Old 26th February 2008, 23:03   #1 (permalink)
pjr
pjr's Avatar
Car: Audi A3 1.6TDI Sport Cabrio
Thanks given: 23
How To Install The Honda Ipod Connector
I installed the official Honda iPod adapter at the weekend, which I had bought from Holdcroft Honda for £129.99
To fit this into your Civic, you do need to dismantle quite a lot of the dashboard as the adapter unit box is mounted on the back of the glovebox (for cars without Nav) or on top of the glovebox (for cars with Nav)
My Civic doesn't have the navigation system so the following steps relate to a non-nav equipped car.
I have to say that the installation manual which came with the kit was pretty comprehensive, with sets of instructions for LHD & RHD cars and the different bit for nav/non-nav equipped cars.
I also referred to the previous how-tos in the following locations to help in stripping the dash, and to save repetition I won't go into all the minute details as these threads cover all the initial dismantling.
To help in removing the dash panels, I used a plastic gap spreader that I already had which was used in fitting a Brodit Proclip into my last car - basically a very thin wedge of plastic which could be pushed into the panel gaps and could be used to lever the panels off without damaging them.
[HOW TO] Get into the dash (Pottsy)
Weak Bass now sorted! Also, pics of the back of the radio (Roger Harris)
How to install an entire ICE system (Swindon Japster)
The following parts of the dashboard need removed before mounting the iPod unit.
Rear Centre console
Drivers Side end of dashboard
Lower panel of dashboard under steering wheel
Silver trim round gearlever
Lower centre console (Removel all covered in Pottsy's thread above)
Panel above radio/vents - I covered the radio/aircon display with duct tape to stop it getting scratched while removing this panel
Radio comes out with 3 screws at top, and two bolts at bottom (Covered in Roger Harris's thread)
There are also two harness clips, one for the hazard warning switch and another for one of the radio cables which need unclipped before the whole headunit can be removed.
Removal of complete glovebox - covered in Swindon Japster's thread.
Once all these bits have been removed (took me about an hour), the installation of the actual iPod kit can begin.
On the back of the glovebox are some fins which need cut off as per the photo below. The lighter grey lines are where the ribs used to be. The iPod adapter fits vertically between these fins. A couple of holes are drilled through the iPod adapter brackets into the glovebox and the adapter is held in place by bolts (covered with plastic caps) screwed through from the glovebox.
The following picture from the installation manual shows the location of the adapter, along with routing of the two cables along the top of the glovebox (held in place by sticky foam covered pads)
The glovebox is then refitted into place, with the cables run through into the space behind the radio (for the cable which plugs into the headunit) and into the space above the centre storage box (for the cable which plugs into the iPod)
The cables for the iPod adapter are cable tied at various locations to the existing wiring harness, just leaving enough cable to reach the back of the headunit and into the storage box compartment.
Next a hole needs made into the top of the centre storage box. The instructions say to use a 15mm holesaw and cut two adjacent circles towards the back left corner of the storage box as per the following photo.
I didn't use a holesaw, but drilled several smaller holes with a 6mm drill and cut & filed roughly the same shape out. This hole is not visible once the installation is complete, and is covered by a rubber grommet anyway.
Here is another picture from the installation manual showing the location of the holes which need drilled.
Next, the headunit is refitted, taking care to connect all the plugs back in, with the iPod cable being connected to the CD changer port. At this point, I plugged my iPod in (before securing the headunit in place) to check that everything was working. Once this test had been done, the radio was screwed back into place, the centre console was refitted and the panels under the steering wheel and across the end of the dashboard were put back.
In all, it took me about 3 - 3.5 hours to fit the whole kit, although I was taking my time particularly during the dismantling as I didn't want to damage any parts of the dashboard.
Thank You to pjr from 2 Users:
Old 26th February 2008, 23:32   #2 (permalink)
Vet_2010's Avatar
Thanks given: 22
Is is actually compatible with sat-nav cars? When I was browsing Holdcroft on ebay I noticed all their i-pod items stated for non-satnav models only? Yet I was offered it as an option when buying the car... maybe there are different versions of the kit?
Looks like a very helpful guide!
Old 26th February 2008, 23:47   #3 (permalink)
pjr
pjr's Avatar
Thanks given: 23
The same kit fits both satnav and non-satnav cars, BUT you need an extra bit of cable for the satnav cars which IIRC is about £90 from Honda. (maybe Holdcroft can do it cheaper ?)
Old 27th February 2008, 17:32   #4 (permalink)
Civic's got Big Booty !
csmcqueen's Avatar
Our instead of the riduculous Honda part get this one, and save £70
HON03-F/MM - PIE HON03-F/MM (08A31-0F1-000) 2003-Up Honda Y-Adapter Cable - Accessories - Precision Interface - Discount Car Stereo.com - Detail
Not this weekend but the next, Im going to fit mine in after buying this cable
csmcqueen is offline   Reply With Quote
Old 23rd July 2008, 22:03   #5 (permalink)
Red Rocket Man
Chalks's Avatar
Car: Milano CTR GT
For the record I was quoted £29 + VAT for the official Honda Y-splitter by my local Honda dealer.
Chalks is offline   Reply With Quote
Old 12th August 2008, 20:07   #6 (permalink)
Car: M200 Type R
Thanks given: 202
Thanks for the 'How to' pjr, I'll be trying it out this weekend. I'll let you know how I get on.
Old 12th August 2008, 20:28   #7 (permalink)
pjr
pjr's Avatar
Thanks given: 23
You'll be fine. Just take your time dismantling the dash so you don't break or scratch anything. It goes back together much easier - honest
Old 12th August 2008, 20:41   #8 (permalink)
Car: M200 Type R
Thanks given: 202
All I need now is for it to stop raining
Old 14th August 2008, 23:30   #9 (permalink)
Car: M200 Type R
Thanks given: 202
Ipod kit arrived today and I installed it this evening. Took about 3 hours.
Thanks Pottsy and pjr for the excellent 'How to', they were really useful. I have to say however the Honda supplier instructions were very clear and concise too.
Old 14th August 2008, 23:50   #10 (permalink)
pjr
pjr's Avatar
Thanks given: 23
Good news - glad to be of assistance. Think it took me about the same length of time.
Thanks to pjr from:
Old 15th August 2008, 00:01   #11 (permalink)
Car: M200 Type R
Thanks given: 202
The interior does look very sad when you have it stripped. You do think 'Oh my God, what I am I doing???' when everything is out.
Thanks again.
Old 15th August 2008, 08:55   #12 (permalink)
Civic gone, not forgotten
alanwalne's Avatar
Car: Pug 4007, 308CC, Clio dci
Thanks given: 25
You lot are braver than me.....
Old 15th August 2008, 10:48   #13 (permalink)
hurricane's Avatar
Car: 2008 1.8i SP LHD, Milano Red
Thanks given: 4
I have to say that the guides on here and Honda's own instructions really helped me to install mine the other day. It also took me 3 hours - that's spooky!
As for my dealer, when I originally asked how much it would be to fit the kit, they could'nt give me a price as they had never done one before! I quickly decided that they were not going to practice on mine!
hurricane is offline   Reply With Quote
Old 15th August 2008, 10:52   #14 (permalink)
Car: M200 Type R
Thanks given: 202
Even if a Honda technician could do it in half the time, at the labour rates they charge, it would still be about £100.
So it was a worthwhile 3 hours I think.
Old 15th August 2008, 11:16   #15 (permalink)
pjr
pjr's Avatar
Thanks given: 23
£100 would be about right - that, plus the £130/£140 for the kit comes pretty close to the £250 that Honda would charge for it fitted.
I took the view that my time was free, so however long it took was ok.
Old 15th August 2008, 14:34   #16 (permalink)
hurricane's Avatar
Thanks given: 4
Well those nice chaps at Honda sent me the kit for free (along with another iPod Touch - still for sale if anyone wants) so I figured that if it was going to be cheap to install I would pay for it, but as they didn't even know how to do it, that was a no brainer!
Looking back I enjoyed doing it myself - gives a nice "bonding" feeling when taking bits apart and putting them back together. or am I just wierd?
Old 16th August 2008, 18:36   #17 (permalink)
Car: M200 Type R
Thanks given: 202
Weirdo!!!
No, I know what you mean, it is quite satisfying to know you installed it yourself and that you deprived the dealer of at least some of your money.
Old 16th August 2008, 18:48   #18 (permalink)
Ipod kit arrived ok then dimplyred? Hope you had fun fitting it. Doing the footwell lights were bad enough.
u05rdh is offline   Reply With Quote
Old 16th August 2008, 19:23   #19 (permalink)
Car: M200 Type R
Thanks given: 202
Yes it did, thanks very much.
TBH I meant to pm you to tell you it had arrived safely, sorry.
Old 25th August 2008, 16:45   #20 (permalink)
Red Rocket Man
Chalks's Avatar
Car: Milano CTR GT
Did mine yesterday - took 5.5 hours, with rain breaks. Had no screws left in the pot when I'd finished and inflicted no damage to the car. My hand suffered 2 cuts though. Very pleased with my efforts.
The problems I had were not really knowing how hard to pull or push things to get them off and back. It takes a leap of faith sometimes !
From my experience I would add two things to the knowledge base:
1) Mark the driver's seat and back position with duct tape on the base runner and doorframe so that you can get your perfected driving position back quickly on completion.
2) Don't bother to remove the gear knob - the boot is held to the cover with three easily removed screws. The boot can then be wrapped over the gear knob to protect it.
Sound quality is fabulous and that's the bottom line. No FM transmitter comes close.
LinkBack to this Thread: http://www.civinfo.com/forum/how/11955-how-install-honda-ipod-connector.html
Civic Type-R Owners Club & Forum • View topic - iPod Adapter + SatNav This thread Refback 23rd August 2011 22:22
Civic Type-R Owners Forum • View topic - iPod Adapter + SatNav This thread Refback 24th May 2010 18:37
Civic Type-R Owners Forum • View topic - iPod Adapter + SatNav This thread Refback 27th January 2010 19:36
Similar Threads for: How To Install The Honda Ipod Connector
AUX in Honda Ipod Connector Review pjr Ipods, MP3 Players and ICE 32 16th July 2010 22:37
Ipod Connector pjr Holdcroft Honda 15 13th July 2008 07:01
Technical Honda Ipod Connector Installation Instructions Wanted madmallyuk Ipods, MP3 Players and ICE 8 19th September 2007 17:53
AUX in Honda MusicLink / iPod connector - now discontinued? paul_b Ipods, MP3 Players and ICE 15 1st May 2007 23:50
AUX in iPod Connector... Keat83 Ipods, MP3 Players and ICE 2 27th February 2007 18:45
