This thread is about: [HOW TO] Install the Dension Icelink>Plus, it's in How To at the Honda Civic forum Civinfo; Happy days guys - Finally got it sorted. PM if you have any problems - i'm more than happy to help. Cheers, Tom...
LinkBack (8) Thread Tools Display Modes
Old 18th November 2006, 14:37   7 links from elsewhere to this Post. Click to view. #1 (permalink)
tucker101uk's Avatar
Happy days guys -
Cheers,
tucker101uk is offline   Reply With Quote
Thanks to tucker101uk from:
Old 18th November 2006, 17:03   1 links from elsewhere to this Post. Click to view. #2 (permalink)
Here is Tucker's guide in "post" format (the pdf is best if you need to print it). Thank you Tucker for this - it is ace! All this below is Tucker's work:
Installing the Icelink>Plus in your 2006 Honda Civic
Note: My Civic is an SE model, and so parts of the dash removal process will differ on the EX, due to the sat nav screen.
I sourced my Icelink>plus from Gordon Harwood Computers - http://www.ghc.co.uk
It cost 99.29 including VAT, and was posted next day. The service I received was exceptional and I would recommend them to anybody. The initial Ice>link did not work, and the technical dept contact dension directly and sourced the correct part. The stock number is 45121, however when ordering ensure you specify that you need the “Honda B” type unit.
Installing the Dension Icelink>Plus
Step 1
This guide will get you started removing part of the dash:
[HOW TO] Get into the dash
Step 2
In order to remove the head unit assembly from the dash, there are 5 screws which require undoing. 3 are located below the blanking plate here:
The blanking plate can be levered up with a screwdriver, but take care not to scratch the plastic. Tip – cover the end of the screwdriver with electrical or masking tape…
Step 3
…and 2 are located underneath the head unit here:
Step 4
Once all 5 screws are removed, the head unit assembly will pull away from the dash. Its fairly tight, but a careful and confident tug will remove it.
Step 5
Slide the head unit out from the dash, taking care not to scratch anything.
We can now identify the CD Changer slot more easily. Plug the cable supplied into the slot as below:
Step 6
Run the cable down the back of the head unit, and out by the gear stick:
Connect the other end of the cable to the Icelink>Plus. In this picture you can see the Cigarette lighter adaptor I have installed in order to power my tomtom.
Step 7
At this point, we can connect up the cradle, and plug in the iPod. Switch the ignition to the accessory position, and all being well the iPod should begin to charge, and also display the Dension logo.
Step 8
Now you need to decide where you are going to mount your cradle, which is where this guide begins to become a little useless. You need to run the cable to your preferred location and mount the cradle. I chose to store my cradle in the centre console tray, and so I have drilled a small hole to feed the cable through. The hole looks larger than required, but I had to drill it that big to get the connector through!!!
Step 9
Re-assemble the dash, taking care to ensure that no cables are visible as you go.
Step 10
Admire your handy work!
Thanks to Pottsy from:
Old 18th November 2006, 17:14   #3 (permalink)
Type S Bournemouth's Avatar
i notice halfords fit the system for £199 inc parts for people who are not keen on doing it themselves.
Old 18th November 2006, 17:32   #4 (permalink)
i wouldnt trust them with it! jesus!
If anyone lives near sussex i'll do it for free! just a cup of tea maybe when i've finished!!!
Old 18th November 2006, 19:20   #5 (permalink)
Well done on a job well done
Could you just please clarify what type of control and display this gives you on the stereo.
karlak is offline   Reply With Quote
Old 18th November 2006, 20:22   #6 (permalink)
If you come to Belfast I'll bake you a lasagne!
Old 18th November 2006, 20:42   #7 (permalink)
Honda100's Avatar
Excellent guide.
Thanks for doing this, a great help to the rest of us who have been desperate to get our iPods working.
From the Gordon Harwood site for those of a nervous disposition
Self installation or fitting service available through Car Phone Warehouse or UniCar (click links for details).
Old 19th November 2006, 00:06   #8 (permalink)
tonks82's Avatar
So what would be different for the EX?
Also (echo from earlier question) what control does this give you?
Excellent guide!!
tonks82 is offline   Reply With Quote
Old 19th November 2006, 00:42   #9 (permalink)
IWANTACIVIC's Avatar
cool guide well done , does this give you full use of the ipod or just aux input style ?
Old 19th November 2006, 00:59   #10 (permalink)
Hi guys...
There is 2 modes of operation -
the first allows you to control the ipod via the steering wheel and head unit buttons, skip through tracks, adjust volume, and disc +/- scrolls through your first 6 playlists. This mode locks out the scroll wheel.
The second allows you to control the ipod via the scroll wheel, but not via the head unit or steering wheel...
There are advantages and disadvatages of both...
To change the mode:
Select CD 6
Use the skip keys to select option 1 - "select ipod UI"
Hold Skip forward (FF)
When prompted remove ipod from cradle and reconnect.
Last edited by tucker101uk; 19th November 2006 at 01:28. Reason: read the manual!!!
Old 19th November 2006, 01:01   #11 (permalink)
The screen on the EX is slightly different, meaning that access to the top of the head unit would be different...
If anyone can post a photo of that area i can have a look see... other than that i dont think there would be any difference... Apart from maybe what is displayed on the screen?
Old 19th November 2006, 15:44   #12 (permalink)
What do you get on the car screen (if anything) on yours?
Old 19th November 2006, 21:23   #13 (permalink)
phuket's Avatar
Thumbs up
Thanks a lot tuckeruk101, you have cleared a topic we all wanted to have resolved for a long time now. I will go ahead and have the dension kit installed soon.
phuket is offline   Reply With Quote
Old 19th November 2006, 22:19   #14 (permalink)
phuket's Avatar
In fact I just ordered the kit from the site you got yours from. Thanks again
Just don't know how i will get my guts up to install the thing myself
If I can't, I'll be having it installed proffessionally. The guide you have prepared makes it easier though, I must say... We'll see.
Old 20th November 2006, 00:07   #15 (permalink)
no probs - unfortunately i cant make it to Turkey to help you
If you have any questions tho, give me a PM.
Its easy to do if you have even a small bit of knowledge...
Old 20th November 2006, 10:28   #16 (permalink)
gnyf's Avatar
displayed
does anyone know what will be on display in an Exe model. I'm hoping for a full iPod interface with all the bells and whistles....
gnyf is offline   Reply With Quote
Old 20th November 2006, 10:34   #17 (permalink)
Parky's Avatar
Originally Posted by gnyf View Post
If it is working as the CD changer then you won't see the full iPod info on the screen. All you will see is the CD name (which refers to a playlist on the iPod) and the track number in the playlist. You won't have full iPod control (i.e. ability to browse through Artist, Title, Genre, etc). You will probably have access to 6 specifically named playlists only.
Ian
Parky is offline   Reply With Quote
Old 21st November 2006, 11:48   #18 (permalink)
generationgav's Avatar
So Tucker; you don't have an EX model? Won't the EX need an extra part I was led to believe? Which is another £100 or so!
Aslo does anybody know where the bluetooth Honda adaptor plugs in to the back of the HU? Not the CD changer slot I hope?
Old 24th November 2006, 16:33   #19 (permalink)
Swindon Japster's Avatar
At your own risk
I rather agree with Tucker, experience shows that their install may be so bad it could be mistaken for a Swindon OEM fit. Remember that monkeys could type the works of Shakespeare given enough time and bananas!
Swindon Japster is offline   Reply With Quote
Old 24th November 2006, 17:26   #20 (permalink)
If you need the extra bit to plug in the CD changer then yes you will need it for the icelink...
LinkBack to this Thread: http://www.civinfo.com/forum/how/2417-how-install-dension-icelink-plus.html
Forums CivicYume • Afficher le sujet - Démontage hauts-parleurs This thread Refback 30th November 2008 19:00
HIBRIDOS CLUBE • Vendo Tópico - Onde fica a entrada Aux (auxilary)? Post #0
