| This thread is about: Install Ambient Blue Lighting (Switched on by Main Lights), it's in How To at the Honda Civic forum Civinfo; Originally Posted by markvirgo Pics will be posted monday. They look really good at night. It's monday....... | ||
#24 (permalink) |
Here's My Pics (sorry about the rain
Lights on ![]() Drivers Side ![]() Passenger Side ![]() Switch ![]() Drivers Side LED Strip Light ![]() Passenger Side LED Strip Light ![]() No Walkthrough as it is coved in the guide. See my car Here Last edited by markvirgo; 2nd July 2007 at 22:41. |
#25 (permalink) |
There is an easier way to do it by buing a Cold catode computer neon light colored blue and taking some power from the glove compartment and it al works fine,
And by the way i dont like that much blue light at the feet and the way to dim the neons is to cover part of them with black electronic tape and see how much light fits your eyes... the neons are quite cheap,maybe 10$ max at yor local computer shop,no heat and low power consumption...and you get wide angle of blue lighting and not spot like Leds.... will share pictures of my setup if needed. Cheers. |
#30 (permalink) |
If you remove the instrument left panel (12 - 14) and the glove box light (7 &
#31 (permalink) |
OK, My bad... I was struggling to get my head round where the end panel was duhhhhh
The problem I have now is that due to some nimble finger work I've managed to release the retention cable into the freedom of the dash cavity duhhhh x 2 Anyone got a smart way of retreaving it? |
#32 (permalink) |
Hi!
I installed my Ambient Lighting today. (3 Superflux LEDs at each side) Took me about 1/2 hour! Thank you very much - tamar !!!! But I have to add that it is not necessary to detach the glove box door. You could do so if you have big hands/fingers Kind regards from Germany, surffreak |
#36 (permalink) |
A. Senna
Just followed this How to guide.
It took me about 1 hour, and 5 euros! I used 2 wided focus 12V Leds. The result is wow!!! Thank you guys! |
#40 (permalink) | |
They are on when the lights are on only. It does not matter if the doors are open or closed. If you put in a switch like I did then you can have them off at certain times. Last edited by markvirgo; 13th September 2008 at 08:40. |
LinkBack to this Thread: http://www.civinfo.com/forum/how/1138-install-ambient-blue-lighting-switched-main-lights.html
| Forums CivicYume • Afficher le sujet - Remplacement des ampoules intérieures par des LED Bleu | This thread | Refback | 31st July 2008 22:56 | |
| Interior Ambient Lighting | Griffyn | Lights | 34 | 6th January 2008 21:40 |
| Ambient Lighting Easy Install | ante00 | How To | 5 | 18th December 2007 13:04 |
| Blue Ambient footwell lighting | Primuldak | Wiki Article Discussion | 0 | 5th September 2007 19:42 |
| Interior Auto dim ambient blue lighting | crispy | Lights | 75 | 5th June 2007 23:25 |
| Interior Ambient lighting | Morph3ous | Lights | 10 | 13th April 2007 19:58 |
