| This thread is about: [HOW TO] Install a subwoofer and amp, it's in How To at the Honda Civic forum Civinfo; mistake... | ||
LinkBack (4) | Thread Tools | Display Modes |
#23 (permalink) |
Getting the Amp wire through the grommet was tbh the most difficult part as there is very little room to get your hand in. I had some help but basically used a screwdriver to pull back the grommet enough to get the wire through the pulled it into the car from the inside.
I think I got the Cigarette Adapter from Halfords but i'm sure other places do them too. |
#26 (permalink) |
Unfortunately, don't have pictures for 'remote' from antenna amp wire.
But, it is easy to locate it -> when you pull HU out, there's small black connector for antenna. On that connector is also cable for antenna amplifier, which you need to cut open and connect remote signal to. As for rest of setup (like where I pulled wires, feel free to refer to my post about my install): My sub/speaker install |
#27 (permalink) |
Nick, to pull HU starts to complicate everything..
For signal to Amp I will use the 12v connector in the trunk. I tried allready to push hard metal bar throught the hole behind pedals, but in the engine compartment, I could not locate the other end. Did you remove the Air Intake out for pulling throught the power cable? I have 2.2 CTDi so the engine may look different. I cannot see anywhere behind the engine. Want to install the infinity referrence speakers and also the bitumen multiseal. |
#28 (permalink) |
Yes, I removed air filter box to have some space there, as otherwise it's close to impossible.
Also, you push cable from inside to engine bay. |
LinkBack to this Thread: http://www.civinfo.com/forum/how/399-how-install-subwoofer-amp.html
| Honda Performance Club - Forum > Lågnivå i nya Civic 1.8? | This thread | Refback | 10th September 2008 20:40 | |
| Honda Performance Club - Forum | This thread | Refback | 20th November 2007 19:20 | |
| Cavo-> da batteria a baule - Elettronica | This thread | Refback | 2nd November 2007 21:39 | |
| www.clubhondacivic.com :: Ver tema - Duda altavoces delanteros | This thread | Refback | 24th September 2007 17:31 | |
| Subwoofer Hot deal on subwoofer! | Koen | Ipods, MP3 Players and ICE | 6 | 28th October 2007 12:39 |
| Subwoofer & Speakers | jamesaberdeen73 | Type-R | 0 | 5th October 2007 23:10 |
| Subwoofer Do I need an LOC for my amp? (Subwoofer-only connection) | cra41g | Ipods, MP3 Players and ICE | 1 | 2nd September 2007 13:09 |
| Radio Bass enhancement without subwoofer : Mission Impossible ? | type901 | Ipods, MP3 Players and ICE | 12 | 10th August 2007 14:14 |
| My install my new ICE - install | VaTaR | Ipods, MP3 Players and ICE | 9 | 6th January 2007 09:16 |
