This thread is about: Front speakers - replacement with Infinity Ref 6510CS, it's in How To at the Honda Civic forum Civinfo; Moved my tweeter connections over to the -3dB terminals and I can safely say that the sound is finally what I had been waiting for. ...
LinkBack (14) Thread Tools Display Modes
Old 16th January 2007, 20:48   #141 (permalink)
TheBull's Avatar
I was a bit disappointed when I first installed the speakers but they are sounding really sweet now. This mod is HIGHLY recommended.
TheBull is offline   Reply With Quote
Old 17th January 2007, 16:38   #142 (permalink)
Meino's Avatar
Spacer rings
Found this on ebay: http://cgi.ebay.nl/ws/eBayISAPI.dll?...ayphotohosting
Is it something we could use for the speaker upgrade?
They are available in 9mm and 12mm.
Meino is offline   Reply With Quote
Old 6th February 2007, 15:01   #143 (permalink)
Diesel Demon
damianscott71's Avatar
Just ordered a set of 6510cs from a company on Ebay (they've got a shop on Tottenham Court Road in London too), great price £45 + shipping. Ordered a set of Astra Speaker rings too.
If anybody's thinkng of replacing the rears too, they do the 6512i which has an integrated tweeter. It should fit (I think), in fact I don't know if it will fit, but it might. It's the same size (16.5cm), but might be deeper.
Could anyone confirm whether the 6512i might fit in the rear?
Also, does anyone know if there's room for any sound insulation behind the speakers? Applying some sound deadening material would probably help the bass and help to minimise any rattles.
Damian
p.s. What do you think of the new avatar?
Old 6th February 2007, 15:07   #144 (permalink)
LOL! all in one post:
It might fit
I don't know if it'll fit
Does anyone else know if it'll fit?
classic!
and yes, very nice!
Old 6th February 2007, 15:12   #145 (permalink)
Diesel Demon
TTDegs,
Well.... I don't know EVERYTHING (realising that was really difficult to come to terms with!)
Damian
Old 6th February 2007, 15:17   #146 (permalink)
at least you now know that you don't know!
back on track (my fault sorry)
I do vaugelly recall posting on a thread in here somewhere about the various sizes and ohmage of each of the speakers - don't recall quite where though or indeed if that will help!
Old 6th February 2007, 15:26   #147 (permalink)
generationgav's Avatar
I'd expect they fit; but wouldn't be sure, like yourself.
As for the insulation; there is quite a bit of room behind the speaker, but it's all inside of the door panel, there's no cabinet to speak of at all, so I'd expect it wouldn't do any good!
Old 7th February 2007, 20:55   #148 (permalink)
Chucky's Avatar
I have fitted the 6512i in the rear doors on my Civic . Made my own speaker rings out of mdf though as couldn't get any Astra rings at the time. The astra speaker rings should fit though as the front and rear factroy speakers look identical.
Chucky is offline   Reply With Quote
Old 7th February 2007, 21:13   #149 (permalink)
Question 6510 speakers
I haven't actually got round to fitting mine yet. All is prepared - wiring looms etc but I have not yet figured out how to refit the door panels without cutting down the moulding on the inside of the panel that seals to the original speaker after the new speakers are fitted. Has anyone else had to do this, or amdoing something wrong?
digisine is offline   Reply With Quote
Old 12th February 2007, 13:18   #150 (permalink)
I fitted mine recently. I think someone mentioned previously that the panel sits slightly away from the door, but it's not noticeable unless you're looking for it.
I'll join the list of recomendations for this upgrade, a night and day difference to the standard (dissapointing) set up and well worth the time and money invloved. Big thanks to all those who contributed on the thread and made it nice and simple for me to follow
323GT-R is offline   Reply With Quote
Old 12th February 2007, 22:47   #151 (permalink)
Willie's Avatar
Took the opportunity to fit Infinity 6510cs when I was fitting new door panel, after Autoglass damaged it while replacing side window. Fitting the new door panel was fairly straight-forward, the total time for panel fitting and speakers was about 5 hours.
Willie is offline   Reply With Quote
Old 1st March 2007, 01:01   #152 (permalink)
Diesel Demon
Chaps, I'm fitting the speakers tomorrow (Thurs 1st March) and wondered if there are any big "do's and don'ts" to consider when fitting.
I'm a little bit concerned about ensuring that the speakers, once fitted to the mounts and attached to the metalwork, line up properly with the plastics on the door. Is this a fair concern, or am I being paranoid? I don't want to have to keep taking them off and re-drilling the metalwork.
Also, what are peoples views on using spade connectors instead of soldering the wires to the speakers?
Any hints/tips before I dive in tomorrow would be greatly appreciated.
Damian
Old 1st March 2007, 11:17   #153 (permalink)
When you remove the door - be careful you don't miss any of the "clips" otherwise you won't have any problems at all.
I soldered mine directly but as you have the crossover there it can be done "away" from the car and just hooked up to the crossover in the car.
Old 3rd March 2007, 20:46   #154 (permalink)
Wander's Avatar
I'm allso intrested in this mod, buy I'm still a bit confused as in what I'd need to buy
Here's what I think I should buy:
Definitly:
- Infinity Speakers
- Wire
Maybe:
- Screws?
- Crossover thing?
- Spacer rings, whatever those might be, allso not sure which type
Tools:
- Solder Iron, solder, heat shrink tube
- Screw driver
- A power drill? Not sure about this one.
- A right hand (ie. not two left ones)
- Time to kill
Am I right? If not, why not?
Wander is offline   Reply With Quote
Old 10th March 2007, 14:04   #155 (permalink)
Griffyn's Avatar
Well seems everyone is using Infinity, is the forum sponsored by Infinity yet
Im not usually a Fan Boy but when it comes to Hifi I love my Alpine stuff!
Was thinking of a set of these:
http://caraudiosecurity.com/shop/pro...s_id/5769.html
I have the 05 spec Type-R speakers in my current car but can't remove those unfort But they sound great imo.
Will these definitely fit? As I was told the Type-Rs would fit in my last car but had to cut the doorcard to fit or not be able to close windows fully! Looked quite good tbh but dont really wana cut the door card to fit a speaker again! Depth is 59mm.
Do the infinities have much room behind them when installed and do they have much upfront for movement?
Griffyn is offline   Reply With Quote
Old 10th March 2007, 17:31   #156 (permalink)
TheBull's Avatar
Definitly:
- Infinity Speakers
- Wire
Maybe:
- Screws?
- Crossover thing?
Tools:
- Screw driver
- Time to kill
You'll need:
1. The speakers (they come with crossovers)
2. The mounting rings (astra ones as described earlier)
3. About 3m of speaker cable
3. Either spade connectors or solder/iron
4. Drill with 3mm bit? (Can't remember which one I used)
Old 10th March 2007, 18:35   #157 (permalink)
Wander's Avatar
I went to a car-audio shop today and told them I wanted better speakers for my Civic, and he recommended a "Magnet classic 216" set. He told me "same or better as the Infinity's, but more bass"
So what do you guys think? Are those good speakers? Is the price OK at 200 - 220 euro (incl fitting) ?
More info: http://www.magnat.de/content/carhifi...1826&pl=9&s=63
Old 11th March 2007, 15:18   #158 (permalink)
Power_of_Dreams's Avatar
iv changed mine too...jl components! factory speakers are ****, anything else is always goin to b a massive improvement!
Power_of_Dreams is offline   Reply With Quote
Old 11th March 2007, 16:46   #159 (permalink)
Griffyn's Avatar
Ok seems the Alpine Type-R Components will fit fine, will post in a few weeks when I get the car and then get round to sorting it out
Old 11th March 2007, 17:11   #160 (permalink)
Price looks fine, and I'd bet the speakers would be very similar to the Infinities. There's only so much you can do with this type of speaker within this budget. There will always be a lack of bass (the problem is the lack of cabinet made by the door) and the quality is going to be average given that it's a cheap source with a small (15w or so) cheap amp.
Bass can only be fixed by the addition of a small sub, a bit like Roger Harris's Alpine - or by doing the job properly and fitting a nice amped setup.
LinkBack to this Thread: http://www.civinfo.com/forum/how/277-front-speakers-replacement-infinity-ref-6510cs.html
Accesul la difuzoarele (din usi)... - Hondafan This thread Refback 7th November 2008 15:45
