| This thread is about: [HOW TO] Removal of Door Trim & Speaker info, it's in How To at the Honda Civic forum Civinfo; You rotate a catch that covers the cable part through 90 degrees. That allows you to pop the cable and end out: sp05.jpg sp06.jpg... | ||
#21 (permalink) |
sp05.jpg sp06.jpg |
#22 (permalink) |
Hi guys
I have something (sounds metal like a screw) rolling around in the bottom of my drivers door. Cant quite tell by looking at the pictures but can I just pull (unclip) the door panel from the bottom to see if the object falls out or do I have to unscrew and take the whole door panel off from the top. Re Dave |
#23 (permalink) |
I would go for removing the whole panel. You might save 3 minutes by just unclipping the bottom, but on mine many of the clips got stuck in the metal door frame and needed some screwdrivering out, which can only be done with the panel off. Also, there's not much access into the door even with the panel off, so best get rid of it.
#26 (permalink) |
Hi Pottsy
Got the bottom of the door off and one of the white plastic fixing studs fell out, that's what was rolling around. As I pulled the panel away most of the white fixings stayed in the door and they are tough to get out. Thanks for you help. Re Dave |
#30 (permalink) |
They are 6.5 inch - see here:
Front speakers - replacement with Infinity Ref 6510CS |
#32 (permalink) |
The ones pictured earlier in this thread look identical to the ones I took out of my type R at the weekend. The stock woofer speakers are incredibly light with very small magnets. The tweeters are similarly light weight.
#33 (permalink) |
cheers will have to change some time to beefier speakers, why do people bum the infinity soo much? are pioneers or kenwoods not good?
#34 (permalink) | |
I guess its because they know the infinitys will fit because others have installed them, it is a tight space with the front window just clearing the speaker when it is wound down. I was also pleased with the way the tweeters can be mounted in the existing tweeter frames - they fit thru the tweeter housing with the help of a stanley knife trimming. I still think the head unit is not up to driving the infinitys properly as I have to turn the bass up and treble down to get an acceptable sound (Note I am not a bass head and have never had to do this on previous cars). |
#35 (permalink) | |
#36 (permalink) | |
I tried putting the fader back to the original rear speakers only today. They sounded terrible - so I guess the infinitys must be good. If I get a chance, I will pop into an audio specialists and see what they say. No doubt I will surface from the shop with an amp or something! What do other people think about their own infinity speaker upgrade ? Last edited by Munro; 3rd October 2007 at 19:17. |
#37 (permalink) | |
LinkBack to this Thread: http://www.civinfo.com/forum/how/223-how-removal-door-trim-speaker-info.html
| Ozhonda.com - [FN2] anyone know how to remove the door panel? | This thread | Refback | 13th July 2008 06:20 | |
| [FN2] anyone know how to remove the door panel? - Ozhonda Forums | This thread | Refback | 3rd July 2008 07:11 | |
| Info - Pics of inside door panel with speakers | mr w1z | Wiki Article Discussion | 1 | 26th November 2007 22:31 |
| Trim Door Trim Rubbing Off | Wheelchair | Bugs, faults and irritations | 10 | 8th September 2007 20:56 |
| Add-on nav Removal of top hinged door in dash | HumberMart | Electronics | 1 | 7th September 2007 12:20 |
| Speakers is there a 3 door rear speaker panel removal guide? | andy dys | Ipods, MP3 Players and ICE | 1 | 27th March 2007 18:56 |
| Plastic trim removal | lazzy git | Styling | 22 | 16th March 2007 20:11 |
