This thread is about: [HOW TO] Do dashboard self-diagnostic, it's in How To at the Honda Civic forum Civinfo; For those who did not manage DIY see link: http://www.youtube.com/watch?v=Zp8pd64b3Fk . Have fun. Edit by Pottsy: or click here:...
LinkBack (5) Thread Tools Display Modes
Old 26th November 2006, 19:49   1 links from elsewhere to this Post. Click to view. #61 (permalink)
4gotten's Avatar
dashboard self-diagnostic video
For those who did not manage DIY see link:http://www.youtube.com/watch?v=Zp8pd64b3Fk.
Have fun.
4gotten is offline   Reply With Quote
Old 27th November 2006, 14:31   #62 (permalink)
Velocity's Avatar
Nice one, I have a question though, what is an Error 2?
Old 27th November 2006, 15:59   #63 (permalink)
4gotten's Avatar
Error 2
Error 2 indicates a fault of communication between gauge module and B-CAN. That is all I know for the moment. I do not think there is nothing to worry about.
Old 27th November 2006, 19:38   #64 (permalink)
Smile
Im sorry 4gotten,if you have an error message displayed then clearly it needs investigating,you are quite right in the description of the fault (If the word ‘‘Error 2'' is indicated, there is a malfunction in the communication line between the gauge control module (tach) and the body-controller area network (B-CAN) )next you should get the trouble codes read should be similar to these (B1155 to B1160). it could be a faulty guage unit or interior under dash fusebox/MICU at fault. One other possibilty is that a stored fault code has not been cleared which happened during the build process of the car & it is being flagged up when checked.Get it in to your dealer for a look
hondatech is offline   Reply With Quote
Old 27th November 2006, 21:01   #65 (permalink)
4gotten's Avatar
Error 2
Thank you hondatech. It could not have been explained better than you did. It looks like you have a civic service manual in front of you or you work for Honda.
Thanks again.
I will visit my dealer because of "Error 2" message as well as due to a misaligned boot door. But it is another story.
Old 27th November 2006, 22:01   #66 (permalink)
Smile
quote from 4gotten "It looks like you have a civic service manual in front of you or you work for Honda. " right on both counts !!
Old 27th November 2006, 23:19   #67 (permalink)
Blue Ambient
rhodgreen's Avatar
Originally Posted by szegri View Post
Hi everyone!
Now I have the documents at hand so I can give you the other two tests. Here they are:
Ignition OFF
Press and hold down the A/C system's Auto and Mode buttons.
Start the engine
Release the buttons
On the A/C - Radio display you'll see the sensor number and the value for that sensor. To advance to the next sensor just press the mirror/rear window defrogger button.
1st sensor: Inner temperature
2nd sensor: Outer temperature
3rd sensor: Solar radiation sensor value (Dark=00, Flashlight=04, Cloudy=10, Sunny=65)
4th sensor: Air mix opening (low value indicates cooler air distribution, higher value indicates warmer air distribution)
The other sensors shows other door opening percentages in connection with air mixing.
Other test:
Ignition OFF
Press and hold down the Auto and Recirculation buttons
Ignition inti II position
Release the buttons
You'll see the "88" at the A/C temperature. If you see any letter from A to P then it means an error message. The messages can be read out only from the HDS system at the service.
Other thing:
If you see any error message during the dashboard test on the central display, that means some communication error between the gauges. Some people said they had this error message, but as far as I know it has never caused any problem. Maybe some errorcode has been stored in the ECU that can be deleted next time you visit the service...
Cheers!
Szabolcs
Just been reading this thread - very interesting!
I am now wondering if the Climate Control diagnostic tests can be used to solve the problem we have encountered and detailed in this thread....
Is My Climate Control Faulty?
If there's a way of changing the settings, specifically related to hot/cold air mixing / distribution, it might solve our problems - anyone got any ideas?
rhodgreen is offline   Reply With Quote
Old 1st June 2007, 12:28   #68 (permalink)
bajosan's Avatar
Hm...what does the 'error 2' mean ? Or is it just a testmessage ?
bajosan is offline   Reply With Quote
Old 1st June 2007, 13:25   #69 (permalink)
dondon's Avatar
Look at post 63 above.
dondon is offline   Reply With Quote
Old 1st June 2007, 16:30   #70 (permalink)
bajosan's Avatar
Read Bajosan read !!! But ***** anyway dondon !
LinkBack to this Thread: http://www.civinfo.com/forum/how/1590-how-do-dashboard-self-diagnostic.html
Forums CivicYume • Afficher le sujet - Petit test d'autodiagnostic du TDB This thread Refback 27th July 2008 18:55
HONDAFAN Forum :: Vizualizare subiect - ERROR - foarte tare :) This thread Refback 9th July 2008 08:48
ERROR 2 pri teste komunikace zbernic F-CAN a B-CAN | Honda CIVIC 8. generace This thread Refback 23rd May 2008 23:19
EasterEggs | Honda CIVIC 8. generace This thread Refback 26th February 2008 14:16
Forums CivicYume :: Voir le sujet - code pour faire un check du TDB This thread Refback 20th February 2008 18:48
Similar Threads for: [HOW TO] Do dashboard self-diagnostic
Gauges diagnostic Munro Wiki Article Discussion 2 8th October 2007 13:05
Radio diagnostic skam Wiki Article Discussion 0 20th September 2007 16:01
MICU diagnostic moinfo Wiki Article Discussion 0 28th August 2007 13:42
Satnav diagnostic menu seejayess Wiki Article Discussion 0 27th August 2007 16:34
Radio Diagnostic mode on radio Bungle Ipods, MP3 Players and ICE 8 14th August 2007 21:31
