen this in a Range Rover but RR are part of the Ford group... well for the moment they are anyway!
Old 16th December 2007, 18:30   #29 (permalink)
Strong in me The Force is
Koen's Avatar
Car: 2.2 NHB & 1.8 DBP TypeS
Thanks given: 9
I noticed when I do my windows with Rain-X, the ice comes off very easy with the rubber scraper blade. Without using water or an alcohol spray.
Cold tap water is indeed a good idea...when it's available. As someone suggested, my Civic resides in a nice garage at night , but at many occasions, you're parked somewhere at night, and then there isn't always tap water available. (Or a garage.) For these occasions I always have a bottle of water with diethylene glycol in the boot. But if the Rain-X coat is still ok, I hardly need it.
K.
Old 16th December 2007, 18:44   #30 (permalink)
cjthompson321's Avatar
I've been using a 4 pint milk bottle filled with not hot-not cold water. Just enough so that it doesn't feel cold when poured over fingers.
Then I add a teaspoon of salt and shake vigourously.
It works wonders and doesn't re-freeze.
cjthompson321 is offline   Reply With Quote
Old 16th December 2007, 19:03   #31 (permalink)
Car: MX-5 & V70
Thanks given: 507
Seriously guys...
...it is not that much work to scrape the windows.
A bad day is when you have to dig the car out from 2 feet of snow.
And I don´t know about pouring salt water on my car.
The salt on roads is bad enough.
Old 16th December 2007, 19:13   #32 (permalink)
Exactly. There's plenty of salt on the road which is heading straight for the paintwork. I'm not going to worry about a tiny bit on the glass that runs straight off.
Old 16th December 2007, 19:45   #33 (permalink)
Civinfo Trader
Thanks given: 1,112
Ive been using warm water for many years. It works a treat.
Tried cold water...waste of time and freezes straight away again.
Old 16th December 2007, 20:09   #34 (permalink)
Munro's Avatar
Thanks given: 89
Seriously guys...
Scraping does me as well - only takes a couple of minutes and its good exercise to warm you up before getting into a freezing car.
The snow Could be even more than 2 feet
Old 16th December 2007, 20:39   #35 (permalink)
Thanks given: 5
I always used warm water or de-icer stuff. I'll give the cold water a go sometime, hasn't been cold enough recently to need to do anything
Old 16th December 2007, 20:57   #36 (permalink)
P@tje's Avatar
well Ford is not the only one. Renault has it too !
But there are 12V systems on the market that can be used for quick heatering from inside. (Conrad)
I use the built-in windows spray ( of course is the tank filled up with winter ready stuff ) and push two buttons: one for rear/mirror heating, and the other one, the windshield defrost button ( it has an orange led also). Of course airco on!
Together with spraying, the windows is clean in short time. But of course this depends on how much it has frosen! One night with -10 Celcius is too much to use the spraying/wipering method. You will have to let the engine run for a while then.
Old 16th December 2007, 20:59   #37 (permalink)
P@tje's Avatar
well warm water is not a very smart choise to use for this job ! to dangerous and tricky.
Old 16th December 2007, 23:17   #38 (permalink)
Thanks given: 7
I suppose the Mini had it back in the 60's.. (at least for rallying purposes). See the horizontal strips inside the windshield.
Old 17th December 2007, 00:16   #39 (permalink)
JohnH's Avatar
I really miss the heated screen from my Ford(s) - along with the decent rear suspension on the Focus (another thread)...
However, I've a feeling that Ford's patent has lapsed (might be mistaken) as they're only granted for a certain amount of time (15 years maybe)? You can definitely order a heated windscreen on a VW Passat these days.
The 2.2 (brilliant though it is and I know it's testament to its efficiency) does take an age to deliver warm air.
JohnH is offline   Reply With Quote
Old 18th December 2007, 08:17   #40 (permalink)
GHGH's Avatar
Thanks given: 3
Originally Posted by civicfan View Post
You can use cold water it's no problem since it is still warm enough to melt the ice in light frost. If it is really cold (-15-20 °C) I would rather not pour water over the windows, since cold water will freeze too quickly and warm water might cause the glass to crack
In periods with -15-20°C the air contains less humidity, so I find the ice less problematic. Much worse last week with thawing days and freezing nights.
Thanks to GHGH from:
Similar Threads for: [How to] Defrost your windows in record time
Honda Sets All-Time Monthly Record for Worldwide Production Honda News Feed Honda News 0 27th November 2007 04:00
All-Time Production Record for First Fiscal Half Honda News Feed Honda News 0 12th November 2007 23:08
Delivery time Record delivery time on i-Shift? ttruijen Buying, Dealers and Servicing 5 20th July 2007 19:01
Delivery time Is this a record frogger Buying, Dealers and Servicing 1 7th March 2007 15:07
record or what bezz General Discussion 3 3rd March 2007 18:18
