This thread is about: [HOW TO] Replace rear internal lights with blue LEDs, it's in How To at the Honda Civic forum Civinfo; It didn't occur to me before, but what about the light in the boot? Anyone changed that yet?...
Old 28th March 2007, 01:20   #21 (permalink)
druidh's Avatar
druidh is offline   Reply With Quote
Old 16th April 2007, 13:23   #22 (permalink)
sco77harris's Avatar
dont forget the glovebox if it has a light i cant remember lol
Old 20th April 2007, 17:10   #23 (permalink)
i just had a look and think the boot one is the same as the front so have order one for the boot too.
Old 5th May 2007, 18:32   #24 (permalink)
kamshaft's Avatar
has anyone tryed this type with 12 Led's off ebay, they should be alot brighter than the 6 led version, also alot cheaper clicky
kamshaft is online now   Reply With Quote
Old 5th May 2007, 19:02   #25 (permalink)
looks good
Old 10th May 2007, 21:13   #26 (permalink)
I got a 269 led bulb today for the rear light and two 501 bulbs for the front lights. The front bulbs were fitted and work fine, however I can't get the 269 bulb to work. I swapped ends around but with no joy, do I take it that I was sent a duff 269 bulb?
digipeep is offline   Reply With Quote
Old 12th May 2007, 00:40   #27 (permalink)
Don Leone's Avatar
Did you try to turn on the switch again or close and reopen a door to actually activate the light? I do remember thinking the leds were broken at first as well when installing until I opened a door again and noticed the leds actually worked.
Don Leone is offline   Reply With Quote
Old 19th May 2007, 18:47   #28 (permalink)
liverpoolcivic's Avatar
hi guys, the blue LED'S blubs- are they the blubs that Honda are selling as an accessories for blue foot well lighting for £200!? (If this makes any sense!!)
liverpoolcivic is offline   Reply With Quote
Old 23rd May 2007, 08:17   #29 (permalink)
Smell My Cheese!
richierich's Avatar
No, it is a small festoon type bulb, identical to the one in the roof light, just composed of 6 small LED's as opposed to a traditional filament type bulb.
I forked out £200 for the footwell lights, the blue lighting overhead adds to the effect, although I only fitted the bulb in the rear and turned off the front units.
The link to the place to buy these should be further up this thread I guess.
Old 23rd May 2007, 09:21   #30 (permalink)
andischatz's Avatar
Even though I'm only getting my Civic on June 6 (longest fortnight of my life, probably... *sigh*), I bought the blue LED cluster for the back interior light and white LEDs for the map lights. I plan on keeping the map lights turned off unless needed to actually read something. I suppose the LED cluster in the back is enough to give the whole interior a blue glow...
andischatz is offline   Reply With Quote
Old 21st June 2007, 18:55   #31 (permalink)
gbrockley's Avatar
Best way to buy blue led bulbs is eBay, £8 for the three internal light bulbs..inc. postage
gbrockley is offline   Reply With Quote
Old 21st June 2007, 21:05   #32 (permalink)
raz_brfc's Avatar
Has anyone doe this for a Type R? I want to change the bulbs in my type R but use red bulbs instead of blue, I've seen the 501 bulbs and I shouldn't have a problem getting those but don't seem to be able to find the 269 bulbs in red? anyone know where I can get one?
raz_brfc is offline   Reply With Quote
Old 21st June 2007, 21:37   #33 (permalink)
gbrockley's Avatar
Try this guy on eBay...has them in 36mm, only 5mm longer than a 269 and will most likely fit. Only £2.99 inc. 1st class postage...worth a try for 3 quid!
http://cgi.ebay.co.uk/Red-Festoon-LE...QQcmdZViewItem
Old 21st June 2007, 22:18   #34 (permalink)
raz_brfc's Avatar
cheers mate, I'll give them a try, might not fit though and only 2 leds. it's a bit odd really not to get the bulb in red. I found these at ultraleds, 31-35mm
http://www.ultraleds.co.uk/u314r-35m...ion-p-673.html
Old 22nd June 2007, 20:18   #35 (permalink)
Civic_Fan's Avatar
Quick question i checked at the store the other day for the rear festoon bulb but instead of the square type one they had one a long cylinder with three LED's instead of six, would they give the same effect ?
Civic_Fan is offline   Reply With Quote
Old 22nd June 2007, 23:29   #36 (permalink)
markvirgo's Avatar
Ordered mine thanks
markvirgo is offline   Reply With Quote
Old 30th July 2007, 14:27   #37 (permalink)
My led doesn't work either, also switched ends, close and open door, put switch to "ON"...
Nothing works.
I sent a mail to autobulbsdirect and damn, they do answer fast
had an answer withing 5 mins.
But they said to turn the bulb 180° , now waiting for other mail.
VaTaR is offline   Reply With Quote
Similar Threads for: [HOW TO] Replace rear internal lights with blue LEDs
Interior blue LEDs gers Lights 1 9th October 2007 01:19
Head Philips GT 150 blue lights? fz158 Lights 3 1st October 2007 20:11
Blue interior lights Maldax Wiki Article Discussion 0 19th January 2007 10:16
Speakers Do I need to replace front & rear speakers? richierich Ipods, MP3 Players and ICE 5 6th October 2006 12:31
Interior New blue lights for your Civic Hartside Lights 9 10th August 2006 19:34
