This thread is about: Tip for getting to the accessory socket, it's in How To at the Honda Civic forum Civinfo; Perhaps you'll find this tip of use... I have found that I can access the accessory socket without having to remove the centre console. I ...
Old 22nd June 2008, 10:44   #1 (permalink)
spile's Avatar
I used a screwdriver to carefully lever the sock up. It lifted easily about 5mm before it became trapped by a small C-shaped tab. I managed to carefully push this in using the screwdriver and by gently lifting the socket to one side I was then able to remove the socket from the hole.
No damage to the socket or surround and a lot quicker than having to remove the console.
spile is offline   Reply With Quote
Old 22nd June 2008, 11:16   #2 (permalink)
Type R GT (R-8065)
SHADEMASTER's Avatar
Another handy way to remove the accessory socket is to buy a Tom-Tom 520, when pulling out the charging plug the accessory socket comes out where you want it to or not
SHADEMASTER is offline   Reply With Quote
Old 24th June 2008, 15:00   #3 (permalink)
happened to me as well !
avboothroyd is offline   Reply With Quote
Old 29th June 2008, 19:24   #4 (permalink)
kahmed87's Avatar
Location: Newcastle Upon Tyne whilst at uni and Gtr Manchester the rest of the time ENGLAND
me too
kahmed87 is offline   Reply With Quote
Old 29th June 2008, 19:59   #5 (permalink)
Dave25's Avatar
and mine , obviously designed that way for easy access
Dave25 is offline   Reply With Quote
Old 30th June 2008, 07:13   #6 (permalink)
It is so easy to remove the centre console, cut the wires to the ciggy lighter, use a pair of chocky block style connectors, and then wire in another power socket that can be firmly attached.
Not having a portable SatNav I positioned mine in the glovebox.
Old 17th August 2008, 21:24   #7 (permalink)
TYPE R MAN's Avatar
To remove the center console,
remove the 4 caps either side and then 4 x 8mm screws.
Lift the rear end of the console up and a slight tug at the front and away she comes.
TYPE R MAN is offline   Reply With Quote
Old 17th August 2008, 21:34   #8 (permalink)
Pics here: Info - getting in to the dash - Civinfo Wiki
Old 16th September 2008, 23:42   #9 (permalink)
my ciggy lighter came partially out when I pulled my satnav power lead out when I got home from the dealer after having picked my car up!!
It's on a small list of niggles that I'll phone them about soon.
At least it's not just me.
sixgun is offline   Reply With Quote
Old 17th September 2008, 11:55   #10 (permalink)
kahmed87's Avatar
mine did this as well i took it back and they have sorted it now
Old 17th September 2008, 12:10   #11 (permalink)
Who needs a 4x4??
alanwalne's Avatar
In case they tell you that it was caused by plugging in a 'non Honda accessory', mine was pulled loose by the Honda tyre compressor.
alanwalne is online now   Reply With Quote
Old 17th September 2008, 12:32   #12 (permalink)
Newton Honda
NH Dan's Avatar
And be careful that you dont break/damage them. At almost £8 each, yes EACH, they aint cheap to replace.
Old 17th September 2008, 13:06   #13 (permalink)
I'm sure that's a mis-price that's stuck ?
When I drilled my centre console seat heater blanks to insert the Tm button I got a replacement first.
That is larger and contains more plastic but only cost a couple of quid.
I reckon whoever priced them up based it on the full set in a placky bag but it got translated into each ?
Old 17th September 2008, 13:15   #14 (permalink)
Newton Honda
NH Dan's Avatar
i checked it for one of the guys on here earlier in the year as thats what we thought but thats what it came up as on the system. Maybe Holdcroft can confirm???
Old 17th September 2008, 13:23   #15 (permalink)
Who needs a 4x4??
alanwalne's Avatar
Parts prices are a joke!!!!
Has anyone (with a Honda system and too much time on their hands) worked out how much it would cost to buy a civic bit by bit?
Old 17th September 2008, 14:46   #16 (permalink)
Newton Honda
NH Dan's Avatar
dont ask. but if you did, imagine the cost to build when you add in the labour costs!!!
Old 17th September 2008, 14:54   #17 (permalink)
I can confirm that this is the 'Honda' price as I got more than one reply to an earlier request.
I reckon Honda mis-priced ?
Dear Mr Honda.........
Old 17th September 2008, 15:25   #18 (permalink)
Who needs a 4x4??
alanwalne's Avatar
Remember the full Honda price for the spare wheel is about £500.....
Old 17th September 2008, 15:35   #19 (permalink)
What !
Old 17th September 2008, 16:48   #20 (permalink)
Holdcroft Honda
Holdcroft_Honda's Avatar
Them caps are about £8 each I've done a few on here already.
A few years ago we did start to build a Civic 5 door from scratch on the EPC. We got a bit fed up after three days and £6,000,000 and decided to leave the other 6/8ths of the car alone. That was back in 2003/4 IIRC.
Holdcroft_Honda is offline   Reply With Quote
2 thanks to Holdcroft_Honda from:
Similar Threads for: Tip for getting to the accessory socket
Electrics Cigarette Lighter Socket garytheobald Electronics 7 12th March 2008 07:40
Electrics Cigarette socket to usb FWH Electronics 2 5th November 2007 11:44
Electrics Rear 12v power socket fennj Electronics 6 30th October 2007 21:19
Other Unknown socket user4589 Ipods, MP3 Players and ICE 5 12th October 2007 23:16
AUX in 3.5 mm Aux In Socket? andysimmonds Ipods, MP3 Players and ICE 4 18th April 2007 09:51
