Old 17th February 2011, 14:50   #81 (permalink)
TheGodsInRed's Avatar
Car: 2006 2.2 CDTi ES, Black
Thanks given: 6
Pads fitted used a Laser wind tool which fitted fine. Great guide thanks
TheGodsInRed is offline   Reply With Quote
Thanks to TheGodsInRed from:
Old 19th February 2011, 14:12   #82 (permalink)
Lord of JAE.....
Car: 58' NHB Type R-GT
Thanks given: 389
Originally Posted by Downie View Post
Hi Mate,
Hope you can help, I followed your post but I never turned the engine on when I depressed the brake pedal. Now my hand brake does not function correctly.
Any suggestions on how I can fix this?
Many Thanks paul.
Sorry for the late reply, I just turned off the engine (released the handbrake) and depressed the pedal until it became tight (it should do as the servo's off), then turn on the engine and try putting the handbrake on... repeat as necessary. This should if memory serves, tighten up the piston.
Old 24th February 2011, 20:36   #83 (permalink)
Car: 2007 2.2 ex
i wish i had seen tis post before trying to fit new pads with out the wind back tool
jplant1981 is offline   Reply With Quote
Old 5th March 2011, 08:12   #84 (permalink)
Thanks given: 1
Post
Originally Posted by Unknownsoldier View Post
Right guys, as this morning was so warm I decided to do my rear pads, and to do a bit of a how to, as I think there is only a how to for the fronts on here.
MAKE SURE THE HANDBRAKE IS OFF AND THE WHEELS CHOCKED WITH CAR IN GEAR!!!!!!
Anyways here we go:
Click the image to open in full size. + my windback tool, which I forgot to put in the piccy. and some cable ties.
I loosened the nuts off. I then jacked up the car using the trolley jack (I did the second lot of pads with the Honda Jack to give a clearer view for the pic's). I put in my axle stand to hold it firm, The axle stand took the weight, but the jack was there too JIC. I kept the second one back for later.....
Here is where I positioned the axle stand:
I then opened the bonnet and opened the brake fluid reservoir, and put some paper towels around it to catch any over flow. I put my brake fluid bottle there too in case it needed a top up later (3 pounds from Honda )
Right now for the messy bits...
Undo and remove all the nuts and remove the wheel, roll it to one side, I took this opportunity to clean the back and to check the tyres wear and for any nails etc.:
Remove the two bolts as per the front fitting instructions, I put them to one side and greased them with copper grease :
Once these are removed you can remove the caliper and using the second axle stand move it back from the pads, Rest the caliper on the axle stand, and it makes it far easier to work on, watch the 'flangey bits' around the disc, they can cut you quite nicely, which I found out today :
I used a cable tie to hold it to the piston behind, this helps when winding back in a moment.
I inserted the windback tool (standard ones are too large, so it needs to be done slowly and very firmly, it's a bugger to start, but if done right should wind back easily): Click the image to open in full size.
I then inserted the new pads after greasing the runners, and forced them in to place, they are a very tight fit!!!!! and then greased the backs.
Then simply refit the caliper and remount the bolts:
Then refit the wheel, and greases and refit the nuts, but do not tighten fully! lift the car enough to remove the axle stand then lower slowly and tighten the wheel nuts fully Job Done.
DEPRESS THE BRAKE A FEW TIMES WITH THE ENGINE ON, DO NOT PUT THE HANDBRAKE ON BEFORE DEPRESSING THE BRAKES!!!!!!!!!
Hi folks - I have information which gives more specific details if you require it - but brilliant post by unknown soldier.
I have this on a Word Document with Honda illustrations but cant seem to upload this document due to restrictions on size - if any one can assist uploading this please email me or if you require this document email me:-
carl@daniels-family.org.uk please put your subject as Honda Pads.
carldanielsuk is offline   Reply With Quote
Thanks to carldanielsuk from:
Old 15th April 2011, 20:40   #85 (permalink)
Pheasant Plucker
Fr0d's Avatar
Car: 2006 2.2 EX, NHB
Thanks given: 56
Changed my rear pads last week, but I have just discovered i was foolish enough not to wind back the piston to a position so the small raised pin on the back of the new pads fits between the slots of the piston.
Will i need to go through at the rigmarole of redoing it? I have driven the car for a week with no issues. Even tried forceful braking to get the ABS to reseat the pads correctly but i have no idea if they are or not, without stripping everything down again. Any Ideas?
Fr0d
Fr0d is offline   Reply With Quote
Old 19th April 2011, 11:54   #86 (permalink)
Thanks given: 4
Thank you , it made things alot easyer .
Drejc is offline   Reply With Quote
Old 3rd September 2011, 20:26   #87 (permalink)
kolozsvarizsolt's Avatar
Car: 2007 1.8 5 door, NHB Pearl
Thanks for this 'how to'.
What about hand brake bowden cable loosing?
I had to do that for disconnecting cable. Without that I had not been able to take off caliper from disc.
kolozsvarizsolt is offline   Reply With Quote
Old 13th September 2011, 12:55   #88 (permalink)
Lord of JAE.....
Thanks given: 389
Never had to loosen anything else mate. sorry.
Old 11th December 2011, 20:31   #89 (permalink)
Thanks given: 2
Great write up Tom did ours today didnt take long , bought a wind back tool off ebay that looks like it will fit all sorts for £23 .
I did wonder if I should have used thread lock on the bolts into the sliders?
Also are there any torque settings lists anywhere I just did them tight?
Mad4amanda is offline   Reply With Quote
Old 14th January 2012, 12:16   #90 (permalink)
Thanks given: 4
Can anybody help me, im changein my rear disc but i dont know how to take them off.
Old 14th January 2012, 14:49   #91 (permalink)
coste1l's Avatar
Thanks given: 1,113
http://www.civinfo.com/forum/wheels-...tuff-pads.html
coste1l is offline   Reply With Quote
Old 15th January 2012, 18:48   #92 (permalink)
Car: 2007 CTR Alabaster
Thanks given: 571
Changed pads and disks tonight. Nice one
peice of pisssssssss
crowmar kirkliss is offline   Reply With Quote
Thanks to crowmar kirkliss from:
Old 4th June 2012, 11:31   #93 (permalink)
Lord of JAE.....
Thanks given: 389
Hey sorry for the late reply, I certainly wouldn't use threadlocker, and I just do them as tight as I can and use copper slip on the bolts. then just check them next time you get a spare minute
Old 8th March 2013, 13:37   #94 (permalink)
andy l's Avatar
Thanks given: 5
Hi.. If it helps anyone I've just replaced my rear discs and pads.. You will need a caliper wind back tool.. Got this from Machine Mart and does the job a treat..
Right-Handed Brake Piston Wind back Tool
£9.98 ex.VAT
£11.98 inc.VAT
Product Code: 040817916
andy l is offline   Reply With Quote
Old 9th March 2013, 12:31   #95 (permalink)
Lord of JAE.....
Thanks given: 389
Nice one, my tool was about the same price, and has seen me through now 4 years of pad changings on different cars
LinkBack to this Thread: http://www.civinfo.com/forum/how/27431-changing-rear-pads-how.html
Brake Bleeding - HondaCivicForum.com This thread Refback 1st October 2011 12:48
- - 296 - Honda Civic Club This thread Refback 4th October 2010 04:24
- 19 - Honda Civic Club This thread Refback 10th September 2010 12:09
ÊÎËÎÄÊÈ - Ñòðàíèöà 19 - Honda Civic Club This thread Refback 28th June 2009 15:51
Similar Threads for: Changing Rear Pads, how to!
Brakes changing front pads shakie1973 Wheels, Tyres, Suspension and Brakes 16 13th May 2009 14:17
Brakes Changing rear brake pads T.R. Wheels, Tyres, Suspension and Brakes 8 7th April 2009 07:21
rear brake pads kahmed87 Type-R 5 11th October 2008 09:50
Rear Brake Pads mes Holdcroft Honda 2 9th May 2008 15:33
