| This thread is about: How to Make your own floorlights, it's in How To at the Honda Civic forum Civinfo; Stef, thanks for the 'how to'. The IN4007S and BC548B are both available for pennies from Maplin, I think they are both equivalent and resistors ... | ||
#21 (permalink) |
The IN4007S and BC548B are both available for pennies from Maplin, I think they are both equivalent and resistors are no problem to get hold of. Whats the nature of the INT light PWM signal? I'm trying to follow the current path, am I right in thinking current flows from 12V to the INT light terminal while the POS is 'off' - which effectively dims the lighting? Any suggestions as to how I can go about physically mounting / building the circuit board? What is the SK10? Last edited by KevinPedrick; 28th May 2008 at 15:43. |
#22 (permalink) | |
In this case the signal is pulsated to ground, creating a dimming effect. The other end of the LED (or bulb) is connected to the + constantly. Sk10 is simply a connector, if you want one. Or connect (solder) directly to the board. You could use a board with separate islands (check Maplin) then interconnect the islands. BTW it is 1N4007 not IN4007 |
#23 (permalink) |
Thanks for the quick reply Stef.
Sorry, I got it as 1N4007... my, uh, keyboard must have misinterpreted. So am I right in thinking current flow is from +12V to INT LGHT when POS LGHT is 'off'..? Doesn't seem like it can go anywhere else but through D10 to INT LGHT since T10 is inactive. |
#24 (permalink) |
What would i need to do, if i wasnt worried about the slow dimming effect?
Just wanted them on on the doors, then dim on headlights. Or is that what it does I thought the extra parts was to get it to go off slowly.. |
#26 (permalink) | |
interested
#29 (permalink) |
I shall be taking the car in for the handbrake mod in a couple of weeks.( I suppose I had better
With the centre console off, they can fit me a rocker switch in one of the blanks, with the wires run from the cigar lighter wiring and left loose, I shall then fit the LED strips. Now with Dealer hourly rates being so reasonable, it should only cost me, -- £200 |
#30 (permalink) | |
#32 (permalink) | |
What colour scotch locks did you use? as my red ones don't seem to want to "cut" into the thin wires. |
LinkBack to this Thread: http://www.civinfo.com/forum/how/10302-how-make-your-own-floorlights.html
| podsvietenie interieru | Honda CIVIC 8. generace | This thread | Refback | 19th May 2008 17:23 | |
| How to make an MP3 CD | TFL | Wiki Article Discussion | 11 | 6th September 2008 22:21 |
| Alloys Other Wheels sometimes do make a car | Sekhmet | Wheels, Tyres, Suspension and Brakes | 37 | 10th December 2007 14:39 |
| This will make you smile | Topcat | Any non Civic chat here please! | 7 | 5th December 2007 17:09 |
| Pictures to make you Smile | Topcat | Any non Civic chat here please! | 12 | 30th July 2007 15:44 |
| Head Unit What is the make/model of the EX hu | WoolyCiv | Ipods, MP3 Players and ICE | 6 | 6th July 2007 21:20 |
