| This thread is about: [HOW TO] Do dashboard self-diagnostic, it's in How To at the Honda Civic forum Civinfo; Are you sure? From memory, it goes: Position 0: Off Position 1: Sidelights/Position lights Position 2: Auto Position 3: Headlights... | ||
LinkBack (5) | Thread Tools | Display Modes |
#43 (permalink) |
Thanks for the replies. Will try it before going back home ( and quicker ... ) It will be already dark so the impact will be something astonishing Tell you the results later. |
#44 (permalink) |
Just didn't work
I think I did it quicky though... 1) Ignition key in zero position ok no probs here 2) Press and hold down the Sel/Reset button on the steering wheel I press it and keep it until step 6) 3) Turn on the light The headlights (i have auto lights...) to position 3: Position 0: Off Position 1: Sidelights/Position lights Position 2: Auto Position 3: Headlights 4) Turn ignition into On(II) position ok no probs here...the lights will 5) Turn the light off, then on, then off again Same as 3), for the position 3 6) Release the Sel/Reset button. ok no probs here 7) Within 5 seconds press the Sel/Reset button three times I count until 5 and then quickly press/depress 3 times the button, but the only I see is the display changing from trip info A to trip info B. I've done it also without waiting 5 seconds, and the result was null too... I did give up after 3 tries yesterday... Will reset my brain |
#46 (permalink) | |
That's your mistake! You have to press the butten three times WITHIN 5 seconds, not after 5 seconds. |
#47 (permalink) | |
My brain translated the letters "within" to "wait"...zzzztt..zztt.zzz...tt...rest et needed... Must get more sleep and stop driving the car and surfing the forum Will also try with the position lights as Bungle said. Thanks. |
#51 (permalink) |
Yeeees....wow..soooo many lights! Really great One more thing to impress my friends ( let's get the space ship to warp speed...) Thanks to all of you... Will get some sleep now. |
#53 (permalink) |
GUYS,just a word of warning,while the display of all the lights may seem very impressive to you and your friends,what your actually messing about with is a test to check all communication lines within the multiplex canbus system on the car.The gauge control module acts as a gateway to allow both systems to share information, the gauge control module translates information from B-CAN to F-CAN and from F-CAN to B-CAN. although failures of the multiplex guage unit are rare,inapproiate "playing" by untrained personnel could lead to potential problems .
#54 (permalink) |
I agree with hondatech,
Also the mechanical "analog" gauges are getting a "zero" init, makes them bang the lower stop of the meter. Not at all recommended! It is OK for a one time check, not for playing! |
#55 (permalink) |
Hondatech,
All these buses, would they be Midland Red ?. Seriously, from your post and your Ename, it sounds like we can look forward to some useful inside info in the future. Regards, pcr. |
#56 (permalink) | |
#57 (permalink) |
How about a bit of inappropriate "playing" by trained personnel? Is that okay?
#58 (permalink) | |
#59 (permalink) |
Thanks for that HT. Actually I must confess to not actually trying it yet. Maybe I'll just stick to real fireworks on Nov 5th, as opposed to the Civic's own impressive display!
#60 (permalink) |
It is not OK when "ERROR" message is displayed. It means that there is a communication problem within multiplex net.
LinkBack to this Thread: http://www.civinfo.com/forum/how/1590-how-do-dashboard-self-diagnostic.html
| Forums CivicYume • Afficher le sujet - Petit test d'autodiagnostic du TDB | This thread | Refback | 27th July 2008 18:55 | |
| HONDAFAN Forum :: Vizualizare subiect - ERROR - foarte tare :) | This thread | Refback | 9th July 2008 08:48 | |
| ERROR 2 pri teste komunikace zbernic F-CAN a B-CAN | Honda CIVIC 8. generace | This thread | Refback | 23rd May 2008 23:19 | |
| EasterEggs | Honda CIVIC 8. generace | This thread | Refback | 26th February 2008 14:16 | |
| Forums CivicYume :: Voir le sujet - code pour faire un check du TDB | This thread | Refback | 20th February 2008 18:48 | |
