This thread is about: [HOW TO] Get into the dash, it's in How To at the Honda Civic forum Civinfo; I'm going for my first DIY attempt with my Civic this weekend, as I'm going to try and install a Parrot HFT . Is it ...
Old 11th January 2007, 22:19   #21 (permalink)
KE_DK's Avatar
I'm going for my first DIY attempt with my Civic this weekend, as I'm going to try and install a Parrot HFT. Is it possible to fit the ISO2CAR cable with the disassembly in the steps of this guide, or do I need to remove the center console also ?
The cable I'm going to fit is like the one Meino has used here: http://www.civinfo.com/forum/showpos...22&postcount=5
Also, as my car is a left hand vehicle, what do I need to be aware of in respect to this guide ?
I'm really looking forward to have this kit fitted, but I am a bit worried about the dismounting process ..
Sorry for my presumably poor English skills. As you probably have noticed English isn't my native tongue.
KE_DK is offline   Reply With Quote
Old 12th January 2007, 06:16   #22 (permalink)
mute cable
Can someone (who installed a HF) tell me, what is the color of the mute wire on the original connector? According to my informations it should be a yellow one, but I think it can be easily checked if someone has an ISO2CAR cable.
Thanks in advance.
Brucez
brucez is offline   Reply With Quote
Old 12th January 2007, 06:55   #23 (permalink)
Meino's Avatar
It should be possible to do it without removing the center console (the radio itself), but it could be a bit tricky... When the dash is removed using this howto you can look under the radio and see the connectors, but I don't know if it is easy to unplug the connectors and connect the ISO2CAR cable.. I have removed the center console which is pretty easy and which makes it much easier to connect the cables.
Meino is offline   Reply With Quote
Old 12th January 2007, 07:40   #24 (permalink)
KE_DK's Avatar
Thanx, for your reply. I will try it out this weekend.
Any hints to my question regarding left hand drive vehicles as opposed to this howto being for a right hand drive vehicle ?
Old 12th January 2007, 08:03   #25 (permalink)
Meino's Avatar
I have a left hand drive vehicle too and succeeded using this howto. It's all the same, only at the other side
So drivers side = drivers side.. (or right = left)... Sounds a bit weird..
Old 12th January 2007, 20:40   #26 (permalink)
honda4ever's Avatar
Hello,
I connected the iso-cable without taking the radio-unit out of the dash.
I think it's better to take out the radio if you want to install the parrotkit with that little screen or gps. See the install on Meino's car.
I preferred to install the microphone at the left side (not on the dash)
See pics included.
I wish you great luck with your installation !
honda4ever is offline   Reply With Quote
Old 12th January 2007, 22:14   #27 (permalink)
KE_DK's Avatar
Thanx for all your kind replys.
Honda4ever: The install you made looks ace..
I am thinking about placing the control unit somewhat like you have. I just want to remove the ashtray and install the control unit below the "sliding part" so that it cant be seen from outside of the car, when the slider is closed. (mine is a LS 3200 Colour) - Like Meino's but without the GPS..
How about the microphone cord, is it easy to put it away like you have done ? - any hints ?
I will post pics when I am done ..
Old 13th January 2007, 13:40   #28 (permalink)
honda4ever's Avatar
The microphone was the easiest part of the installation.
You have to pull away the rubber at the door's side.
Lead the microphonecable between the carbody and the interior.
It's done in five minutes.
Old 13th January 2007, 15:40   #29 (permalink)
KE_DK's Avatar
Thanx a lot.
Thanks to Potsy for making this howto and thaks to all of you that have helped me and a lot of others I'm sure.
This site is priceless.
Old 13th January 2007, 17:09   #30 (permalink)
gsyme's Avatar
Just adding two bits of advice to the above:
1. To take the top off the dash I used a nylon spatula from the kitchen and worked at the soft part of the dash so as not to mark the hard plastic (see photo)
2. To take the end off the dash it is easier if you prise from the top using the soft part of the dash as your fulcrum (do you like that) again so as not to leave a mark. (see photo)
gsyme is offline   Reply With Quote
Old 14th January 2007, 02:21   #31 (permalink)
daiashthomas's Avatar
what does it look like under the top part of the dash in the 1st photo which you are using the spatula on ?
daiashthomas is offline   Reply With Quote
Old 14th January 2007, 11:12   #32 (permalink)
gsyme's Avatar
It is just a moulding that covers the screws for the display and for the stereo. In the photo I have removed the three screws that hold the stereo.
Old 14th January 2007, 11:14   #33 (permalink)
gsyme's Avatar
In the photo above the slots that you can see are for the push fit clips that hold in the cover!
Old 14th January 2007, 14:44   #34 (permalink)
generationgav's Avatar
How did you get to the back of the HU? Just remove the "top bit"?
I want to see if I can get the ipod link without the CD Changer cable, I know to fit it I'd prob have to remove the dash though...
Old 14th January 2007, 18:03   #35 (permalink)
gsyme's Avatar
I followed Pottsy's instructions and took the dash apart as I could not at any stage get at the back of the head unit. I did wonder what the access would be like if I took off the cover below the glove box but having the instructions from Pottsy I just followed them!
Old 15th January 2007, 07:41   #36 (permalink)
Meino's Avatar
I think I am going to replace the mic, cause sometimes (when driving on motorway) people can't here me very clear. Probably because the distance of the mic.. So Honda4ever's setup of the mic is probably the better way as I did.
Old 12th March 2007, 10:06   #37 (permalink)
I'm going to connect the connects2 cable some point in the next couple of weeks. Once I've got to the end of Pottsy's guide, do I then need to remove the stereo too or is that it?
Old 12th March 2007, 10:12   #38 (permalink)
Yes, you need to remove the stereo. I've tried to put all the articles together in the wiki - have a look there!
Old 12th March 2007, 11:10   #39 (permalink)
Cheers Pottsy! I did have a look at the Wiki and it's great; just wasn't sure if the last step (taking the top panel off and removing the screws there) was completely necessary or if you could just get your hand up & plug the cable in! If anyone wants more pics or info as I do mine then please tell me.
Old 12th March 2007, 14:38   #40 (permalink)
Power_of_Dreams's Avatar
for access to any part of the HU...the console has to be removed as shown.
Power_of_Dreams is offline   Reply With Quote
LinkBack to this Thread: http://www.civinfo.com/forum/how/154-how-get-into-dash.html
Cenre Console flap/lid - HondaTech Australia Forums This thread Refback 8th May 2008 06:23
Honda Club Belgium :: Bekijk onderwerp - civic 2007 radio This thread Refback 20th November 2007 22:27
Similar Threads for: [HOW TO] Get into the dash
Interior Dash lighting during the day. The Phantom Lights 11 12th July 2007 12:40
Galaxy Dash board pics, Type R dash fitted to EX! Ham'sCivic Gallery 3 15th April 2007 17:53
Trim Dash Getting Hot geoff Bugs, faults and irritations 5 19th January 2007 20:59
Dash heysidays General Discussion 3 22nd December 2006 12:37
Cleaning the dash Velocity Cleaning 7 14th November 2006 12:55
