This thread is about: Solution to interior door noise, it's in How To at the Honda Civic forum Civinfo; Has anyone got any good ideas of what I could put in the bottom of the door pockets to stop things from sliding around and ...
Old 10th January 2008, 15:02   #1 (permalink)
Homer Simpson's Avatar
Has anyone got any good ideas of what I could put in the bottom of the door pockets to stop things from sliding around and making loads of noise? The plastic as you know is very hard and slippery.
I have tried some anti slip matting that I bought off of Ebay but its so flimsy that what ever is in the pocket seems to grab hold of it and scrunch it up out of the way
I'm sure someone on this forum has come up with a good idea they would like to share
Homer Simpson is offline   Reply With Quote
Old 10th January 2008, 15:52   #2 (permalink)
cb550's Avatar
I use the same stuff in the central armrest cubby holes etc,Although not really needed any in the door pockets yet.
What about double sided adhesive tape? Bear in mind though,there could be a residue left on the car's plastic should you later remove the matting.
Old 10th January 2008, 16:56   #3 (permalink)
Topcat's Avatar
Simple - dont use them
My civic is making enough noises of its own at the moment without the added sound of bits & pieces moving around.
In fact I have to empty my car so often to take the car to the dealership that I dont even put my stuff back in it anymore.
Topcat is online now   Reply With Quote
Old 10th January 2008, 20:56   #4 (permalink)
I never use them either.
Old 10th January 2008, 21:01   #5 (permalink)
If you go to machine mart or the like they sell a roll of rubber mat which is used to line the bottom of tool boxes. Its pretty good and can be cut into any shape and stuck down with double sided tape - its about .08 mm thick.
try: Machine Mart Power Tools and Machinery: Clarke, Dewalt, Makita, Ryobi, Bosch
leicesterminiracer is offline   Reply With Quote
Old 11th January 2008, 16:44   #6 (permalink)
That seems like a pretty good idea but I think I may have found a solution.
I've found a company on Ebay that sells self adhesive silicon sheets in various colours and thicknesses. I've ordered a sheet in red (Type R) and will cut some templates for the doors and see how it looks and works.
I'll let you know if it's any good?
Old 15th January 2008, 13:13   #7 (permalink)
Thumbs up Solution Found
Ok after much thought I have made a solution to stop the noise from items left in the door pockets. It took me about an hour but the results are pretty good.
Step 1 - Buy a sheet of self adhesive silicon gel from ebay or something similar. I used silicon gel as its really easy to cut and comes in any colour and thickness. I used 3mm sheet in red (Type R) but in hindsight I should have used 5mm.
Next I made a template that fitted into the door cavity. Its worth taking your time over this to get it right, but you only need to make one as it is reversible for the other side.
Once this is made, mark out the shape onto the silicon gel or what ever else you have used.
Repeat for the other side and then cut out the shapes using a sharp knife and scissors. The silicon gel is really easy to cut.
Finally clean out the door pocket with an alcohol wipe or something similar. Remove the backing tape from the silicon gel sheet and stick into place.
The silicon grabs anything that you put onto it and stops all of the noise.
I would have posted this into the how to section but for some reason I couldn't I hope that this post has been of some help
Old 15th January 2008, 13:40   #8 (permalink)
AndyC's Avatar
That looks awesome and useful. I bought a neat little silicone ipod mat for £2.49 the day i picked my car and it fits perfectly in the ipod cubbyhole and stops it sliding about. That silicone stuff is some job. Might try black for the door poskets though...
AndyC is offline   Reply With Quote
Old 16th January 2008, 19:35   #9 (permalink)
Munro's Avatar
Looks like a good idea.
Old 16th January 2008, 22:14   #10 (permalink)
Civic Storm's Avatar
Have you got a link for the company on ebay
Civic Storm is offline   Reply With Quote
Old 17th January 2008, 10:07   #11 (permalink)
You will laugh
Hi Civic Storm
Here is the link you need
eBay.co.uk Shop - Softcare Silicone UK Outlet: With Adhasive Backing: Silicone Gel Sheet with Pressure Sensitive Adhesive PSA
By the way they sell some pretty strange stuff on their site so don't go getting too excited
Old 17th January 2008, 12:39   #12 (permalink)
Exiled Englishman
bucketp's Avatar
That is one strange site!
Old 28th January 2008, 23:02   #13 (permalink)
Jack The Lad.'s Avatar
Think I'll go for the breasts, to stick over the speakers.
Old 5th February 2008, 23:05   #14 (permalink)
gray52's Avatar
i wont ask how you found this site
Old 6th February 2008, 08:10   #15 (permalink)
Comedian/Smart A*se
Why would you want custom nipples? Suppose you might get cold Knobs in winter?
Similar Threads for: Solution to interior door noise
Interior door scuffs jaydh Cleaning 13 20th January 2008 21:22
Lights Have they given someone solution for the condensation? lohupoyu Bugs, faults and irritations 25 9th November 2007 23:20
Trim drivers interior door opener bikersupermoto Bugs, faults and irritations 7 10th October 2007 10:15
Rear Door Interior Skin Lucid General Discussion 1 26th February 2007 10:58
AUX in Possible iPod solution? YorkshirePud Ipods, MP3 Players and ICE 32 15th November 2006 15:19
