This thread is about: [HOW TO] Install non OEM parking sensors - and save £250!!!!, it's in How To at the Honda Civic forum Civinfo; Ok thanks for everyone's help! Managed to get (most) of the sensors in! I bought the Steel-mate ones and have to say was very happy ...
Old 8th July 2008, 16:16   #121 (permalink)
iamholam's Avatar
I bought the Steel-mate ones and have to say was very happy with the feel and quality of the unit and sensors, speaker looked pretty good too! Only problem I find with the Steel-mate's are that the speaker is a little shrill.
Only problem was that one of the sensors was faulty so despite taking all day to do the thing I still haven't finished as I am waiting for a replacement sensor before fitting the bumper properly back on.
Thanks for your help. I only broke 2 of those bloody clips!
Old 31st July 2008, 20:32   #122 (permalink)
Could some one please give me a better example of where to connect the wires, I understand the ground, but exactly where does the other wire go to?
The reversing light wire.... were is it? what colour?
I have the dolphin buzzer version Parking Sensors - To Aid Reverse Parking
Paul-civic is offline   Reply With Quote
Old 31st July 2008, 20:37   #123 (permalink)
Found the answer, sorry.
Near the rear drivers seat belt Connect red wire( parking sensor) to the Brown wire (Honda)
Old 2nd August 2008, 13:13   #124 (permalink)
Question 2 Quick question with rear wheel arch - parking sensors
I am going to fit my PARKING SENSORS tomorrow, everywhere is says partially remove the Right Hand side wheel arch, surely I will have to release the left as well, won't I?
To remove the bumper stand at the rear of the car push the bumper forward and at the same time outwards, is that correct?
I see these as the two most difficult to fully understand, so any help will be appreciated, thanks
Paul
Old 4th August 2008, 11:24   #125 (permalink)
iamholam's Avatar
Yes you will, just do the same as you would on both sides
Paul
The clips that hold the bumper in on the sides are clipped in by pushing the bumper towards the centre of the car. So to remove it you have to pull away from the car. (Away as in outward to the side not backward towards the rear of the car) You push towards the front of the car to help loosen the clips. If you work from the bottom you should be able to take the first one out and get a better view of the rest.
I do have a pic of the bumper off which I can upload for you later tonight if you want.
Old 7th August 2008, 23:55   #126 (permalink)
iamholam's Avatar
bit late I know but here is a picture of the back off the civic with the bumper off.
The 3 red marks point to the clips that hold the bumper in place. I should have take a pic of the removed bumper but you should be able to see a number of clips that hold the bumper in place. The idea behind pushing the bumper forward is so that the bumper "un hooks" from these clips before you pull the bumper off.
Hope that's a little clearer.
Old 26th August 2008, 13:52   #127 (permalink)
Tomorrow, I'll like to install my PDC-System. If someone needs special pictures of the installation let me know, then I'll take some more with my Cam.
Lebowsky is offline   Reply With Quote
Old 26th August 2008, 16:30   #128 (permalink)
sandz's Avatar
Pictures are allways nice.
sandz is offline   Reply With Quote
Old 27th August 2008, 15:09   #129 (permalink)
Here are some pictures of my installation. The system is working perfect
Old 27th August 2008, 16:42   #130 (permalink)
JoeyF's Avatar
Sorry just seen this post, just to let you know the speaker fits very nicely by the drivers side foot well (Behind the carpet on the side of the wheel!), the wire is just long enough to slide under the trim from the rear to the front just along where the door sills sit.
It sounds enough for you to hear it plus it can not be seen.
Old 4th September 2008, 09:29   #131 (permalink)
Eutai's Avatar
Check this out:
No-Drill Parking sensors
Eutai is offline   Reply With Quote
LinkBack to this Thread: http://www.civinfo.com/forum/how/1202-how-install-non-oem-parking-sensors-save-250-a.html
Parking sensors on a Civic - Type R Owners Forums This thread Refback 3rd June 2008 20:30
Similar Threads for: [HOW TO] Install non OEM parking sensors - and save £250!!!!
Parking Parking Sensors Knat Electronics 32 Today 15:15
Exterior parking sensors panasony Bugs, faults and irritations 8 23rd January 2007 20:44
[HOW TO] Install Honda OEM parking sensors Pottsy How To 7 26th November 2006 16:55
Parking Parking sensors PTR Electronics 18 9th October 2006 18:13
Other Parking Sensor Install basegreen Gallery 3 31st May 2006 00:07
