This thread is about: Install Homing Lights, it's in How To at the Honda Civic forum Civinfo; This guide explains how to install homing lights, using a connection between interiour lights and positioning lights. This results in turning ON / OFF the ...
Old 1st November 2006, 19:35   2 links from elsewhere to this Post. Click to view. #1 (permalink)
Stef's Avatar
This results in turning ON / OFF the positioning lights using remote.
The remote goes 50m or more so...
It works great! (in these dark winter days)
For the UK , you could get the parts from Maplin or CPC (I gues)
Otherwise I could help with the parts.
WARNING: You need some electric skills (sorry)
Old 1st November 2006, 19:46   #2 (permalink)
JPDirect's Avatar
Stef you are a God!
But for the life of me, I have absolutely NO idea what on earth you're on about. I wish I could do that - but there is no way in hell I would even consider doing that. I wouldn't even know where to start!
Can't I just open the door, press the brake pedal twice, switch on the headlights, shut the door, turn on the radio, open the window and pray it works?!?!?
JPDirect is offline   Reply With Quote
Old 1st November 2006, 20:30   #3 (permalink)
Stef's Avatar
Thanks JP,
Anyhow, I see you got the foot lights, so the wiring is allready available...
Now you need the skills (or have somebody available with skills...).
Old 1st November 2006, 22:25   #4 (permalink)
12th June 2006 1.8EX
WoolyCiv's Avatar
Thanks for the info Stef, will get the bits together (possibly already lying around in garage) and give it a go.
Old 1st November 2006, 22:48   #5 (permalink)
Stef's Avatar
May the force be with you, WoolyCiv
Old 1st November 2006, 23:53   #6 (permalink)
Fedorov's Avatar
Wow Stef, impressive work there, wish myself and probably many others understood it though
Old 2nd November 2006, 14:47   #7 (permalink)
Enthusiastic Supporter
Miggins's Avatar
Stef,
Interesting - might give this a go. Do wonder if there is a legal issue (not expected but you never know)?
Also congratulations on a well put together document - My next How To will be in Adobe format, far easier to compile offline and post (as well as email/print).
Old 2nd November 2006, 18:59   #8 (permalink)
Stef's Avatar
I see no legal issue to hominglights, lots of cars have them..
Only legal issue is that you are not alowed to drive using positioning lights only.
Old 18th November 2006, 17:15   #9 (permalink)
Stef's Avatar
One extra tip,
If you have the floorlights, you also can connect to the floorlights controller box conector inside this box. That way no need to cut any wire at all.
For guys from Belgium (or anyone else that want to make the trip) bring me the box, I modify it, install the box. And you got homing lights. Simple as that.
This is how the box look like. If you installed the floorlights you know it is located just under the steering column.
Old 19th November 2006, 06:19   #10 (permalink)
IWANTACIVIC's Avatar
intersting idea but what are homing lights ? does you mean like see me home headlights ?
Old 19th November 2006, 12:13   #11 (permalink)
Glass Spider's Avatar
think of them as using your positioning lights as a torch, they light up the way as you stumble up the driveway to your front door, linked to the interior lights that come on when you use the key fob or open/close the door
Glass Spider is offline   Reply With Quote
Old 19th November 2006, 18:07   #12 (permalink)
Stef's Avatar
Indeed Glass Spider, is there a better name?
They also call them coming home lights or follow me home lights...
Another tip;
1- Close the door
2- Press "unlock button"
Then the lights will stay on, after about half a minute, the car closes itself and the lights go off.
Old 7th February 2007, 20:31   #13 (permalink)
P@tje's Avatar
the better name is "follow me home" lights
Old 7th February 2007, 20:32   #14 (permalink)
P@tje's Avatar
Yes "follow me home" is the name that IMO is most clear
Old 10th February 2007, 12:02   #15 (permalink)
Originally Posted by Stef View Post
One extra tip,
hey, where in belgium are you from? i'm from eupen... (east-belgium, german speaking community )
necromant is offline   Reply With Quote
Old 11th February 2007, 17:28   #16 (permalink)
Stef's Avatar
Hi Necromant, I am from the other side of the country in Geraardsbergen. I think about 250Km from where you are.
Old 10th October 2007, 20:58   #17 (permalink)
ukpm's Avatar
Great guide - not too scary a procedure either. Just need to round up the bits really. I think your recommendation for getting the footwell lighting first should be taken seriously, as it makes this mod really easy.
It'd be more of a feat to set them up as they would have been if they were a factory option - with the lights only coming on once the dusk sensor reports that it was getting dark. Audi/VW cars do this. They also turn off when the key is turned to position 2.
Old 13th October 2007, 17:54   #18 (permalink)
Stef's Avatar
Indeed, getting the footwell light makes things easy.
I realy see no downside that the lights also come on during daytime, there is no problem at all for the battery.
An other good thing is to upgrade the front positioning lights (high bright LED's or halogen 5W bulbs).
Old 12th February 2008, 13:30   #19 (permalink)
Greedy's Avatar
Stef
Just seen this on the back of your floor lighting thread which I am planning to install on my Accord (no doubt the Wire Harness will be somewhat different).
I have an idea to use your welcome home light circuit but to feed super bright LED's mounted in to the underside of the door mirror. I just need to confirm the waterproof connectoin to the LED in the Mirror with enough space.
Old 12th February 2008, 13:42   #20 (permalink)
It wasn’t me!
They arnt going to work with Auto lights are they?
LinkBack to this Thread: http://www.civinfo.com/forum/how/1991-install-homing-lights.html
www.clubhondacivic.com :: Ver tema - Follow Me Lights This thread Refback 24th September 2008 20:57
www.clubhondacivic.com :: Ver tema - Luz de cortesia exterior This thread Refback 27th August 2007 17:39
www.clubhondacivic.com :: Ver tema - los leds tb en los laterales This thread Refback 26th August 2007 01:35
Similar Threads for: Install Homing Lights
Install Ambient Blue Lighting (Switched on by Main Lights) tamar How To 39 13th September 2008 08:38
[HOW-TO] Install fog lights civicsport How To 45 17th August 2008 21:43
Install aftermaket Xenon lights on civic ante00 How To 1 27th July 2007 14:31
Install extra rear positioning lights Stef How To 10 10th May 2007 14:08
Head Homing Lights poejay Lights 18 4th November 2006 10:40
