| This thread is about: How to install front splitter, it's in How To at the Honda Civic forum Civinfo; Tools required flat screw driver philips screw driver 10mm sockect & ratchet First unscrew & unclip the wheel arch from the front bumper 2 clips ... | ||
HACKIN & SLAYIN
Tools required
flat screw driver philips screw driver 10mm sockect & ratchet First unscrew & unclip the wheel arch from the front bumper 2 clips 1 screw on each side. ![]() There is a clip holding the inner ach in place remove this to allow access the arch clips. Now loosen the clips holding the wheel arch trim as before on the rear. Unscrew the philips holding the bumper to the wing. remove the 2 bolts from underneath the front of the bumper along with the clips and save ![]() Remove the number plate and the screw behind it. The bumper is now free, slowly start to gently pul the bumper from 1 side and it will un clip. You will need to disconnect the fogs if you have them. Put the bumper onto a sheet . Remove the clips holding the 2 parts together ![]() The new splitter will clip back into place , start from the middlework out the way. then do in reverseto finnish to end up with this . You have just saved £280 , have fun |
Thanks or this, I want the new splitter, I'm gonna have to wait till i get some spare cash to justify buying them and with this how to I think I'll have a pop myself.
is that a std type r front splitter or after market jobby can you give me the part no if its a after market please because it look quite driffrent to my type r
LinkBack to this Thread: http://www.civinfo.com/forum/how/14363-how-install-front-splitter.html
| www.clubhondacivic.com :: Ver tema - Antinieblas en el Kit GP | This thread | Refback | 28th May 2008 06:04 | |
| Brand New Fn2 Front Splitter & Mesh | chippyleigh | For sale and Wanted | 7 | 23rd September 2007 07:42 |
| DIY Front/Rear Splitter pack - possible ? | MoOriginal | Type-R | 0 | 26th June 2007 09:35 |
| Does anyone have front splitter kit on a black FN2 | MoOriginal | Type-R | 2 | 13th May 2007 21:48 |
| Front Splitter/Spoiler | Toonman | Cleaning and Styling | 5 | 16th September 2006 19:09 |
