This thread is about: How to install an Origin B2 speed camera detector, it's in How To at the Honda Civic forum Civinfo; Thought anyone who has got one or thinking of buying one may be interested. I originally had it installed on to the dash top of ...
Old 18th October 2006, 16:37   #1 (permalink)
Swindon Japster's Avatar
I originally had it installed on to the dash top of my Seat Leon but didn't want to clutter the Honda's display area. As the Civic already has an eye level speedo, positioning was a case of somwhere that could be glanced at for speed limit info etc. and that would clearly heard with audible alerts.
This position seemed ideal, the shape of the unit very similar to cigarette lighter surround (I am a non smoker so this was convenient to obscure the socket). As with previous 'How To's', I removed the centre console and took out the ash tray. The power was picked up from the back of the lighter (ignition feed only which is not ideal for this unit I admit) and cables run though a hole made with a small come cutter in the botton of the cubby. This and the fixing holes for the cradle will be hidden by replacing the ashtray when time comes to move the Civic on.
The wiring for GPS aerial and laser detector was run around the centre console, over the passenger footwell and then up the side of the door weather strip to the A pillar.
Laser detector 'sucker' being positioned behind a sticker makes it almost invisible from the front, useful if the changes to the Road Safety Bill occur (of course I will remove this component if this happens!).
GPS wire fits (very) snugly between A pillar trim and dash (make sure hands are clean!).
Overall pleased with the fit, discrete but still effective.
Swindon Japster is offline   Reply With Quote
Old 18th October 2006, 19:07   #2 (permalink)
Honda100's Avatar
Very neat and unobtrusive.
My only problem would be that I need to power other items from the cigarette lighter socket so it would not be convenient to cover this item over.
Old 18th October 2006, 22:40   #3 (permalink)
do you get a decent GPS signal there?
with my (Snooper) the place mine worked best was stuck to the back of the rear view mirror - which is nice as it's hidden, but even more tucking of wires behind trim panels
Old 19th October 2006, 12:55   #4 (permalink)
generationgav's Avatar
I've got 4 cigarette power sockets in my arm rest area (the big one) wouldn't that work for you?
and the standard one works as normal anyway, inside and out.
Old 19th October 2006, 15:30   #5 (permalink)
GPS reception is good although the B2 unit itself is a bit slow at getting initial lock, a trait of this system, hence my preference for a permanent power feed.
Old 21st October 2006, 05:09   #6 (permalink)
IWANTACIVIC's Avatar
yer the civic seems to have poor gps singal inside , i spent over 1h just trying to get a place were it would work , good job you dont have a ex swindon' the screen play hell with the laser dector on mine lots of falase alarms etc , but if u move it to half way between the air vent and the tax disc sime ok. you sime a bit near your curtain deploy area with your sensors .
Old 6th November 2006, 11:27   #7 (permalink)
what is best place for a gps?
I have a gps module, and placed it the trunk.
thought of placing it under the panoramic window...
but don't have a clue as to which windows have a gps hindering coating
Trip is offline   Reply With Quote
Old 6th November 2006, 12:41   #8 (permalink)
Glass Spider's Avatar
i've got a tom tom 700 with an external aerial and i just slap it in the glove box, 100% signal all the time better than my megane that i had, which is why i bought the external aerial in the first place
Glass Spider is offline   Reply With Quote
Old 6th November 2006, 21:31   #9 (permalink)
12th June 2006 1.8EX
WoolyCiv's Avatar
Thats where the Honda one is, under the dashboard towards the center i think.
Old 6th November 2006, 23:15   #10 (permalink)
my Snooper GPS isn't so great
best signal I can get is by attaching it to the back of the rear view mirror (though that is fairly handy for hiding wires)
Old 7th November 2006, 12:47   #11 (permalink)
Big Civic fan
stu_iow's Avatar
Your tax disk holder is from the place i got my beast from
Nice install, think it may work well with my TR-30 as well.
stu_iow is offline   Reply With Quote
Old 7th November 2006, 16:41   #12 (permalink)
Bungle's Avatar
GPS should work through any glass as long as its not UV coated or has heater elements in it (front screen style).
Anywhere on the dash area should work well, the further from the pillars the better. They do block some of the signal. The glass roof should work well, but may have trouble with satellites near the horizin.
I have a GPS sat-nav (Garmin Nuvi) and the reception anywhere in the car is superb. I sometimes have it loose on the passenger seat, and a freind sitting in the back was playing with it and it worked a treat there too.
Old 8th November 2006, 08:56   #13 (permalink)
I tried it today (stuck in traffic)
In the trunk i get 4-5 sattelites.
on the dash or by the glas roof i get 8 sattelites.
so boot is worst for me..
note, i have a siftII gps
Old 10th November 2006, 15:42   #14 (permalink)
Looks like my cover is blown! How have you found aftersales Stu?
Old 15th November 2006, 15:02   #15 (permalink)
Big Civic fan
stu_iow's Avatar
I have found it ok.
Car is going in tomorrow for a few things:-
There is silver paint coming off on top of the handbrake, that is being looked at.
I have something loose moving around in my boot door, so that will be looked at.
Petrol cap - got to tesco to fill upthe other day, took me 4 or 5 times on the internal release to get it open!
Intermitant cut out on a speaker somewhere too, not sure which one.
All silly things, but getting them all done at once.
I am hoping i get to try a diesel when i get given a car to use.
Old 15th November 2006, 15:12   #16 (permalink)
Type S Bournemouth's Avatar
I have found it ok.
you might get a 1.4. lol
Old 15th November 2006, 16:26   #17 (permalink)
Big Civic fan
stu_iow's Avatar
1.4. ummm
well if i do, i may make me more aware of how good the 1.8 is. (assuming the 1.4 isn't as punchy that is).
Old 19th January 2007, 16:15   #18 (permalink)
Re: speed camera TR30 lite
Hi , I bought a TR-30 lite few days ago...the cigar lighter power lead wire is too short and hence finding itdifficult to hide it .How did you connect it...?... It's otherwise very good...and I would recommend it...
J777JSY is offline   Reply With Quote
Old 20th January 2007, 20:09   #19 (permalink)
Big Civic fan
stu_iow's Avatar
I had trouble too, but i used a cigarette lighter multiplug with a lead extention on it, i then used that to take the plug (with the multi-plug box) and tuck it behind the centre console all the leads then lead to that location with wires nicely tucked away.
Old 23rd January 2007, 13:12   #20 (permalink)
Smile ***** for the reply
hi would i be able to see a photo...? That would make it much easier...is the centre console the box on which you rest your arm ?....
Similar Threads for: How to install an Origin B2 speed camera detector
Safety Cameras Camera Detector - what is best raineeslover Electronics 19 23rd January 2007 16:53
Spot the speed camera!! jme1978 Any non Civic chat here please! 8 29th December 2006 16:16
speed camera detectors stu_iow General Discussion 22 24th August 2006 22:12
Safety Cameras speed camera detectors civvie06 Electronics 14 31st July 2006 18:50
Speed camera detector and civic windscreen? eyewatcher General Discussion 3 25th June 2006 15:30
