| This thread is about: How to install a Pioneer sub woofer, it's in How To at the Honda Civic forum Civinfo; This is a guide how to install a Pioneer TS-WX11A small sub. Available on Ebay for about 130€ http://shop.ebay.de/?_from=R40&_trks...&_nkw=TS-WX11A The guide can be used as ... | ||
LinkBack (1) | Thread Tools |
![]() Car: 2006 Civic EX
Available on Ebay for about 130€ http://shop.ebay.de/?_from=R40&_trks...&_nkw=TS-WX11A The guide can be used as inspiration for other subs too... Have fun! PS. Post me a PM if you need a higher quality pdf. Last edited by Stef; 26th October 2008 at 09:25. |
7 thanks to Stef from:
#5 (permalink) | |
There are 2 ways to drive the sub, Line level (coming from RCA car radio output) Not an option in the Civic. OR: speaker level input, this is what I used. Stef |
#6 (permalink) | |
my english is very weak that means the sub pioneer has input high level signal and you used RCA. pls. confirm Last edited by szubek; 1st November 2008 at 20:44. |
Hmmm.....
It is possible to connect the sub to a line level output, most of the time RCA connectors are used, coming from the car radio. In this case, since the Civic car radio does not have line level output RCA, a speaker level to line level adjustment cable is provided by Pioneer. Hope it is clear now. Stef |
![]() Join Date: 10th August 2007
After seeing Stefs how to I thought I would have a go at this Sub install in my CTR
I used the following connections, all were very conveniently located at the point of the green arrow on the diagram / photo. 1 ACCESS TO THE WIRES All you have to do is lift up the 2 rear seats bases and pull back the carpet near the middle (see photo below).
2 ELECTRICAL CONNECTIONS New wires from sub are in bold type 2.1 Speaker Twisted Pair Wires
I did not connect to the right rear speaker wires, and the sub seems to work fine. 2.2 Boot Power Socket +ve Wire This has a 20 Amp fuse so should be enough for the sub, which has a 10 Amp fuse. Thick + Yellow wire, Connect Both the Sub thick + Yellow and thin +Blue fused wires 2.3 Earth Convenient Bolt on car chassis, Connect the Sub Earth - Black wire I checked the earth and boot power supply with a multi meter just to make sure everything was OK 3 Remote Control Wire Lots of options for how to route this Various others have installed this and similar mini subs and there is a lot of photographs / options / discussion in this thread . Small Sub Woofer Under Rear Seats. Questions ? … |
![]() Join Date: 12th February 2009
Thanks Munro. I followed your instructions and now have a Pioneer sub under my back seat. I ran the control box to the centre console. Good stuff.
#15 (permalink) |
![]() Join Date: 12th August 2008
You will get everything you need in the box. as stated in the guide the bass signal will come form the rear speaker cabling.
the sub will be powered from the yellow cig cable at the rear seats. and power signal will also hook in the same yellow cable. |
#16 (permalink) | |
On page 6 below is a picture of the convertor cable, with a red circle around the convertor circuit inside the cable.... |
#18 (permalink) |
Does this setup mean you do not require an RCA cable? or
Has the speaker wire and the RCA cable been cut and attached together. i just wanna check this before i go ahead. If this is right then i presume that the speaker wire connects to the yellow/brown +orange/blue cables under the rear seat. The cut speaker wire is attached to the cut RCA lead. Then the RCA lead plugged into the line in on the amp.. is this right???? Or completly wrong? |
#19 (permalink) |
![]() Car: 2008 CTR GT, Milano Red
can everyone open the pdf file or is it just me that cant?
its telling me the file is damaged. That looks like it would have been a great help too... |
#20 (permalink) | |
Adobe - Adobe Reader download - All versions |
LinkBack to this Thread: http://www.civinfo.com/forum/how/19435-how-install-pioneer-sub-woofer.html
| Русскоязычный IT Клуб :: Просмотр темы - нщб сабвуфер | This thread | Refback | 1st June 2009 20:46 | |
| Subwoofer Small Sub Woofer Under Rear Seats. Questions ? | Munro | Ipods, MP3 Players and ICE | 33 | 24th October 2008 20:51 |
| Upgrades Pioneer Ipod Interface | Honds | Ipods, MP3 Players and ICE | 7 | 2nd July 2008 11:28 |
| For Sale: Pioneer AVIC X1-R Sat Nav | Craig_1983 | For sale and Wanted | 0 | 9th December 2007 16:56 |
| Pioneer DVD Player (1080p) For Sale | rishiap09 | For sale and Wanted | 0 | 2nd March 2007 19:05 |
