This thread is about: [How To] Get a Nokia 6680 working with the Civic EX HFT, it's in How To at the Honda Civic forum Civinfo; I know that this is not affecting many but thought I would pop up a little how to. The Nokia 6680 seems to have a ...
Old 27th September 2006, 18:55   #1 (permalink)
Maldax's Avatar
The Nokia 6680 seems to have a problem with the EX HFT in that when you finish a call the bluetooth connection is lost. Then phone still thinks it is connected but the HFT drops the phone
I have found a little 'work round' the means to need to press 4 buttons on your phone to reconnect and it seems to work fine so here goes
To speed things up assign Bluetooth to one of your soft keys I have assigned it to the up arrow
Press Menu | Tools | Settings | Phone | Then Select it
Then Select Standby mode, move down to Navigation key up and press select
then select Bluetooth
Thathas now set you up navigation key to take you straight to the Bluetooth menu to speed things up
Now when the HFT drops the Bluetooth connection when you end a call just press
Up | Select | Yes | Select
Far from ideal but seems to work, and before people start saying Honda should sort it out! I think the problem rests firmly with Nokia
Old 27th September 2006, 23:43   #2 (permalink)
Ancient Nerd's Avatar
Some of the older Nokia phones didn't conform to the bluetooth standard very well. The 6310 that I had was one of these, I don't know about your 6680 Maldax.
The result was that I had trouble with all sorts of devices (well PC and earpiece) trying to get them to pair reliably. I gave up in the end and stuck to cable connections.
Subsequent Motorola V600 and Nokia N70 were no trouble at all, once I'd read the manual (if all else fails ... )
Similar Threads for: [How To] Get a Nokia 6680 working with the Civic EX HFT
Windscreen Windscreen washer jet not working Hondaneer Bugs, faults and irritations 12 17th June 2008 11:29
Electrics Rev Indicator Not Working ??? surfdog29 Electronics 17 5th October 2007 10:57
AC/Heater air con not working middypusss Electronics 3 28th June 2007 09:54
PM not working? Bungle Site suggestions, feedback and rules 7 13th October 2006 08:03
Phone Nokia 6680 thanksdenis Electronics 2 4th August 2006 13:21
