This thread is about: Picture Hack for the satnav, it's in How To at the Honda Civic forum Civinfo; Am i missing something Ive taken this image and made it the right size Opened it paint and then reduced the colours to 256 and ...
LinkBack (7) Thread Tools Display Modes
Old 13th July 2007, 12:21   #41 (permalink)
Opened it paint and then reduced the colours to 256 and its looking like this
is this correct
Sorry just realised that the file is 111 kb so too big to add
MoOriginal is offline   Reply With Quote
Old 13th July 2007, 12:29   #42 (permalink)
Upload it to Photobucket and post the link
Old 13th July 2007, 12:44   #43 (permalink)
this is before i ran the convesion program on it
just a standard bmp saved from paint
http://www.dropshots.com/day.php?use...3&ctime=124239
Old 13th July 2007, 12:57   #44 (permalink)
Could anyone make an iso ready to change a picture and share it?
Regards
ayasystems is offline   Reply With Quote
Old 13th July 2007, 13:17   #45 (permalink)
if we can get this then it must be possible then to put speed camera on the disc so get hacking and let us no when its done lol
allan79 is offline   Reply With Quote
Old 13th July 2007, 14:26   #46 (permalink)
Bog
Bog's Avatar
Easier said than done! This hack is easy because you can find, extract and replace the bmp image in the BIN file. The POI's are well hidden in the code and therefore some serious hacking and coding is required. The guy's in the US on the Honda/Acura forums have been trying for a while now without much success!
I'm sorry to say, I doubt it will ever happen unless Honda update the firmware to allow the bulk import of POI's in a future map update. Again this is unlikley due to thact they would not want to open themselves up to litigation!
Old 13th July 2007, 15:45   #47 (permalink)
-=Stella Artois=-'s Avatar
Originally Posted by DigitalPlumber View Post
I think Honda might have stopped this hack working. I’ve tried twice and it just results in a blank screen being displayed instead of the image then continues to the nag screen as normal.
My car was made in March 07. Anyone else got it to work on a new car?
Of course I could have done something wrong, but I followed the instructions to the letter and didn’t get any errors.
I got exactly the same result, no errors, just a blank screen. Yes, i followed the destructions explicitly too.
-=Stella Artois=- is offline   Reply With Quote
Old 23rd July 2007, 13:09   #48 (permalink)
Morph3ous's Avatar
I have the 2005/2006 3.03 version disc, and so I think this screen hack should work. Therefore I'm having a go at it, however I have a problem with the instructions.
What do these bits mean? What do I have to do? Confused with command line stuff...
Convert it using 8to16 at the command line:
Code:
Copy Opening1.bmp also to the bysin folder. Run bysin from the command line
Code:
Morph3ous is offline   Reply With Quote
Old 28th July 2007, 13:19   #49 (permalink)
p64
Ezermester
p64's Avatar
Hello!
I have a problem. After bysin cmd line I get a response 'Unable to find opening1.bmp on BIN' . Ver.3.01 .Any suggestions?
Regards, Andrej
p64 is offline   Reply With Quote
Old 19th April 2008, 14:32   #50 (permalink)
Adams's Avatar
Hi all.
The procedure to hack picture is valid also for the new version 3.23?
Adams is offline   Reply With Quote
Old 20th April 2008, 00:41   #51 (permalink)
kekonline's Avatar
Hi everyone, im new to this page, i have been reading lots of post. Im sorry if my english is bad. i have been trying to do these for at least 6 hours and i haven´t managed to get it right. i think my problem is getting the image in 256 colours, in paint shop pro do you select the option standard/web? Thanks
kekonline is offline   Reply With Quote
Old 20th April 2008, 00:43   #52 (permalink)
kekonline's Avatar
Hey p64 you need to go to the file properties and take the tick off the read only checkbox
hope that works
Old 20th April 2008, 08:35   #53 (permalink)
weclome aboard
attach your image in here and I'm sure someone will be able to work out what's going on
Old 20th April 2008, 08:50   #54 (permalink)
I think I used PSP 7 - maybe this is the problem?
http://gd.tuwien.ac.at/pub/pc/bazar/psp700ev.exe
Old 20th April 2008, 10:21   #55 (permalink)
kekonline's Avatar
Ok, Thanks here is the pic.
Thanks a lot
Old 20th April 2008, 10:48   #56 (permalink)
kekonline,
That bmp works perfectly for me without going through PSP7. Though I did also put it through PSP7 and saved it as saved2a.bmp, and that also worked fine:
Code:
C:\temp\8216\Release>8to16 save2.bmp Opening1.bmp
palette starts at 00000036
data starts at 00000436
C:\temp\8216\Release>8to16 save2a.bmp Opening1a.bmp
I have attached the Opening1.bmp here too.
Old 20th April 2008, 12:32   #57 (permalink)
kekonline's Avatar
Ohhh,
Thanks a lot im going to try it just now!!!
Muchas Gracias
Old 20th April 2008, 13:16   #58 (permalink)
kekonline's Avatar
well, i couldn´t make it work, i keep getting a black sceen, y did the last step with the
but it still didn't work, i have the 3.03 dvd and a civic from de 2008 from spain, do you think that make any difference? Any way all civic are nicely made in the uk. i must be doing something wrong and i have no idea.
Any last advice?
Old 20th April 2008, 14:35   #59 (permalink)
My 3.03 never had these files (which is odd):
SMGA.bin
A0000_00.MNG
DCA0.REG
PRG_INFO.MNG
UPDATE_APL.exe
Does yours? Have I got this right - you did the bysin thing and it worked, you updated the firmware with a CD and it worked, but when the satnav boots you just get a black screen? Is that what is happening?
Old 20th April 2008, 17:23   #60 (permalink)
kekonline's Avatar
I have just re-checked and i have version 3.06, i have the quoted files and i did yes did the bysin thing and it worked, i put the cd and it worked, but the sat nav disc and i get the black screen. So yes you go it right. you do all the stuff in the folder that says release, right?
LinkBack to this Thread: http://www.civinfo.com/forum/how/318-picture-hack-satnav.html
Neue Funktion Civic FK ??? : Seite 17 : Honda Civic FK, FN, FD This thread Pingback 7th October 2008 18:39
Civic-FX.net - Forum Honda Civic ab 2006 (FK, FN, FD) • Thema anzeigen - wer kann das übersetzen This thread Refback 7th October 2008 17:02
www.FnHatch.de :: Thema anzeigen - Erffnungsbildschirm beim Navi wechseln This thread Refback 15th May 2008 20:07
www.clubhondacivic.com :: Ver tema - navegador y radares This thread Refback 13th January 2008 14:21
Navigatore - Elettronica This thread Refback 19th November 2007 10:58
www.clubhondacivic.com :: Ver tema - [BRICO] Cambiar la imagen inicial al encender el Navegador This thread Refback 18th November 2007 11:01
Neue Funktion Civic FK ??? : Honda Civic FK, FN, FD This thread Refback 17th November 2007 16:01
Similar Threads for: Picture Hack for the satnav
Satnav Sat Nav Nag Screen Hack DigitalPlumber Electronics 25 20th February 2008 11:26
Brakes Brake calipers painted picture example anyone? Ditmar Wheels, Tyres, Suspension and Brakes 3 4th March 2007 08:23
Creating a post with a picture Pottsy Basic tutorials 0 10th December 2006 16:11
Transmission Picture of i-shift Paddles anywhere? Munky Engines and Transmission 8 1st September 2006 17:20
S-Silver London Motor Show Picture of the Honda Civic Alan Gallery 5 28th July 2006 22:20
