This thread is about: Aux-in how-to 4 door, it's in How To at the Honda Civic forum Civinfo; I'm following this guide from a US 8th gen civic site. It shows how to make a homemade aux-in cable that put in the civic ...
LinkBack (18) Thread Tools
Old 4th May 2008, 17:04   18 links from elsewhere to this Post. Click to view. #1 (permalink)
JDM all the way!
zippyijk's Avatar
It shows how to make a homemade aux-in cable that put in the civic (my 06 4dr, doesn't have one).
I first pulled my dash apart to get the HU (brute force stylee )
When I got it out I found the CD changer was using the connection I needed, so the cable I had made wouldn't fit. (The connection is the 20pin B connection)
So what I need to know is how can I get a connector block like the 20 pin one so I can make the cable fit?
I've added the guide I used to make the cable for reference (by the way all credit for it goes to chok on 8thCivic.com)
Click the image to open in full size. AUX for non US model
1. Get the cable as shown in the fig. or any cable you can find. The cable I used is the one that came with the optical drive for PC. The cable is just fit the connector of the head unit. So it is really easy, no soldering needed.Click the image to open in full size.
2. Here is the pins assignment from Honda taken from Civic-EU model (this would be the same for all Civic as it exactly the same for my Civic-Thailand model)
B3 = AUX SGND (ground for the signal)
** = AUX SH GND (shielding ground for preventing the signal interference from other devices)
B5 = AUX GND (AUX detection wire for switched type female jack)
B13= AUX L (Left signal)
B14 =AUX R (Right signal)
B15 = AUX DET (AUX detection wire for switched type female jack)
I'm really sure about the pins assignment but I'm not sure about the function of those pins.
3. This step you need one CD-Rom cable with a socket taken from another cable. Route the wires as shown in the fig.
4. This step will finish the AUX cable but you would think about where to place this thing in your car. So you should skip this step and go to step#5-6 then get back to complete this step.Click the image to open in full size.
Connect the other end to the mini-jack cable by inserting three pieces of hard wire between those female socket. Now you are done with the AUX cable. Click the image to open in full size.
5. I would suggest you to hide this cable in the transmission pocket. Remove the pocket and route the wire as shown in fig.Click the image to open in full size.
6. Route the wire as shown in fig. Then go to step#4
Congratulation! you now have the AUX.
zippyijk is offline   Reply With Quote
Old 8th June 2008, 12:52   #2 (permalink)
Instructions for removing the center panel (Not brute force style...)?
psychocrackpot is offline   Reply With Quote
Old 10th June 2008, 16:24   #3 (permalink)
bearyslow's Avatar
Hey zippyijk,
I've tried your method on my 3dr Civic (FN2), dun seem to work. Even when I connect B5 and B15 together, I can't get my AUX to work. Did it work for you??
bearyslow is offline   Reply With Quote
Old 12th June 2008, 20:09   #4 (permalink)
jj69's Avatar
Very strange ... the actual cd changer / aux input is supposed to be on connector C.
There mus be a difference between the hatchback HU and the sedan HU.
Not surprised it doesn't work on your 3dr bearyslow
jj69 is offline   Reply With Quote
Old 13th June 2008, 08:33   #5 (permalink)
teletxt's Avatar
The 4D HU is a 6 cd changer in the ES , the 5D HU is a mono cd player.
teletxt is offline   Reply With Quote
Old 17th June 2008, 12:24   #6 (permalink)
jj69's Avatar
I'm lost here !
I knew I had already seen the diagram showing the back of the HU ... its in the HowTo section, it's supposed to be the back of a 5D with satnav !
So my question is :
Is the howto targeted for 4D only ?
zippyijk, could you post a link to the original site ?
Old 25th June 2008, 16:48   #7 (permalink)
JDM all the way!
zippyijk's Avatar
Originally Posted by jj69 View Post
I'm lost here !
So my question is :
Sorry Guys for the delay in reply, been very busy with moving house and working nights for a while.
The 4dr only comes in one spec, called SE-S
The 6cd changer is in the HU on this model (i.e. its all one unit).
When you take the dash apart there are cables connected to A, B, & F. There is nothing connected to C.
I pulled out the cable from B (which only had 2 wires in it....incedentially I found out these are for the power to the steering wheel buttons)
Then I connected the cable exactly as in the diagram (note I got it wrong the first time as I had my head in over the dash and was looking at the unit backwards.....bad explantion )
It works perfectly, here are some pics below.
Psychocrackpot I've attached a pdf with instructions for removing the HU.
Original Site: Pinout for Aux Input on LX - 8th Generation Honda Civic Forum
(Its on page 4 iirc)
LinkBack to this Thread: http://www.civinfo.com/forum/how/13980-aux-how-4-door.html
segnale video esterno - Pagina 9 - HONDA CIVIC TEAM This thread Refback 21st June 2009 10:26
Civic-FX.net - Forum Honda Civic ab 2006 (FK, FN, FD) • Thema anzeigen - Lösung I Pod Adapter This thread Refback 2nd June 2009 05:40
Civic-FX.net - Forum Honda Civic ab 2006 (FK, FN, FD) • Thema anzeigen - Lösung I Pod Adapter This thread Refback 20th May 2009 16:35
segnale video esterno - Pagina 10 - HONDA CIVIC TEAM This thread Refback 7th May 2009 22:29
Civic-FX.net - Forum Honda Civic ab 2006 (FK, FN, FD) • Thema anzeigen - Lösung I Pod Adapter This thread Refback 2nd April 2009 09:21
Civic-FX.net - Forum Honda Civic ab 2006 (FK, FN, FD) • Thema anzeigen - Car-PC an Soundanlage anschließen? This thread Refback 28th February 2009 23:15
Civic-FX.net - Forum Honda Civic ab 2006 (FK, FN, FD) • Thema anzeigen - Lösung I Pod Adapter This thread Refback 25th February 2009 20:20
Pinout for Aux Input on LX - Page 6 - 8th Generation Honda Civic Forum This thread Refback 30th January 2009 20:21
Khôi phục hệ thông AUX (audio input) cho Civic - Page 2 - Otofun Forums This thread Refback 3rd January 2009 16:45
Civic-FX.net - Forum Honda Civic ab 2006 (FK, FN, FD) • Thema anzeigen - Car-PC an Soundanlage anschließen? This thread Refback 20th November 2008 13:19
Civic-FX.net - Forum Honda Civic ab 2006 (FK, FN, FD) • Thema anzeigen - Lösung I Pod Adapter This thread Refback 7th November 2008 08:12
www.clubhondacivic.com :: Ver tema - Se puede hacer una Aux de esta forma? This thread Refback 6th September 2008 16:03
Pinout for Aux Input on LX - Page 4 - 8th Generation Honda Civic Forum This thread Refback 9th July 2008 23:52
Civic-FX.net - Forum Honda Civic ab 2006 (FK, FN, FD) • Thema anzeigen - Car-PC an Soundanlage anschließen? This thread Refback 4th July 2008 07:04
www.clubhondacivic.com :: Ver tema - Posible entrada auxiliar por RCA o minijack, radio de serie. This thread Refback 24th June 2008 19:34
Nút AUX trên táp lô dùng nh? th? nào? - Page 2 - Otofun Forums This thread Refback 24th June 2008 17:33
Khôi phục hệ thông AUX (audio input) cho Civic - Page 2 - Otofun Forums This thread Refback 22nd June 2008 16:43
??u 6 ??a c?a civic This thread Refback 21st June 2008 01:53
Similar Threads for: Aux-in how-to 4 door
Squeaks Removal Of Door Trim On 4 Door Green Hornet Bugs, faults and irritations 1 29th January 2008 10:03
Damage New Door.... gocallaghan Bugs, faults and irritations 14 22nd January 2008 19:00
Door 'dinked' by another door - help! SandGirl Cleaning 11 28th December 2007 07:32
5 Door Civic - Original Door garnish Doubtingthomas For sale and Wanted 9 3rd October 2007 19:37
5 door R czechplastik Type-R 20 12th September 2007 14:51
