| This thread is about: [HOW TO] Do a speaker check, it's in How To at the Honda Civic forum Civinfo; Found this today while messing about with the radio diagnostic mode. To access the speaker check menu:- Press and hold (in order) 1, 3, and ... | ||
Press and hold (in order) 1, 3, and then press the power button Can then check each speaker individually by pressing the seek/skip buttons. |
#2 (permalink) | |
Mind going into a little more detial. I went into the screen after you hold Menu Map and Cancel and tried it and also tried in the in the radio screen under unit check that shows the FM and AM frequency all with no luck. Maybe I'm doing something wrong? Anyone else get this to work? |
Not sure if it works the same with the sat nav as i dont have this. Try it from the normal screen when listening to a cd or the radio without going into any other menus first.
Thanks!
For some reason I glanced at these previously and assumed that they were EX only and wouldn't work on my lowly SE. I must be wrong! |
| AC/Heater air con check? | Flyboy13 | Bugs, faults and irritations | 13 | 20th May 2007 19:44 |
| New Car Check List - What would YOU check? | tonyt | General Discussion | 1 | 27th February 2007 18:55 |
| Collection What to check for | steeeveee | Buying, Dealers and Servicing | 5 | 24th January 2007 10:20 |
| Other Check this out 2! | Doody2008 | Gallery | 5 | 7th September 2006 20:46 |
| Other Check this out! | Doody2008 | Gallery | 1 | 4th September 2006 16:01 |
