#21 (permalink) | |
![]() Car: M200 Type R
Thanks given: 200
Very pleased with mine too, as you say the sound quality is great. I bought it knowing of it's limitations, however I am glad I did. The best bits about installing it yourself are you can take your time and be careful and also the thought you have saved some money. |
#22 (permalink) |
Civic gone, not forgotten
![]() Car: Pug 4007, 308CC, Clio dci
Thanks given: 25
Does anyone else agree that the sound from the ipod is clearer and has more depth than the inbuilt CD player. Weird considering that MP3s are more compressed than CDs.
#23 (permalink) |
![]() Car: Audi A3 1.6TDI Sport Cabrio
Thanks given: 23
Can't say I've noticed, although I always used to use MP3 CD's before I got my iPod connector - And they are the same MP3's as are on the iPod anyway.
I'll have a listen tonight, with an original CD, and the same album from the iPod to see if I can hear any difference. |
#24 (permalink) | |
Thanks given: 200
Check out his post at the end. |
#25 (permalink) | |
Thanks given: 23
The hardwired solution is so much better. I've also tried listening to a normal audio CD, and the same album from my iPod, and whilst there is a difference I couldn't put my finger on what was different - I thought the iPod version was very slightly flatter (which I would expect, with the sound being compressed into MP3), but was also less crashy sounding. The one real difference is about a volume difference of around 4/5 to get the same amount of loudness. (iPod needs say 15/16, where CD is 10/11 for the same volume) Not as bad as the FM transmitter which needed 23/24 on the volume to get the same. |
#26 (permalink) | |
Thanks given: 200
I've never played an original CD in my Civic, I guess I should really just to compare. As I say though I'm really pleased with the ipod connector and glad I got it. |
#27 (permalink) |
Thanks given: 23
Noticed something strange about the display from the iPod connector just now.
If you play a normal audio CD, you get the track number and the time in minutes & seconds. If you play through the iPod, you get playlist & track number, but if you press and hold the seek/skip buttons it displays the time (like it does for an audio CD). It only stays on the display while fast forwarding/rewinding through a track, and none of the buttons let you change the display to this permanently. So there is more display capability than has been implemented I very rarely played audio CDs in the car either - nearly always MP3s. And I never play CDs now, since I got the iPod wired in. |
#28 (permalink) | |
Thanks given: 200
I noticed that a couple of days after I installed it too. Another feature I think is missing, is being able to scroll through the tracks using the dial on the left hand side of the head unit. It works with an mp3 or wma cd and is very useful for finding a track number quickly but not with the ipod. |
#29 (permalink) | |
Thanks given: 25
#30 (permalink) | |
Thanks given: 25
#31 (permalink) | |
Thanks given: 23
However, thinking of getting her a Nano sometime, but couldn't really face re-ripping all my CDs again - my iTunes library has about 7000 songs in it, so 500+ albums! |
#32 (permalink) | |
Thanks given: 25
All CDs I have ripped to iTunes, I have done automatically, so may be AAC format. |
#33 (permalink) | |
Thanks given: 200
It would be very useful if we could quickly search through the tracks within the playlists though wouldn't it? |
#34 (permalink) |
Thanks given: 23
Not quite the quick search that I think you're after - like the left hand knob when playing an MP3 CD - but the 'Scan' button on the headunit plays the first 10 seconds of each track in a playlist - Pressing 'Scan' again cancels the autoscan feature, and will play from that point on in the playlist/album.
#36 (permalink) | |
Thanks given: 200
That's worth knowing, thanks. |
#37 (permalink) |
Thanks given: 5
Hi Guys,
Installed my Ipod connecter today (Carlink - mentioned else where on this site), just want to say THANK YOU to all the guys who have posted write-ups on how to do it Took just over an hour (I work in car diagnostics), worth every minute, sound quality is great! Thanks again guys. Regards R. |
#38 (permalink) | |
![]() Car: 2007 5dr 2.2 i-CTDI EX
Thanks given: 6
All you need to do is highlight all the songs in your itunes library, right click and select convert to AAC. itunes will automatically convert them all for you, it may take some time, but you could leave it going over night!! |
#39 (permalink) |
Thanks given: 23
Yes I could do, although that could result in a drop in sound quality by converting from one compressed format to another. I might try it with a couple of albums first to see if I can hear a difference.
#40 (permalink) |
Civic Coupe EXL. left hand drive, premium radio, no Nav
Ipod adapter, USA Spec PA15HON OK all you psedo technos, You don't have to take the dash apart in a 08 Civic EX or equivalent. Here is what I did. One remove the upper cover in the small cubby to get access to the radio. That's all you have to do. Next feel inside for the back of the radio and you will find an empty connector if you don't have Nav. Next, with a lot of patience and dexterity, monuver the USA Spec connector into place, key side down. Push it into the radio receptacle, it goes in very easy if you have the key correct. Next snake the cable into the glove box - there is an open spot on the top of the box into the area of the radio. Plug in the connector to the USA Spec PA15 Hon, plug in the Ipod connector to the same. Connect the Ipod after setting the snap switches to folder-hydbid. Turn on the radio, select AUX and poof up comes the XM selection on the radio. Next sit back and listen to the music. Steering wheel controls change the songs and display shows Song title and artist. Total time for me 15 minutes. I discovered this buy using an inspection mirror and a flash light and viola there was the back of the radio. |
LinkBack to this Thread: http://www.civinfo.com/forum/how/11955-how-install-honda-ipod-connector.html
| Civic Type-R Owners Club & Forum • View topic - iPod Adapter + SatNav | This thread | Refback | 23rd August 2011 22:22 | |
| Civic Type-R Owners Forum • View topic - iPod Adapter + SatNav | This thread | Refback | 24th May 2010 18:37 | |
| Civic Type-R Owners Forum • View topic - iPod Adapter + SatNav | This thread | Refback | 27th January 2010 19:36 | |
Similar Threads for: How To Install The Honda Ipod Connector
| AUX in Honda Ipod Connector Review | pjr | Ipods, MP3 Players and ICE | 32 | 16th July 2010 22:37 |
| Ipod Connector | pjr | Holdcroft Honda | 15 | 13th July 2008 07:01 |
| Technical Honda Ipod Connector Installation Instructions Wanted | madmallyuk | Ipods, MP3 Players and ICE | 8 | 19th September 2007 17:53 |
| AUX in Honda MusicLink / iPod connector - now discontinued? | paul_b | Ipods, MP3 Players and ICE | 15 | 1st May 2007 23:50 |
| AUX in iPod Connector... | Keat83 | Ipods, MP3 Players and ICE | 2 | 27th February 2007 18:45 |
