| This thread is about: How to install Splitters, it's in How To at the Honda Civic forum Civinfo; Tools required Flat screw driver Philips screw driver 10mm socket & ratchet microfibre cloth First thing is to take the clip and screw out from ... | ||
HACKIN & SLAYIN
Tools required
Flat screw driver Philips screw driver 10mm socket & ratchet microfibre cloth First thing is to take the clip and screw out from underneath the joint of the wheel arch & loer bumper. Pull them apart both sides. ![]() Unscrew the inner wheel arch both sides ![]() Take out the clips from the underside of the bumper and save all clips.Now start to remove the wheel arch trim by squeezing the clips from behind & pushing them through, puthe microfibre behind it as you go. there is 1 large clip witch is very tight . I squeezed it then hit with pliers to get it out. unscrew the philips screw holding them toether out. ![]() Remove the caps covering the 4 bolts holding the bumper on . ![]() now gently start to shake the bumper loose , if you have parking sensors you will need todisconnect before the bumper will come right off. Plaace bumper on to a sheet to stop it getting scratched. Unbolt the exhaust trims and save the bolts ![]() ![]() Unscrew the reflectors & save. Now the 3 clips holding the bumper together are removed & saved. ![]() The bumper will now unclip from both sides. Now clip the new part in and do this in reverse ![]() Last edited by illegalhunter; 17th May 2008 at 23:36. |
Thanks to illegalhunter from:
| Splitters on the way | illegalhunter | Type-R | 27 | 15th August 2008 00:59 |
| Splitters - Type R - Pricing? | -=Stella Artois=- | Holdcroft Honda | 23 | 6th June 2008 16:46 |
| Front/Rear Splitters... | Big Slick | Type-R | 21 | 12th August 2007 12:38 |
| Standard Type R splitters. | whoopy73 | Type-R | 19 | 25th July 2007 10:07 |
| My install my new ICE - install | VaTaR | Ipods, MP3 Players and ICE | 9 | 6th January 2007 08:16 |
