This thread is about: Front speakers - replacement with Infinity Ref 6510CS, it's in How To at the Honda Civic forum Civinfo; and a drive littered with bits of broken plastic!........the tweater mouldings have three plastic hooks and a spring metal device - this bit pulls out, ...
LinkBack (13) Thread Tools Display Modes
Old 1st May 2007, 20:07   #201 (permalink)
and a drive littered with bits of broken plastic!........the tweater mouldings have three plastic hooks and a spring metal device - this bit pulls out, but the plastic hooks are a liitle weedy and need careful manipulation to disengage. My advice woul be to start by lowering the windoe and genlty easing the edge of the trin which is by the window channel away fom the channel until th eplastic hook is clear of the metal alowing you to ease it towards you at right angles to the door. The metal clip is on the front slope of the trim and should pop away with out too much prising force.
Once the top of the trim is clear lift it up to release the plastic hooks on the bottom edge clear of the door.
I found also that prising the oor trim clips was quite hard - start in the middle lower edge of the panle and work along the bottom edge in both directions from the middle - then up the sides at that wil give you more leverage. I bought a trim removal tool (£10) from a local parts supplier (like camberley auto factors. This hels to release the plastic rivets from the door without breaking them or the moulding on the door trim that they fit in. You need another pair of hands to hold the trim while you disengage the fastners that hold the loking and door opening mechanism as well as unplugging the wiring harness - otherwise it is easy to break the fittings ( I did and spent two hours making a repair)! One of the plastic rivets is a different colour form the others - make a not of where it locates.I tooka picture of the door panel when removed so i could refer back in case of difficulty.
digisine is offline   Reply With Quote
Old 1st May 2007, 20:55   #202 (permalink)
sco77harris's Avatar
hi does anyone have direct links as to where to buy the astra rings?
and the same for sound insolation?
thanks for any help
Old 1st May 2007, 21:00   #203 (permalink)
Type S Bournemouth's Avatar
the link to where to buy them is in this thread at caraudiosecurity.com.
Not sure on the sound insulation. Any decent car hifi shop i expect or maybe even halfords.
Old 1st May 2007, 21:06   #204 (permalink)
what thread lol? thanks for the help
Old 1st May 2007, 21:07   #205 (permalink)
I bought mine from Halfords - £11 I think they were. As for the sound deadening material - haven't got any yet so I'd be interested to know but I wold guess halfords or any decent Car audio shop. Otherwise try Google
Old 1st May 2007, 21:15   #206 (permalink)
is this them http://cgi.ebay.co.uk/Astra-Cavalier...QQcmdZViewItem
Old 1st May 2007, 21:16   #207 (permalink)
http://caraudiosecurity.com/shop/pro...s_id/1995.html
Old 1st May 2007, 21:19   #208 (permalink)
t0ny0k's Avatar
As previously mentioned take your time and read all the posts. I copied and pasted all the relevant info onto a word document. Part numbers, +ive and -tive speaker cable colours,etc. Spent time looking at all the photos. Gives you a good feel for the work required. See my post on previous page,I have made a list of prices paid and suppliers. There is also a good thread some where about sound deadening from a guy in Estonia.
t0ny0k is offline   Reply With Quote
Old 1st May 2007, 21:20   #209 (permalink)
thanks pottsy these are just for the front what about the rear?
yes i am a nag today
Old 1st May 2007, 21:20   #210 (permalink)
Originally Posted by sco77harris View Post
They look like the same as the ones I have.
Old 1st May 2007, 21:21   #211 (permalink)
Old 1st May 2007, 21:32   #212 (permalink)
Daren's Avatar
Fitted my Infinities last Tuesday - no major problems at all, just followed the instructions posted.... piece of cake to do and no rattles afterwards
I was disappointed with the sound quality after the install and could not hear any real improvement, HOWEVER, I had a nice long run up to Scotland from my home in Essex - I could not believe the improvement in sound quality by my arrival 6 hours later. The speakers have settled in nicely and the base and depth makes a huge difference (even the wife made comment!)
If your worried about doing the upgrade my advice is go for it, you'll be glad you did. You will have to wait for them to bed in and open up - its worth the wait.
Daren is offline   Reply With Quote
Old 1st May 2007, 21:46   #213 (permalink)
did u use the speaker rings just for the front
or are there some for the rear thanks
Old 1st May 2007, 22:12   #214 (permalink)
sandz's Avatar
Rear ones are the same.
sandz is offline   Reply With Quote
Old 1st May 2007, 22:17   #215 (permalink)
Daren's Avatar
Only did the fronts. Thought I would see how they sounded first before making my mind up about doing the rears. I don't think I will bother as I am v happy with the sound quality now.
I think someone else has posted instructions for the rear earlier in this thread (too much for me to read though again )
Old 3rd May 2007, 09:43   #216 (permalink)
so i can use the same astra rings in the rear, thanks
Old 3rd May 2007, 11:44   #217 (permalink)
generationgav's Avatar
I did the same (well not the 6 hour trip) I complained on here that I was dissapointed with the improvement, and a few people thought that I was asking for too much I think! But after a few journeys and I'd say about 12hrs with them on they sounded amazing and still do!
Old 8th May 2007, 17:20   #218 (permalink)
Skaven252's Avatar
Thumbs up
Just had them installed today. 6510cs's in the front and 6512i's in the rear. No problems with the installation, as I didn't have to do it myself. (to the people near Espoo, Finland, I used the services of Tip Top Auto)
Improvement? Well, yes and no. Mostly yes! The upper register is much brighter and clearer now, I can hear stuff in the music I didn't know was there (such as mp3 packing artifacts, meh). The bass goes really deep down, but it's quieter than in the previous speakers, especially in the mid-low range. Maybe I shoulda used "subtler" instead of "quieter" there though. Overall, the speakers seem to require more power than the factory ones, I have to keep the volume at a higher level than previously.
The trebles and mid high are actually a tad too loud for my tastes, giving the speakers a slightly 'tinny' quality, but I adjusted the EQ. I boosted the bass a bit, reduced the treble slightly, and used the fader to give a tad more power to the rear speakers. With this kind of setting the sound "floats" in the middle of the car, so to speak, and feels quite transparent.
When driving at 100km/h, I noticed how clear the sound really is. It clearly cuts through the background noise (whereas with the factory speakers the music tended to drown in the noise). Nice!
I still find the sound kind of tinny, but it's only because I'm comparing the sound with the old speakers which I had gotten used to. I'll probably get used to this new sound much faster.
Final verdict: don't expect a miracle, but it's clearly an improvement.
Skaven252 is offline   Reply With Quote
Old 8th May 2007, 17:29   #219 (permalink)
i think you need to give them time to bed in as such and they will improve over time.
Old 8th May 2007, 20:17   #220 (permalink)
sandz's Avatar
Did they do Sound isolation as wel?
LinkBack to this Thread: http://www.civinfo.com/forum/how/277-front-speakers-replacement-infinity-ref-6510cs.html
Forums CivicYume • Afficher le sujet - Comment j'ai changé mes haut-parleurs avant This thread Refback 2nd August 2008 20:45
Under driven speakers? - Talk Audio Forums This thread Refback 29th July 2008 00:31
Type-R Scotland :: View topic - Infinity 6510 cs This thread Refback 8th June 2008 21:06
www.clubhondacivic.com :: Ver tema - ¿Qué tal es la radio que lleva de serie? Car Audio</
