This thread is about: How To - Fix The Windscreen Cowl creaks., it's in How To at the Honda Civic forum Civinfo; Originally Posted by Munro Try posts earlier in this thread. Dude right on tankx. Thank you for your contibution to this cool forum....
LinkBack (18) Thread Tools
Old 15th April 2008, 21:50   #41 (permalink)
Type-R R-00799
TYPE-R '07's Avatar
TYPE-R '07 is offline   Reply With Quote
Old 15th April 2008, 21:51   #42 (permalink)
Type-R R-00799
TYPE-R '07's Avatar
You see what Munro said....... go to page one of this thread, right at the top.
Old 15th April 2008, 23:13   #43 (permalink)
No, I see it... Thank you.
I just want to know if the Honda dealership can fix this permanently because the DIY above looks to be a temporary fix and will come back.
Ghetto2315 is offline   Reply With Quote
Old 16th April 2008, 16:33   #44 (permalink)
cjthompson321's Avatar
Apparently there is an official Honda fix which is the same as the DIY fix on this thread, except they use a bit of felt instead of trim repair tape.
Only when I told my dealer about this fix they couldn't find any mention of it in their computer.
When I got my car back from them they said they'd adjusted the plastic cowl as it was seated incorrectly. The noise was still there.
When I took the cowl off to do the DIY fix I noticed there was no evidence of them having touched the cowl. There was also a long gouge out of the glass where the cowl had been rubbing (does this affect the strength of the windscreen?).
The DIY fix looks to me to be more permanent than the official one, plus when it does loose it's effectiveness you'll be able to re-apply it without going back to the dealer.
Last edited by cjthompson321; 16th April 2008 at 16:36. Reason: submitted before i'd finished
cjthompson321 is offline   Reply With Quote
Old 16th April 2008, 19:04   #45 (permalink)
Car: Type R GT
It amazes me sometimes what the dealers will tell us to fob us off.
Old 16th April 2008, 21:37   #46 (permalink)
Yes there is one, but even my dealer does not believe it will work
Old 8th September 2008, 11:35   #47 (permalink)
Goodbye all, have fun!
I have found the silicone spray sold at Halfords to be very good for curing this noise too. I lifted up the cowling slightly and sprayed plenty in to the gap, and its much quieter now.
The company that makes WD40 also makes the 3in1 silicone spray that I used.
Old 8th September 2008, 18:28   #48 (permalink)
Munro's Avatar
I am sure the spray will stop the noise for a while , but suspect it will wash away next time you wash the car, or it rains or when you use the windscreen washer fluid.
I found the noise only occurred when driving fast over very bumpy roads. It is a very distinctive and worrying creaking noise that makes you think the windscreen is going to fall out or something similar. Since the tape fix I have not heard it once in @ 10,000 miles. The tape fix only takes 20 minutes to do.
I find The silicone spray is good for inside the car on the dashboard joints - it cured a few squeaks for me.
Old 8th September 2008, 18:30   #49 (permalink)
I would like to try your fix, but my hands are not very good with small objects and fiddly things, so I will have to stick to the silicone for now.
Old 8th September 2008, 20:08   #50 (permalink)
Will not last for too long I'm afraid... I've posted another method some time ago (lift the cowl, support temporarily on pieces of felt and fill the gap with "gasket" silicone). This is a bit fiddly especially the cleaning needed before applying the silicone gasket, but it will last.
Old 8th September 2008, 20:16   #51 (permalink)
Reversing lessons anyone?
Car: 2.2 i-CTDi Type S GT, Milano
I did mine with silicone spray 3 months ago and it still doesnt creak
Old 8th September 2008, 21:46   #52 (permalink)
I wasn't that lucky, so I did it the other way. AFAIK there is also a "factory solution" - a felt mat, but I don't know how well it would work
Old 12th September 2008, 10:04   #53 (permalink)
gray52's Avatar
ive just had mine done by honda, and its now all sorted. make sure the trim at the sides is also done or it will still make some creaking. took it back and its now all sorted.
Old 12th September 2008, 10:07   #54 (permalink)
Good to hear a success story, well done!
Old 13th September 2008, 08:32   #55 (permalink)
Munro's Avatar
Good news , how did they do it ?
Old 13th September 2008, 08:33   #56 (permalink)
Maybe they gave him an Accord or a Jazz instead!
Old 13th September 2008, 10:05   #57 (permalink)
Munro's Avatar
Old 14th September 2008, 21:48   #58 (permalink)
gray52's Avatar
i just told them about it, they were aware and i took them for a spin to here it. no problem we will get it sorted, and they did. i think they had been reading about it on here, so theres no getting out of it
Old 6th November 2008, 15:53   #59 (permalink)
tomo2001's Avatar
Mines just started creaking and cracking. Went to car and moved cowl about and it generates the exact noise I can hear inside the car. Removed cowl completely - 5 min job and cleaned grit from windscreen and cowl itself. Put back on car and no longer makes the noise. Will do a long term fix when time permits. However there was a date sticker on the cowl I guess showing date of build (25.06.0 so even new cars still have the problem. There is a nasty grey foam under the cowl that isn't thick enough so the plastic still rests on the 'screen.
tomo2001 is offline   Reply With Quote
Old 10th November 2008, 13:56   #60 (permalink)
forever_after's Avatar
Glad it worked for you as well Jabba1980 - the loud creak noise sounded terrible.
It is worth opening the bonnet and removing the centre cowl to do the work. Here's the diagram from the manual, with arrows similar to the photos.
Where can I find these schematics?
forever_after is offline   Reply With Quote
LinkBack to this Thread: http://www.civinfo.com/forum/how/11854-how-fix-windscreen-cowl-creaks.html
Forums CivicYume • Afficher le sujet - Nouveau Forumiste nouveau adepte This thread Refback 23rd June 2009 21:08
Civic-FX.net - Forum Honda Civic ab 2006 (FK, FN, FD) • Thema anzeigen - Bekannte Civic-Mängel This thread Refback 13th June 2009 12:19
Civic-FX.net - Forum Honda Civic ab 2006 (FK, FN, FD) • Thema anzeigen - Bekannte Civic-Mängel This thread Refback 4th June 2009 21:41
Civic-FX.net - Forum Honda Civic ab 2006 (FK, FN, FD) • Thema anzeigen - Bekannte Civic-Mängel This thread Refback 20th April 2009 11:16
Civic-FX.net - Forum Honda Civic ab 2006 (FK, FN, FD) • Thema anzeigen - Bekannte Civic-Mängel This thread Refback 16th April 2009 20:25
GODSPEED: '08 Honda Civic Type S+ 1,8 Deep Bronze Pearl - Page 3 - Hondafan This thread Refback 30th March 2009 21:48
GODSPEED:'08 Honda Civic Type S+ 1,8 Deep Bronze Pearl - Page 3 - Hondafan This thread Refback 30th March 2009 20:46
Civic-FX.net - Forum Honda Civic ab 2006 (FK, FN, FD) • Thema anzeigen - Bekannte Civic-Mängel This thread Refback 3rd March 2009 08:59
Civic-FX.net - Forum Honda Civic ab 2006 (FK, FN, FD) • Thema anzeigen - Bekannte Civic-Mängel This thread Refback 25th February 2009 11:29
Forums CivicYume • Afficher le sujet - petits défauts corrigés par Honda. This thread Refback 12th January 2009 08:19
www.clubhondacivic.com :: Ver tema - Crujia la luna delantera This thread Refback 15th December 2008 07:09
FN2 R - Rattles - HondaTech Australia Forums This thread Refback 27th October 2008 13:18
8th Generation Honda Civic Forum - View Single Post - Creaking in my 08 Si Coupe... Driving me crazy! This thread Refback 19th May 2008 18:50
Civic-FX.net - Forum Honda Civic ab 2006 (FK, FN, FD) • Thema anzeigen - Bekannte Civic-Mängel This thread Refback 17th May 2008 18:45
Forum Honda Civic ab 2006 (FK, FN, FD) • Thema anzeigen - Bekannte Civic-Mängel This thread Refback 7th May 2008 10:02
Forum Honda Civic ab 2006 (FK, FN, FD) • Thema anzeigen - Frust wegen Civic-mängel :( This thread Refback 19th April 2008 20:18
Creaking in my 08 Si Coupe... Driving me crazy! - 8th Generation Honda Civic Forum This thread Refback 15th April 2008 01:59
Povrzávání-praskání "st?echy" v pravém rohu(stran?) od ?idi?e-Executive | Honda CIVIC 8. generace This thread Refback 25th March 2008 22:08
Similar Threads for: How To - Fix The Windscreen Cowl creaks.
Windscreen windscreen damage murr04 Bugs, faults and irritations 2 7th July 2007 13:42
Scratched Windscreen adamski Cleaning 11 21st June 2007 12:57
Windscreen Warped windscreen JoeyF Bugs, faults and irritations 6 13th May 2007 13:13
Windscreen About to receive my 3rd windscreen Tony Fendall Bugs, faults and irritations 8 9th May 2007 19:31
Windscreen Kremmen Cleaning 6 15th April 2007 14:31
