| This thread is about: How To - Fix The Windscreen Cowl creaks., it's in How To at the Honda Civic forum Civinfo; Originally Posted by damianscott71 My creaking windscreen, which I always took to be an incorrectly fitted windscreen (to the repeated denial of the local dealer) ... | ||
LinkBack (18) | Thread Tools |
![]() Join Date: 7th October 2007
thin windscreen and thin paint - Honda |
#27 (permalink) | |
![]() Join Date: 22nd June 2007
I mentioned this felt fix and the head tech guy sounded interested and looked it up on the system. There was no mention of it. But because I mentioned the cowl they noticed it was positioned incorrectly and have refitted it. I wonder if it will have worked... |
#32 (permalink) | |
Anyway, after seeing my fix the service guy said he believes it might last longer than the "felt fix" because there's less chance for water/dirt getting between the cowl and the windscreen |
#33 (permalink) |
Despite the dealer saying thay had made "adjustments", there is no change at all. The creak is there as bad as ever. They say they can't hear it.
I think i'll try the DIY cowl fix next. |
#35 (permalink) | |
![]() Join Date: 10th August 2007
The Type R is probably more prone to it due to the firmer suspension inducing more bodyflex. The fix has stopped the creaking in my car, even when driving "enthusiasticaly". It has been on the car for @3 weeks and @ 1000 miles now without a single creak. As DR says in the last post, it is really quick and easy to do, and a lot less hassle than taking the car to the dealers. The Duck tape I used, and would recommend, is the 1mm thick x 4mm wide stuff. It is sticky on both sides. Halfords link below: Duck Trim Repair Tape 12mm x 4m from Halfords Price Ł4.99 . |
#37 (permalink) | |
![]() Car: Type R GT
#38 (permalink) |
Hello guys... I have a 08 2.0 Si Coupe and I have the same problem. I am wondering if any of you guys have had a permanent fix yet from your Honda dealer?
I am afraid my Honda dealer will not be able to fix and that I have to do the DIY method... |
#39 (permalink) | |
Type-R R-00799
![]() Join Date: 22nd February 2008
The problem is at the end of the wind screen, where it meets up with a plastic cover between the windscreen and the hood. This plastic part is making that creak sound as it rubs against the windscreen from the vibrations of the road . I had found a thread with diagram for the DIY. If I manage to find it I'll send it to you. Otherwise have a look through the older threads. I'm adding you to my buddy list so I can find you easier when I find the thread. |
#40 (permalink) | |
| Windscreen windscreen damage | murr04 | Bugs, faults and irritations | 2 | 7th July 2007 13:42 |
| Scratched Windscreen | adamski | Cleaning | 11 | 21st June 2007 12:57 |
| Windscreen Warped windscreen | JoeyF | Bugs, faults and irritations | 6 | 13th May 2007 13:13 |
| Windscreen About to receive my 3rd windscreen | Tony Fendall | Bugs, faults and irritations | 8 | 9th May 2007 19:31 |
| Windscreen | Kremmen | Cleaning | 6 | 15th April 2007 14:31 |
